Hi everyone ! I've read the entire topic, but i'm stuck with the "Error Connecting to Broadlink device..." message
2018-04-07 18:20:48.838 (Broadlink Mini 3) Initialized version 3.0.0, author 'zak45'
2018-04-07 18:20:48.841 (Broadlink Mini 3) Debug log level set to: 'true'.
2018-04-07 18:20:48.841 (Broadlink Mini 3) 'HardwareID':'8'
2018-04-07 18:20:48.841 (Broadlink Mini 3) 'HomeFolder':'/home/seb/domoticz/plugins/BroadlinkRM2/'
2018-04-07 18:20:48.841 (Broadlink Mini 3) 'Version':'3.0.0'
2018-04-07 18:20:48.841 (Broadlink Mini 3) 'Author':'zak45'
2018-04-07 18:20:48.841 (Broadlink Mini 3) 'Name':'Broadlink Mini 3'
2018-04-07 18:20:48.841 (Broadlink Mini 3) 'Address':'192.168.0.13'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'Port':'0'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'Key':'BroadlinkRM2'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'Mode1':'780f77006f9f'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'Mode2':'/home/seb/domoticz/plugins/BroadlinkRM2'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'Mode3':'yes'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'Mode4':'yes'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'Mode5':'9000'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'Mode6':'Debug'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'DomoticzVersion':'3.8944'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'DomoticzHash':'9df30fb0'
2018-04-07 18:20:48.842 (Broadlink Mini 3) 'DomoticzBuildTime':'2018-02-23 23:42:52'
2018-04-07 18:20:48.842 (Broadlink Mini 3) Device count: 4
2018-04-07 18:20:48.842 (Broadlink Mini 3) Device: 1 - ID: 42, Name: 'Broadlink Mini 3 - Command', nValue: 0, sValue: 'Off'
2018-04-07 18:20:48.842 (Broadlink Mini 3) Device ID: '42'
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device Name: 'Broadlink Mini 3 - Command'
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device nValue: 0
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device sValue: 'Off'
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device LastLevel: 0
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device: 2 - ID: 43, Name: 'Broadlink Mini 3 - Temp', nValue: 0, sValue: ''
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device ID: '43'
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device Name: 'Broadlink Mini 3 - Temp'
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device sValue: ''
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device: 254 - ID: 44, Name: 'Broadlink Mini 3 - Remote', nValue: 0, sValue: ''
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device ID: '44'
2018-04-07 18:20:48.843 (Broadlink Mini 3) Device Name: 'Broadlink Mini 3 - Remote'
2018-04-07 18:20:48.844 (Broadlink Mini 3) Device LastLevel: 0
2018-04-07 18:20:48.844 (Broadlink Mini 3) Device: 255 - ID: 45, Name: 'Broadlink Mini 3 - Import', nValue: 0, sValue: 'Off'
2018-04-07 18:20:48.844 (Broadlink Mini 3) Device ID: '45'
2018-04-07 18:20:48.844 (Broadlink Mini 3) Device Name: 'Broadlink Mini 3 - Import'
2018-04-07 18:20:48.844 (Broadlink Mini 3) Device nValue: 0
2018-04-07 18:20:48.844 (Broadlink Mini 3) Device sValue: 'Off'
2018-04-07 18:20:48.844 (Broadlink Mini 3) Connecting to: 192.168.0.13:780f77006f9f
2018-04-07 18:20:48.844 Error: (Broadlink Mini 3) Error Connecting to Broadlink device....
2018-04-07 18:20:48.845 (Broadlink Mini 3) Device Number begin to : 2
2018-04-07 18:20:48.845 (Broadlink Mini 3) Entering work loop.
2018-04-07 18:20:48.868 (Broadlink Mini 3) No ini file :/home/seb/domoticz/plugins/BroadlinkRM2/remote/plugin_remote_8.ini
2018-04-07 18:20:48.869 (Broadlink Mini 3) Custom Commands for Remote not managed
2018-04-07 18:20:48.869 (Broadlink Mini 3) Heartbeat interval set to: 30.
2018-04-07 18:20:58.388 (Broadlink Mini 3) Calling message handler 'onHeartbeat'.
2018-04-07 18:20:58.389 Error: (Broadlink Mini 3) Error Connecting to Broadlink device...
Domoticz runs on an Ubuntu server 17.10 with python 3.6, and I try to reach the RM mini 3.
I've installed the last version of plugin.py (v3), I've copied all the content of crypto, broadlink & pyaes in /usr/lib/python3.6/
The RM mini 3 is well seen by the e-control app on android, and from my other PC, with advanced IP scanner, I have the line :
"OK 192.168.0.13 192.168.0.13 NBS Payment Solutions Inc. 78:0F:77:00:6F:9F"
which corresponds to the rule I set in my dhcp server settings.
To be sure, I've run the discovery thing, and the IP and the MAC was well the ones above.
I don't understand why I still have this message...
P.S: @davidrq78 : yes, you have to go to /home/pi/domoticz/plugins/BroadlinkRM2, then type sudo chmod +x plugin_http.py
