I don't know why it doesn't work
pascal
Domoticz version: V4.9700
Post by pascal »
Who could explain to me why it does not seem to work. Here is my script:
timer = { 'every minute' }
execute = function(domoticz, timer)
if (device'Fin_chauffage'.state == 'On')
then
device'prise ordi'.switchOff()
device'prise TV Chambre'.switchOff()
domoticz.notify('Hey pas mal')
device'prise TV Chambre'.switchOn()
device'prise ordi'.switchOn()
Thanks for your help
Pascal
Re: I don't know why it doesn't work
You missed a couple of () in your code. Do you see anything in the domoticz logfile ?
Please use code tags around your code to improve readability on the forum.
    on = { timer = { 'every minute'} },
    logging = {     level = domoticz.LOG_ERROR,
                    marker = "chauffage actions" },
        if (device('Fin_chauffage').state == 'On') then
            device('prise ordi').switchOff()
            device('prise TV Chambre').switchOff()
            device('prise TV Chambre').switchOn()
            device('prise ordi').switchOn()
pascal
Post by pascal »
No I don't see anything in logfile. even with yours. Amazing
pascal wrote: Tuesday 17 July 2018 22:56 No I don't see anything in logfile. even with yours. Amazing
Did you enable logging in your /etc/init.d/domoticz.sh ?
by removing the # on the line
#DAEMON_ARGS="$DAEMON_ARGS -log /tmp/domoticz.txt"
so that it reads
pascal
Post by pascal »
I just did, but nothing happens. Probably something I did not do properly, but I don't know what.
pascal
Post by pascal »
Here is the error I have:
2018-07-18 21:10:56.190 Status: dzVents: Error (2.4.6): chauffage actions: ...e/pi/domoticz/scripts/dzVents/generated_scripts/kiki.lua:8: attempt to call global 'device' (a nil value)
Thanks for your help :-)
pascal wrote: Wednesday 18 July 2018 21:15 Here is the error I have:
We are getting somewhere now. Please try this modified script.
    execute = function(domoticz, trigger)
        if (domoticz.devices('Fin_chauffage').state == 'On') then
            domoticz.devices('prise ordi').switchOff()
            domoticz.devices('prise TV Chambre').switchOff()
            domoticz.devices('prise TV Chambre').switchOn()
            domoticz.devices('prise ordi').switchOn()
pascal
Post by pascal »
here it is:
2018-07-18 21:39:00.664 Status: dzVents: Error (2.4.6): chauffage actions: ...e/pi/domoticz/scripts/dzVents/generated_scripts/kiki.lua:8: attempt to call local 'device' (a table value)
pascal wrote: Wednesday 18 July 2018 21:40 here it is:
My mistake. I edited the previous post
pascal
Post by pascal »
any clue? :-(
pascal wrote: Wednesday 18 July 2018 23:17any clue? :-(
Did you try the edited version ?
the logic in your script causes dzVents to send you a notifications every minute for as long as "Fin_chauffage" state is On. It will also switch the other devices with a delay varying from 1 - 60 seconds. If you want to change the script in such a way that it triggers direct and only when the state of "Fin_chauffage" changes; modify it to:
    on = { devices = { 'Fin_chauffage'} },
                    marker = 'chauffage actions' },
       if trigger.state == 'On' then
pascal
Post by pascal »
:roll: Thanks a lot Waaren. It is working exactly how I wanted. What is the difference between:
execute = function(domoticz, trigger) and execute = function(domoticz, Device)?
Thanks again.
Pascal :P :P
jake
Post by jake »
pascal wrote::roll: Thanks a lot Waaren. It is working exactly how I wanted. What is the difference between:
Thanks again.
Pascal Image :P
Please check the wiki:
https://www.domoticz.com/wiki/DzVents:_ ... gerInfo.29
There they use the word 'item'. It is your choice what word to use. In your script you didn't make use of the'trigger word', so you can skip it as well:
execute = function(domoticz)
jake wrote: Thursday 19 July 2018 14:18
pascal wrote:What is the difference between:
@Jake, in the example based on the device state change trigger is used so better to leave it like it is.
@pascal, the the second parm in the function(domoticz,Device) (or function(domoticz,trigger) ) is the object that is triggering the script.
It can be a device, variable, scene, group, timer, security or httpResponse depending on what you defined in the on = (....) section.
jake
Post by jake »
@waaren, I based my comment on the initial scripts. Now I see in your suggested improved script (which I think is much better in this situation) that you used the 'trigger' in your script as intended.
