Seismic devices
EddyG
Seismic devices
Post by EddyG »
I saw that the seismic device are in the latest beta.
I have an FIBARO FGMS001-ZW5 Motion Sensor which supports seismic data.
It was always an error in the logging at the start of Domoticz because Domoticz did not support it yet.
But now the support is in I do not get the device(s).
How do I get the device(s) in Domoticz?
gizmocuz
Re: Seismic devices
Post by gizmocuz »
I have not tested it... I have a multisensor, but i have no idea how to simulate an earhquake with it.
I tried shaking... but nothing happens
You should enable 'accept new devices' in the settings, and then it should be detected (i hope)
EddyG
Re: Seismic devices
Post by EddyG »
I did shake it, I did forcely tap it, I forced an Alarm.
I did enable 'accept new devices', but nothing happend.
Previous I always had an error when starting Domoticz about a seismic device. That error has gone.
The log now shows:
2018-07-02 09:53:01.633  OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR MULTILEVEL, Label: Seismic Intensity, Instance: 25
But NO new device.
gizmocuz
Re: Seismic devices
Post by gizmocuz »
Then it seems you (and i) don't get any updates on this sensor.
Can you try to enable debug on the zwave controller (not to long as this file can be very big)
(Setup on OZW hardware)
When all nodes have been queried, try to simulate an alarm.
In the 'Config' folder you should find the log file, can you see any updates on this sensor ?
EddyG
Re: Seismic devices
Post by EddyG »
Going for a short holiday in 30 min.
Will test comming friday or saterday.
EddyG
Re: Seismic devices
Post by EddyG »
I did startup domoticz with loglevel 9 on ZWave.
This is the result concerning Seismic data, it came together with Lux data.
2018-07-09 11:27:29.087 Detail, Node017,   Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x11, 0x05, 0x31, 0x05, 0x19, 0x21, 0x38, 0xd0
2018-07-09 11:27:29.087 Info, Node017, Received SensorMultiLevel report from node 17, instance 1, Seismic Intensity: value=5.6mercalli
2018-07-09 11:27:29.087 Detail, Node017, Initial read of value
2018-07-09 11:27:29.088 Detail, Node017, Notification: ValueChanged
2018-07-09 11:27:29.272 Detail, Node017,   Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x11, 0x06, 0x31, 0x05, 0x03, 0x0a, 0x01, 0x25, 0xf9
2018-07-09 11:27:29.272 Info, Node017, Received SensorMultiLevel report from node 17, instance 1, Luminance: value=293lux
2018-07-09 11:27:29.272 Detail, Node017, Initial read of value
2018-07-09 11:27:29.272 Detail, Node017, Notification: ValueChanged
And somewhat later this:
2018-07-09 11:27:56.643 Detail, Node017,   Received: 0x01, 0x0b, 0x00, 0x04, 0x00, 0x11, 0x05, 0x31, 0x05, 0x19, 0x21, 0x00, 0xe8
2018-07-09 11:27:56.643 Info, Node017, Received SensorMultiLevel report from node 17, instance 1, Seismic Intensity: value=0.0mercalli
2018-07-09 11:27:56.644 Detail, Node017, Refreshed Value: old value=5.6, new value=0.0, type=decimal
2018-07-09 11:27:56.644 Detail, Node017, Changes to this value are not verified
2018-07-09 11:27:56.644 Detail, Node017, Notification: ValueChanged
gizmocuz
Re: Seismic devices
Post by gizmocuz »
@Eddy, was this during startup or where the nodes already queried ?
Did you pick up the node, and give it a shake ?
If after nodes queried and shaking, i should be able to replicate this, tried it before, but no Seismic changes where reported
EddyG
Re: Seismic devices
Post by EddyG »
I restarted domoticz with Zwave loglevel at 9.
Directly after all nodes where queried I shaked the device and this was the output.
In the domoticz log I see the message, but a new device is not created.
2018-07-09 11:29:32.742 OpenZWave: Value_Added: Node: 17 (0x11), CommandClass: SENSOR MULTILEVEL, Label: Seismic Intensity, Instance: 25
EddyG
Re: Seismic devices
Post by EddyG »
Anyone got it working yet?
gizmocuz
Re: Seismic devices
Post by gizmocuz »
Nope sorry, just checked again, and i get no Seismic value at all, also not at startup
Could you tell me from the openzwave node list, what ID/Type you have ?
Mine is 0x1001, 0x0800, i have included this on a non-zwave+ stick
Benneton
Re: Seismic devices
Post by Benneton »
I have this sensor and I am interested in the seismic intensity meter stuff
I have just added this device to Domoticz and do not get the seismic output in the domoticz log.
Did one of you get this working?
Bernard
assenzuid
Re: Seismic devices
Post by assenzuid »
Not working here, but interest how to get it to work.
febalci
Re: Seismic devices
Post by febalci »
@gizmocuz,
Screen Shot 2018-12-30 at 12.57.05.png (27.03 KiB) Viewed 872 times
In order for the FGMS001 (At least on ZWave Plus version) to have Seismic Sensor; parameter 24 should be assigned to "Tamper and Earthquake".
Screen Shot 2018-12-30 at 12.59.05.png (29.79 KiB) Viewed 872 times
But i still don't have the seismic device created still.
