Anyone using their wireless switches to switch yeelights via a script?
viewtopic.php?f=11&t=13016&p=182516#p182516
- Domoticz version: BETA
snellejellep wrote: ↑Monday 04 June 2018 11:18 yes, there is a seperate hardware thingy for that: https://www.domoticz.com/wiki/Yeelight
note: do not forget to turn on lan access in the yeelight app otherwise domoticz wont find your lights, i spent hours troubleshooting but i forgot that step
That is the point I cannot find this option n the app any more?
- Domoticz version: 2020.2
i checked, if you tick the name of the light, then push the button with the icon that looks like a cd/dvd eject button (arrow up), if you do it correctly there will show up a menu, push lan management, i have dutch so maby it wil not be called that way but it has a lightning icon, if you tap that, there you can switch lan management on.
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
snellejellep wrote: ↑Monday 04 June 2018 20:49i checked, if you tick the name of the light, then push the button with the icon that looks like a cd/dvd eject button (arrow up), if you do it correctly there will show up a menu, push lan management, i have dutch so maby it wil not be called that way but it has a lightning icon, if you tap that, there you can switch lan management on.
Edit:
Thanks!!!
Works!!!
Is there perhaps someone that have Floating working in Domoticz???
That's a great option..
Love
i am using the yeelight app
hello
someone have the vima smartlock ???
- Domoticz version: la. beta
Hi does anybody update to 1.4.1_155.0143, is it working with Domoticz?
Love my Xiaomi Gateway in connection with homebridge and domoticz on my PI3
Xiaomi Gateway Domoticz Wiki
Yes, a few weeks ago and so far no issuestheo69 wrote:Hi does anybody update to 1.4.1_155.0143, is it working with Domoticz?
Sent from my SM-G935F using Tapatalk
thanks, just updated confirming it works
yesterday we received the "Xiaomi Philips ZhiRui E27 bulb". The lamp works well in the "Mi Home". But do not get it in Domoticz. Someone experience with this lamp? Any idea how to reset this lamp?
Today came smoke sensors from xiaomi. Pulled them into domotix without any problems, as well as other sensors from xiaomi. I smoke one of them for verification, the sensor yelled and the gateway, too, but the domotix is silent. No reaction. What can be wrong? Can anyone come across. They are supported. In the logs the following is written:
Code
2018-06-24 13: 21: 16.570 Status: {"cmd": "report", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\ "density \": \ "0 \"} "}
[*] [*] [*] 2018-06-24 13: 21: 16.584 Status: {"cmd": "heartbeat", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" voltage \ ": 3205, \" alarm \ ": \" 0 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 16.766 Status: {"cmd": "report", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" alarm \ ": \" 0 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 16.813 Status: {"cmd": "report", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" density \ ": \" 0 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 16.829 Status: {"cmd": "heartbeat", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" voltage \ ": 3205, \" alarm \ ": \" 0 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 28.560 Status: {"cmd": "report", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" alarm \ ": \" 2 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 28.600 Status: {"cmd": "report", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" density \ ": \" 0 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 28.619 Status: {"cmd": "heartbeat", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" voltage \ ": 3205, \" alarm \ ": \" 2 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 34.913 Status: {"cmd": "report", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" alarm \ ": \" 0 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 34.969 Status: {"cmd": "report", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" density \ ": \" 0 \ "}"}
[*] [*] [*] 2018-06-24 13: 21: 34.971 Status: {"cmd": "heartbeat", "model": "smoke", "sid": "158d0001e582bd", "short_id": 50705, "data": "{\" voltage \ ": 3205, \" alarm \ ": \" 0 \ "}"}
But the sensor in the home kit does not change.
Gesendet von meinem FRD-L09 mit Tapatalk
Code
Looking to get a new beside lamp, any feedback RE the Yeelights vs Xiaomi Philips Zhirui 9290019202?
I particularly like that the Philip model is powered by USB C.
https://www.gearbest.com/night-lights/p ... id=1433363
Anyone buying be sure to use the below Domoticz link so the project gets a bit back from your purchase.
https://www.gearbest.com/?lkid=12996811
this week i recevied my Xiaomi Aqara gateway. It has radio function (it seems so in the app) and the device name in my LAN mentions "v3".
The current android app version is from June 25 2018.
I can not get it into developper mode; i can not find any submenu or setting about the app version, "about", "..." or whatsoever (only the User Agreement Version). It seems the app had some update since the instructions online, since the look is quite different, please see screenshots:
https://imgur.com/a/mWJOVfG
I have location set as Mainland China. I also tried Europe (that does only provide less options just as suggested online).
The app has updated the Gateway (Mi Control Hub) to latest version though i can't see what that version number is.
Does anyone know how to set developper mode in current app version?
You should press Mi control hub, then Settings -> About and then click at the bottom of the screen.
Thanks but the only settings I can find are the settings on bottom left as seen in the screen shots, which are just the "Manage rooms" settings. When I click the MI Control Hub it shows the menu with the options "switch" "light" "arming" and "more operations" as also shown in the screenshots. Clicking "more operations" doesn't do anything. I tried for 3 hours by nowCaesarPL wrote:You should press Mi control hub, then Settings -> About and then click at the bottom of the screen.
Verstuurd vanaf mijn ONEPLUS A3003 met Tapatalk
Mi control hub settings are here: https://imgur.com/a/oY4PnKS
Ahh, something else is wrong i think! I do not even have that menuCaesarPL wrote: ↑Wednesday 04 July 2018 9:36 Mi control hub settings are here: https://imgur.com/a/oY4PnKS
I think it must have been the server availability and my lack of patience. When pressing the gateway and then "more options" nothing seemed to happen. When I tried in the morning and waited about 5 minutes I did get into the options menu. In the evenings still access is difficult but I managed to set up everything
Verstuurd vanaf mijn moto g(6) plus met Tapatalk
- Domoticz version: V2022.1
Does somebody know if it is possible to get the battery percentage connected to a dummy switch?
I have a doorsensor called "xiaomi door sensor".
It has a battery percentage of 85 when looking in the devices.
Tried to make a dummy switch setup as percentage switch, called "xiaomi door sensor battery".
But this doesn't work.
Does somebody know an option, how to get the battery percentage connected to a switch?
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
Someone knows if the new Xiaomi Aqara IP camera Gateway is compatible with Domoticz as Gateway. This device works as a zigbee gateway and is a good alternative as a hub:
https://www.aliexpress.com/item/Origina ... autifyAB=0
I have seen that you have already asked but it has not been answered.
Thank you
Thank you
