Omnik Inverter - Additional data
TommySunny
Domoticz version: 2024.1
Post by TommySunny »
I'am using the Wouterrr script to acquire the data from an Omnik inverter.
Everything works like a charm however when I look into my inverter either via the inverter interface or the via the portal I see that more info is available.
I mean like the AC output Voltage, the grid frequency (Hz).
I don't know how to adapt this in the code.
Did anyone already changed the script or knows how to do this?
sincze
Domoticz version: 2024.4
Re: Omnik Inverter - Additional data
Post by sincze »
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
TommySunny
Yep, I used this to get things working.
But the AC output (V) en frequency output (Hz) are not in the list and I was wondering if these could be added in some way.
Since I'm lacking the skills to do as such in Pyhton I was wondering if someone on this forum had already done this.
sincze
Post by sincze »
TommySunny wrote: Monday 09 July 2018 9:57 Yep, I used this to get things working.
mmm nicely noticed. Let me check.
As I think I DO have those numbers for you.
I assume if you test with LiveStats.py (wouterrrr) you see those values presented in the cli?
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Post by sincze »
The following should be possible with Omnik Inverter:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
plantjes
Domoticz version: 3.5877
Post by plantjes »
Hi, got the Woutrrrr solution working...
But i have 3 Omnik systems in my network...
What would be the easy way of getting the data from all 3 systems...
Obvious the naming and IDX can be different in Domoticz, but how to tell python there a 3 systems to get the data from...
Benno
