Python Plugin: Broadlink RM2
zak45
- Domoticz version: V2024.4
old version, no more to be used
this is the second one (of 3) to share with you.
All information on the Wiki : http://www.domoticz.com/wiki/Plugins/BroadlinkRM2.html
kniazio
- Domoticz version: 3.7243
Re: Python Plugin: Broadlink RM2
I want to run the Broadlink plugin
It shows errors:
My hardware: Raspberry Pi3
My os OSMC
please help
It shows errors:
2017-03-28 07:40:31.847 Error: (BroadlinkRM2) failed to load 'plugin.py', Python Path used was '/home/osmc/domoticz/plugins/Broadlink/:/usr/lib/python3.4/:/usr/lib/python3.4/plat-arm-linux-gnueabihf:/usr/lib/python3.4/lib-dynload'.
2017-03-28 07:40:31.847 Error: (Broadlink) Module Import failed, exception: 'ImportError'
2017-03-28 07:40:31.847 Error: (Broadlink) Module Import failed: ' Name: broadlink'
2017-03-28 07:40:52.474 Hardware Monitor: Fetching data (System sensors)
2017-03-28 07:41:22.514 Hardware Monitor: Fetching data (System sensors)
2017-03-28 07:41:52.559 Hardware Monitor: Fetching data (System sensors)
2017-03-28 07:42:00.018 Error: Broadlink hardware (6) thread seems to have ended unexpectedly My os OSMC
please help
zak45
can you execute python, type these commands:
import os
import sys
print(sys.platform)
print(sys.path)
print(os.__file__)
and provide the result.
thanks
import os
import sys
print(sys.platform)
print(sys.path)
print(os.__file__)
thanks
kniazio
zak45 wrote:can you execute python, type these commands:
import os
import sys
print(sys.platform)
print(sys.path)
print(os.__file__)
thanks
root@osmc:~# python
Python 2.7.9 (default, Aug 13 2016, 17:56:53)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import os
>>> import sys
>>> print(sys.platform)
linux2
>>> print(sys.path)
['', '/usr/local/lib/python2.7/dist-packages/Adafruit_BMP-1.5.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/Adafruit_GPIO-1.0.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/spidev-3.2-py2.7-linux-armv7l.egg', '/usr/local/lib/python2.7/dist-packages/Adafruit_PureIO-0.2.0-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/setuptools-4.0.1-py2.7.egg', '/usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.3.0-py2.7-linux-armv7l.egg', '/usr/lib/python2.7', '/usr/lib/python2.7/plat-arm-linux-gnueabihf', '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload', '/usr/local/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages', '/usr/lib/python2.7/dist-packages/PILcompat', '/usr/lib/python2.7/dist-packages/gtk-2.0']
>>> print(os.__file__)
/usr/lib/python2.7/os.pyc
I do not know why he does not use it
- winscp python.jpg (194 KiB) Viewed 14921 times
zak45
Domoticz Python framework require 3.x version.
What you can try , on line 55 of the plugin.py file, add:
sys.path.append('/usr/local/lib/python3.4/dist-packages')
before
import broadlink
but first verify that /usr/local/lib/python3.4/dist-packages is the valid directory to used...
before
import broadlink
kniazio
/usr/local/lib/python3.4/dist-packages is emptyzak45 wrote:Domoticz Python framework require 3.x version.
before
import broadlink
Still the same mistakes
domoraspberryitaly
Hey all, first post hope everyone is doing well! Been trying the plugin. I noticed plugin.py needs a python version higher then 3.4 due to hex() call. Running raspberry pi.. If I could fix I would..
kniazio
I installed Python 3.5
Still the same
Still the same
domoraspberryitaly
Our issues are different, I think. Yours is a config issue re python, what I found is that the readily available python version 3.4 for raspberry is not compatible with the Python script of the plugin. I found at least the .hex() method not to be available until 3.5
zak45
@kniazio
don't know how your OS manage different python version.
What I have seen is that Domoticz Python framework is looking on : /usr/lib/python3.4
so... looks like this is the version required / find and that the plugin will use.
when you do : pip install broadlink (or any other command), this should install the module probably there:
maybe for you this go to python2.7 ??
@domoraspberryitaly
Welcome !!!
@domoraspberryitaly
Welcome !!!
kniazio
I have already done pip install broadlinkzak45 wrote:@kniazio
@domoraspberryitaly
Welcome !!!
