domoticz in synology as package! Available now.
- Domoticz version: 2022.2
oops, spoke to soon.
somehow the hue lights status is not updated in domoticz with v4.9700
everything works, lights go on and off but the switch status never changes
also i noticed that al my kWh meters were reset to zero
i had to revert back to good old v3.8720(with dzVentz in usr/local/domoticz/var/dzVents)
now everything is back to were it was before including the kWh meter totals
the good thing is i wrote a restore script so now i can restore to previous versions really fast without loosing anything
i also checked previous versions to see were things went wrong with dzVents
6.1-9417 is the last version holding dzVentz(under usr/local/domoticz/var/dzVents)
6.2-8975 is the last version holding dzVentz(under usr/local/domoticz/var/dzVents)
so it does not mattter much were dzVents is installed as long as it is found by domoticz so the search path must match the install path
maybee check those versions to see what the install script looks like and take this as the base for newer builds(to keep uniformity)
- jumbotroll
Is this hue lights status a bug in source code or is because dzVents is in wrong folder?Gravityz wrote: ↑Tuesday 26 June 2018 21:04 oops, spoke to soon.
Last edited by jumbotroll on Wednesday 27 June 2018 11:03, edited 2 times in total.
https://paypal.me/Jumbotroll
Jumbotroll
http://www.jadahl.com
Jumbotroll
- waaren
It is not because dzVents is in wrong folder. Probably something in source but not confirmed yet. For standard Hue setup, dzVents is not required.jumbotroll wrote: ↑Tuesday 26 June 2018 22:37 Is this hue lights status a bug in source code or is because dzVents is in wrong folder?
- jumbotroll
Ok Thanks!waaren wrote: ↑Tuesday 26 June 2018 22:48It is not because dzVents is in wrong folder. Probably something in source but not confirmed yet. For standard Hue setup, dzVents is not required.jumbotroll wrote: ↑Tuesday 26 June 2018 22:37 Is this hue lights status a bug in source code or is because dzVents is in wrong folder?
Jumbotroll
Jumbotroll
yes correct.
nothing to do with dzVents
Just updated domoticz on my 214 Synology DSM 6.1, my dashboard is working fine, but I don't see my switches etc. in the switches tab anymore.... need some support
you propably need to clear the browser cache, close browser, open browser and try again.
i have this sometimes when i do a reinstall. when i restore the database not al the switches and scenes are visible.
cleaning out the cache helps for me
[/quote]
[/quote]
ooooo damn..you are right..its working now.. thanks!
[/quote]Gravityz wrote: ↑Wednesday 27 June 2018 22:10 you propably need to clear the browser cache, close browser, open browser and try again.
v4.9728 seems to fix the hue lights update bug again.
would be nice if you can make this build so i can test it Jumbotroll
the question is also what they will do with the stable build(since it obvious is far from stable)
can they recompile under the same number?
- jumbotroll
I can build v4.9728 for you, but I think this was fixed in v.4.9727.Gravityz wrote: ↑Thursday 28 June 2018 20:00 v4.9728 seems to fix the hue lights update bug again.
I did upload that earlier today: http://www.jadahl.com/domoticz_beta_6.2/
Edit: v.4.9728 Apollolake is uploaded.
Jumbotroll
Jumbotroll
tested 9728 and can confirm hue status is updated again although the time it needs to update seems slower(approx 5-8 seconds) switching lights of updates status instantly
- Antori91
- Domoticz version: 4.10717
Same here complaining about domoticz and mosquitto users. It is a new rule of Synology security advisor (not related to a version of domoticz). I assume this warning comes because domoticz (and mosquitto) user is not in the users list (control panel/users). To solve this issue, I've just skipped this rule using the skip action button in the security advisor menu.jZNJ wrote: ↑Sunday 24 June 2018 12:41jumbotroll wrote: ↑Sunday 24 June 2018 11:19I don't have this message, but I think it's because we have to run domoticz as root user on synology.Gravityz wrote: ↑Sunday 24 June 2018 10:16 i have the same message
it seems it is a new protection check for abnormal users (users linked to certain apps, not regular users)
not sure how to solve this
you can remove the entry but i am not sure if user domoticz is necessary for a working/upgradable Domoticz version
@Jumbotroll, care to jump in?
I have the same message.
Have attached screenshots that illustrates it.
In /etc/passwd I see a line with domoticz::<number>:<number>:Domoticz User:<path>
Domoticz High Availability Cluster: Synology Dz V4.10693 (Main) - Raspberry Dz V4.10717 (Backup) - Scripts Node.js
Alarm server: Raspberry - motionEye - iot_ALARM-SVR Node.js
Sensors/Actuators: ESP8266-Arduino
https://github.com/Antori91/Home_Automation
@Jumbotroll: will you compile the latest beta including python for me.
i'm using Philips Hue lights
- jumbotroll
What DSM version? DSM 6.1 or DSM 6.2 ?
What NAS do you have?
Jumbotroll
Jumbotroll
I'm using DSM 6.2 on a DS115jumbotroll wrote: ↑Wednesday 04 July 2018 17:59What DSM version? DSM 6.1 or DSM 6.2 ?
Same for me please, DS212j and DS211j, DSM 6.2@Jumbotroll: will you compile the latest beta including python for me.
Many thanks
- jumbotroll
Donehbennis wrote: ↑Wednesday 04 July 2018 18:18I'm using DSM 6.2 on a DS115jumbotroll wrote: ↑Wednesday 04 July 2018 17:59What DSM version? DSM 6.1 or DSM 6.2 ?
http://www.jadahl.com/domoticz_beta_6.2_python/
Jumbotroll
Jumbotroll
- jumbotroll
Sorry, I don't compile for arch 88f6281 or 88f6282 anymore because of -std=c++11 in domoticz source code and the old toolchain from synology.
Last edited by jumbotroll on Wednesday 04 July 2018 21:19, edited 1 time in total.
Jumbotroll
Jumbotroll
Thanksjumbotroll wrote: ↑Wednesday 04 July 2018 19:30Donehbennis wrote: ↑Wednesday 04 July 2018 18:18I'm using DSM 6.2 on a DS115jumbotroll wrote: ↑Wednesday 04 July 2018 17:59
Hi Jumbotroll, can you compile the latest 4.x with Python for the DS412+ (cedarview) with DSM 6.1? Still a bit affraid to update to 6.2...
Thanks in advance.
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Thanks in advance.
