Hi, I need your help. I have now used two ajhre without problems my raspberry with openzwave USB. since the new version of domoticz was installed, domoticz crashes after about 15 minutes.
That's why I put a new system on a new memory card. raspberry with STRETCH and domoticz 4.97.
I still have the old configuration.
I did a backup with domoticz and made the configuration of the openzave hardware.
after I load the backup in domoticz, I have all the switches, etc.
also the devices are restored
but under the hardware / openzwave usb I have no nodes.
how can i restore my system?
Thank you for your help, I am desperate for 3 days work ...
NEED HELP! Zwave problems after new domoticz version, how to backup?
- hardware restored in domoticz
- hardware.JPG (115.72 KiB) Viewed 938 times
- switches restored in domoticz
- domoticz.JPG (168.36 KiB) Viewed 938 times
- devices restored in domoticz
- devices.JPG (200.44 KiB) Viewed 938 times
Re: problems after new domoticz version, how to backup
no nodes under the hardware of open zwave
- no nodes
- setup_empty.JPG (92.89 KiB) Viewed 936 times
- no possibility to load configuration
- setup_empty_load.JPG (122.68 KiB) Viewed 936 times
- gizmocuz
Re: NEED HELP! problems after new domoticz version, how to backup?
I think your USB port is not correct, you have two times openzwave ? One with ttyAMA0 (that can not be right i think) and 1 on ttyUSB20
First, give them each a different name !! (never give something the same name!?)
- go to the devices tab, search for a switch you had, check the hardware it was used on (lets say OpenZWave_1)
- now make sure in the hardware overview, the other openzwave hardware is disabled, that is the wrong one,
- configure/enable the correct one, make sure the USB port is correct!!
- Now check the log
Another thing, "the new version" ,.. there are new versions everyday!, What was your old version, what is your current version ?
- Now check the log