Installed in python 2.7
deennoo
Whoa looks like perfect ! can we call you pluginator ?
Will try it on linux quickly and update my blog how-to on this device.
Just one question for a better integration, isn't possible to use learn switch from switch page ?
http://domo-attitude.fr
domoraspberryitaly
Python 2.7 on raspberry wont work due to the methods used in plugin.py (and maybe elsewhere) that require 3.5 as I wrote earlier.. I'll see if I can do some work on it to make it compatible.
deennoo
Just test on debian, Domoticz looks lib at
this mean you need to install python who is used for domoticz
When done, you have to copy lib on the good dir :
Then restart domoticz en enjoy !
@zak45 maybe you can update your wiki with this thank you for this great plugin !
when did you release the one for Orange Box ? ahrd to transforme to freebox revolution ?
/usr/local/lib/python3.4/dist-packages/Code: Select all
sudo apt-get install python3-pip libglib2.0-dev
sudo pip3 install Crypto
sudo pip3 install broadlinkCode: Select all
sudo cp -r /usr/local/lib/python3.4/dist-packages/Crypto/ /usr/lib/python3.4/
sudo cp -r /usr/local/lib/python3.4/dist-packages/broadlink /usr/lib/python3.4/
sudo service domoticz restartwhen did you release the one for Orange Box ? ahrd to transforme to freebox revolution ?
zak45
@deennoo
perfect!
will update the wiki.
perfect!
domoraspberryitaly
I hope I can get this to work as well will check now
Awesome plugin!
deennoo
Re: RE: Re: Python Plugin: Broadlink RM2
All credits too another Python plugin dev Zaraki673zak45 wrote:@deennoo
perfect!
http://easydomoticz.com/forum/viewtopic.php?t=3278
zak45
So... hummm.. not sure to understand :deennoo wrote:Whoa looks like perfect ! can we call you pluginator ?
deennoo
On linux version we have this button :
Learn or detection in french
deennoo
I'm facing an issue when trying to record an IR code
My config
2017-03-28 20:45:47.331 User: Admin initiated a switch command (3379/Broadlink - Command/Set Level)
2017-03-28 20:45:47.364 (Broadlink) Calling message handler 'onCommand'.
2017-03-28 20:45:47.364 (Broadlink) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2017-03-28 20:45:47.394 (Broadlink) Connected to Broadlink device.
2017-03-28 20:45:47.394 (Broadlink) All plugin system is on pause for 5s...
2017-03-28 20:45:47.394 (Broadlink) When Broadlink led is lit press the button on your remote within 5 seconds
2017-03-28 20:45:52.781 (Broadlink) b'&\x00\x84\x03\x11/\x13/\x12/\x13/\x11\x10\x11\x10\x11\x0f\x12/\x12\x00\x07[\x96\x91\x12\x0f\x11\x10\x11\x0f\x12\x0f\x110\x12/\x13\x0f\x10\x10\x11/\x13/\x12/\x120\x12\x0e\x12\x0f\x12\x0f\x12\x0e\x12\x92\x12\x0f\x11\x10\x11\x10\x11\x0f\x11\x10\x11\x10\x11\x0f\x11\x0f\x12/\x120\x12/\x12\x0f\x110\x12/\x110\x12/\x12\x10\x11\x0f\x12\x0f\x110\x12\x00\x07[\x96\x90\x13\x0f\x11\x0f\x12\x0f\x11\x10\x110\x12/\x12\x0f\x12\x0f\x110\x12/\x110\x12/\x13\x0f\x11\x0f\x12\x0f\x11\x0f\x12\x92\x12\x0f\x11\x10\x11\x0f\x12\x0f\x11\x0f\x12\x0f\x12\x0f\x11\x0f\x120\x11/\x120\x12\x0e\x120\x12/\x120\x110\x11\x0f\x12\x0f\x11\x10\x110\x12\x00\x07\\\x95\x91\x12\x0f\x12\x0f\x11\x10\x11\x0f\x11/\x120\x12\x0f\x11\x10\x110\x12/\x12/\x13.