still error but in line 8. thanks for taking time anyway!
Water tank level (from other webserver)
Tarzan737
Re: Water tank level (from other webserver)
Ok! but sorry, no success anyway
- Screenshot (8).png (188.86 KiB) Viewed 3173 times
- Egregius
- Domoticz version: v2024.7
What if you past thag url in a browser and just change the ip address?
- Egregius
What? What don't you understand? You don't know what a url is? Or you don't know what a browser is?
Well, a url is a link, in this case:
And a browser? That's what you use the browse the web, like Chrome, Firefox, Safari,...
So, copy the above url and past it in the address bar of your browser.
You should see this:
http://192.168.0.14:8080/json.htm?type=command¶m=udevice&idx=33&nvalue=0&svalue=100So, copy the above url and past it in the address bar of your browser.
"status" : "OK",
"title" : "Update Device"
Tarzan737
Sorry for late answer (been away) but i do get this
if i use 192.168.0.14
but if i use 127.0.0.1:8080 i get domoticz offline with this code
"status" : "OK",
"title" : "Update Device"but if i use 127.0.0.1:8080 i get domoticz offline with this code
<!DOCTYPE HTML>
<html>
<head>
<meta charset="UTF-8">
<title>Domoticz Offline</title>
<meta name="viewport" content="initial-scale=1.0, maximum-scale=1.0, user-scalable=0" />
<style>
html, body
height: 100%;
body
font: 12px 'Lucida Sans Unicode', 'Trebuchet MS', Arial, Helvetica;
margin: 0;
background: #202020 url(../css/images/img01.jpg) repeat;
#offline
background-color: #fff;
background-image: -webkit-gradient(linear, left top, left bottom, from(#fff), to(#eee));
background-image: -webkit-linear-gradient(top, #fff, #eee);
background-image: -moz-linear-gradient(top, #fff, #eee);
background-image: -ms-linear-gradient(top, #fff, #eee);
background-image: -o-linear-gradient(top, #fff, #eee);
background-image: linear-gradient(top, #fff, #eee);
height: 50px;
width: 300px;
margin: -150px 0 0 -180px;
padding: 30px;
position: absolute;
top: 50%;
left: 50%;
z-index: 0;
-moz-border-radius: 3px;
-webkit-border-radius: 3px;
border-radius: 3px;
#offline:before
content: '';
position: absolute;
z-index: -1;
border: 1px dashed #ccc;
top: 5px;
bottom: 5px;
left: 5px;
right: 5px;
-moz-box-shadow: 0 0 0 1px #fff;
-webkit-box-shadow: 0 0 0 1px #fff;
h3
text-transform: uppercase;
text-align: center;
color: #666;
margin: 0 0 30px 0;
letter-spacing: 4px;
font: normal 26px/1 Verdana, Helvetica;
position: relative;
h3:after, h3:before
background-color: #777;
content: "";
height: 1px;
position: absolute;
top: 15px;
width: 60px;
h3:after
background-image: -webkit-gradient(linear, left top, right top, from(#777), to(#fff));
background-image: -webkit-linear-gradient(left, #777, #fff);
background-image: -moz-linear-gradient(left, #777, #fff);
background-image: -ms-linear-gradient(left, #777, #fff);
background-image: -o-linear-gradient(left, #777, #fff);
background-image: linear-gradient(left, #777, #fff);
right: 0;
h3:before
background-image: -webkit-gradient(linear, right top, left top, from(#777), to(#fff));
background-image: -webkit-linear-gradient(right, #777, #fff);
background-image: -moz-linear-gradient(right, #777, #fff);
background-image: -ms-linear-gradient(right, #777, #fff);
background-image: -o-linear-gradient(right, #777, #fff);
background-image: linear-gradient(right, #777, #fff);
left: 0;
</style>
</head>
<body>
<div id="offline">
<h3 data-i18n="Domoticz Offline">Domoticz Offline</h3>
</div>
</body>
</html>
Tarzan737
And i noticed that the value actually changed to 100 % in domoticz when i copy/pasted that line into browser, so it is updating
if i change value from 100 to 70 it is doing that as well into domoticz..
- Egregius
You can't use 127.0.0.1 on your computer of course.
Do you have authentication enabled?
What is you curl the url in a shell?
Tarzan737
sorry, ofcourse i used to have domoticz on same computer..
but if you mean if i have any website protection? no i don´t
Tarzan737
you mean like this?
- Screenshot (9).png (170.13 KiB) Viewed 3101 times
- Egregius
No. This command:
curl -s "url..."
curl -s "url..."
Tarzan737
i get this...
- Screenshot (10).png (133.17 KiB) Viewed 3088 times
Tarzan737
tried curl -I to...
- Screenshot (12).png (151.79 KiB) Viewed 3088 times
- Egregius
You need to place the url between quotes...
Also, please try google... He knows a lot
Tarzan737
ahh crap
sorry again...
anyway.. then i get status ok and title update device....
other words.. it works like that!!
- Egregius
Then it should also work from php.
Tarzan737
Propanly but it dont! Not with that code.
Everything seems to work, and when i use php
It reads correct value from tanklevel but it refuse to send it to domoticz.
- Egregius
Did you manage to get this working yet?
What did you do in the mean time?
Tarzan737
Nope, not with the PHP code.
I beg that you or someone else have the solution. It would be nice to have it in domoticz.
I don't know what I do wrong. Could it be something in settings in domoticz? But as I wrote before, it responds but not with PHP script
- Egregius
But you didn't do anything since my last post?
You didn't try stuff?
Check the url that is printed in the terminal window.
Use another small php script with this to verify:
or
and
<?php
$data=file_get_contents('http://192.168.0.12/tanklevl1');
$data=strafter($data,'</span><br>');
$data=strbefore($data,'%');
$idx=33;
$nvalue=0;
$svalue=$data;
$url='http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx='.$idx.'&nvalue='.$nvalue.'&svalue='.$svalue;
echo $url.PHP_EOL;
file_get_contents($url);
function strafter($string,$substring){
$pos=strpos($string,$substring);
if($pos===false)return $string;
else return(substr($string,$pos+strlen($substring)));
function strbefore($string,$substring){
else return(substr($string,0,$pos));
?>Use another small php script with this to verify:
<?php
file_get_contents('http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=33&nvalue=0&svalue=100);
<?php
file_get_contents('http://192.168.0.14:8080/json.htm?type=command¶m=udevice&idx=33&nvalue=0&svalue=100);
<?php
file_get_contents('the url that was printed with the first code');
Tarzan737
i have actually tried this before
and then i get error on line 2 instead...
<?php
?>- Attachments
- Screenshot (13).png (158.15 KiB) Viewed 3785 times