\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12\x91\x13\x0f\x11\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x11\x10\x11\x10\x11/\x120\x12.\x12\x0f\x12/\x13/\x12/\x120\x12\x0f\x11\x10\x11\x0f\x12.\x13\x00\x07[\x96\x91\x12\x0f\x11\x0f\x12\x0f\x12\x0f\x110\x12/\x12\x0f\x11\x10\x11/\x120\x12/\x120\x11\x10\x11\x0f\x12\x0f\x11\x10\x11\x92\x12\x0f\x11\x10\x11\x0e\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x12/\x120\x12/\x12\x0f\x12/\x12/\x12/\x12/\x13\x0f\x11\x0f\x12\x0f\x110\x12\x00\x07\\\x95\x90\x13\x0e\x12\x10\x11\x0f\x12\x0f\x110\x12/\x12\x10\x11\x0f\x11/\x120\x110\x12/\x13\x0f\x11\x0f\x12\x0f\x11\x10\x11\x92\x12\x0f\x11\x10\x11\x0f\x12\x0f\x11\x0f\x12\x10\x10\x10\x11\x0f\x110\x12/\x120\x12\x0f\x110\x12/\x120\x11/\x12\x10\x11\x0f\x11\x10\x110\x12\x00\x07\\\x94\x92\x12\x0f\x11\x0f\x12\x0f\x11\x10\x110\x12/\x12\x0f\x12\x0e\x120\x12/\x110\x12/\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x91\x12\x0f\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x12\x0f\x11\x10\x11/\x12/\x12/\x13\x0f\x110\x110\x12/\x13/\x12\x0f\x11\x10\x11\x0f\x110\x11\x00\x07]\x94\x92\x12\x0f\x11\x10\x11\x10\x11\x0f\x11/\x13/\x12\x0f\x11\x10\x11/\x13/\x12/\x120\x11\x10\x11\x0f\x11\x10\x11\x0f\x12\x91\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12/\x13/\x12/\x11\x10\x11/\x120\x12/\x120\x12\x0e\x12\x10\x11\x0f\x12/\x11\x00\x07\\\x95\x92\x12\x0e\x12\x0f\x12\x0f\x12\x0f\x110\x12/\x12\x0f\x11\x0f\x12/\x120\x12/\x12/\x13\x0f\x11\x0f\x12\x0f\x11\x10\x11\x92\x12\x0f\x11\x10\x11\x0f\x11\x10\x11\x0f\x11\x10\x11\x0f\x12\x0f\x110\x12/\x13/\x12\x0f\x110\x12/\x12/\x12/\x13\x0f\x11\x0f\x12\x0f\x110\x12\x00\x07\\\x95\x90\x12\x0f\x12\x0f\x12\x0f\x11\x10\x110\x12/\x12\x0f\x12\x0f\x110\x11/\x13/\x12/\x12\x10\x11\x0f\x11\x10\x11\x10\x11\x92\x12\x0e\x12\x0f\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12\x0f\x11\x10\x11/\x12/\x120\x12\x0f\x110\x12/\x120\x100\x12\x0f\x12\x0f\x11\x10\x110\x12\x00\x07\\\x95\x91\x12\x0f\x11\x10\x11\x10\x11\x0f\x11/\x13/\x12\x0f\x11\x0f\x120\x12/\x12/\x110\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12\x91\x12\x0f\x12\x0f\x12\x0f\x11\x0f\x12\x0f\x12\x0f\x11\x10\x11\x10\x11/\x13/\x11/\x13\x0f\x11/\x13/\x12/\x120\x12\x0f\x11\x10\x11\x0f\x11/\x12\x00\x07\\\x96\x91\x12\x0f\x11\x10\x11\x0f\x12\x0f\x110\x11/\x13\x0e\x12\x0f\x12/\x120\x12/\x13/\x12\x0f\x11\x10\x10\x10\x11\x0f\x11\x93\x11\x10\x11\x0f\x11\x10\x11\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x12/\x120\x110\x12\x0f\x12.\x120\x12/\x12/\x13\x0f\x11\x0f\x12\x0f\x110\x12\x00\r\x05\x00\x00\x00\x00'
2017-03-28 20:45:52.781 Error: (Broadlink) 'onCommand' failed 'AttributeError':''bytes' object has no attribute 'hex''.
2017-03-28 20:45:52.781 Error: (Broadlink) ----> Line 117 in /home/nico/domoticz/plugins/Broadlink/plugin.py, function onCommand
2017-03-28 20:45:52.781 Error: (Broadlink) ----> Line 339 in /home/nico/domoticz/plugins/Broadlink/plugin.py, function learn
2017-03-28 20:45:54.556 User: Admin initiated a switch command (3379/Broadlink - Command/Set Level)
2017-03-28 20:45:54.585 (Broadlink) Calling message handler 'onCommand'.
2017-03-28 20:45:54.585 (Broadlink) onCommand called for Unit 1: Parameter 'Set Level', Level: 10 , Connected : True
2017-03-28 20:45:54.615 (Broadlink) Connected to Broadlink device.
2017-03-28 20:45:54.615 (Broadlink) All plugin system is on pause for 5s...
2017-03-28 20:45:54.615 (Broadlink) When Broadlink led is lit press the button on your remote within 5 secondes
2017-03-28 20:45:59.855 (Broadlink) b'&\x00\xe0\x01\x95\x91\x13\x0e\x12\x0f\x10\x11\x10\x11\x101\x13-\x13\x0f\x10\x10\x110\x110\x13/\x13.\x13\x0e\x12\x0f\x10\x10\x12\x10\x11\x92\x11\x10\x11\x10\x11\x0f\x0e\x12\x10\x11\x10\x11\x10\x10\x10\x10\x120\x110\x13/\x13\x0e\x101\x100\x120\x101\x13\x0e\x10\x11\x11\x0f\x120\x11\x00\x07\\\x96\x90\x12\x0f\x12\x0f\x11\x10\x10\x10\x110\x13/\x12\x0f\x11\x10\x100\x12/\x13/\x110\x12\x0f\x11\x10\x10\x11\x10\x10\x12\x91\x13\x0f\x10\x10\x11\x10\x11\x0f\x12\x0f\x12\x0f\x11\x10\x11\x0e\x120\x12/\x12/\x13\x0f\x110\x12/\x12.\x13/\x12\x0f\x11\x0f\x12\x10\x11/\x13\x00\x07[\x95\x92\x11\x0f\x12\x0e\x12\x10\x11\x0f\x110\x13/\x12\x0f\x11\x10\x11/\x13/\x11/\x13/\x12\x0f\x11\x10\x11\x0f\x12\x0f\x11\x92\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x11\x0f\x12\x0f\x12\x0f\x12/\x110\x12/\x13\x0e\x12/\x120\x12/\x12/\x12\x10\x11\x0e\x12\x0f\x12/\x12\x00\x07\\\x95\x92\x11\x0f\x12\x10\x11\x0f\x11\x10\x11/\x12/\x12\x10\x11\x0f\x12/\x13/\x12/\x12/\x11\x11\x11\x0f\x11\x0f\x11\x10\x11\x92\x12\x0f\x11\x10\x11\x10\x11\x0f\x12\x0f\x11\x10\x11\x0f\x12\x0f\x110\x12/\x13/\x11\x0f\x110\x12/\x13/\x12/\x12\x10\x11\x0f\x11\x0f\x120\x11\x00\x07\\\x95\x91\x13\x0f\x11\x0f\x12\x0f\x11\x10\x11/\x13/\x11\x10\x11\x0f\x110\x12/\x13/\x12/\x13\x0e\x12\x0f\x11\x10\x11\x10\x10\x92\x12\x10\x11\x0f\x12\x0f\x11\x10\x11\x0e\x12\x0f\x12\x0f\x11\x10\x110\x12/\x12/\x13\x0e\x120\x11/\x120\x110\x12\x0f\x12\x0f\x11\x10\x11/\x13\x00\x07\\\x94\x91\x12\x0f\x12\x0f\x11\x10\x11\x0f\x12/\x13/\x12\x0e\x12\x10\x11/\x12/\x12/\x13/\x12\x0f\x11\x10\x11\x10\x11\x0f\x11\x92\x12\x0f\x12\x0f\x11\x10\x11\x10\x11\x0f\x12\x0f\x11\x10\x11\x0f\x11/\x120\x12/\x13\x0e\x12/\x120\x12/\x110\x12\x0e\x12\x10\x11\x0f\x12/\x13\x00\r\x05\x101\x100\x120\x101'
2017-03-28 20:45:59.855 Error: (Broadlink) 'onCommand' failed 'AttributeError':''bytes' object has no attribute 'hex''.
2017-03-28 20:45:59.855 Error: (Broadlink) ----> Line 117 in /home/nico/domoticz/plugins/Broadlink/plugin.py, function onCommand
2017-03-28 20:45:59.855 Error: (Broadlink) ----> Line 339 in /home/nico/domoticz/plugins/Broadlink/plugin.py, function learn
