Pass2PHP
Egregius
Domoticz version: v2024.7
Re: Pass2PHP
Post by Egregius »
Lol, seems I have superfast disks :lol:
sincze
Domoticz version: 2024.4
Re: Pass2PHP
Post by sincze »
A well, because we now can :D read the usage of a Unifi AP-AC-LR :D
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
gimic
Domoticz version: 3.66
Re: Pass2PHP
Post by gimic »
Is it normal that when no events ocure that the _cron60.php is not executed every 60 seconds? or am i missing something?
Tnx
Egregius
Re: Pass2PHP
Post by Egregius »
If you don't trigger the script by cron yes. If you have lot's of devices it gets triggered automatically.
I shall post my cron script tomorrow, or it could be on github.
gimic
Re: Pass2PHP
Post by gimic »
ok, tnx there is a cron.sh file on git but i don't think that that is the file i need.
Egregius
Re: Pass2PHP
Post by Egregius »
That's the one ;)
https://github.com/Egregius/LUA-Pass2PH ... re/cron.sh
You can adjust the sleeps in it and remove lines as needed.
Add it to cron with sudo crontab -e
* * * * * /path/to/script/cron.sh
The script will also check if domoticz is still online and reboot if needed.
gimic
Re: Pass2PHP
Post by gimic »
Works, needed also jq package installed ;-)
Egregius
Re: Pass2PHP
Post by Egregius »
Great!
Enjoy pass2php ;)
gimic
Re: Pass2PHP
Post by gimic »
Do you have an example or an idea how i can create a button with following function
First time pressed: change status of blinds to ON
Second time pressed: change status of blinds to Stop
Third time pressed: change status of blinds to Off
Fourth time pressed: change status of blinds to Stop
Fifth time pressed: change status of blinds to On
etc...
how can i remember in php the blinds two steps in history so i know if it is stopped i need to do On or Off the next time it is activated?
Egregius
Re: Pass2PHP
Post by Egregius »
You want ON - STOP - OFF - STOP - ON - STOP - OFF - ...?
No matter what the current status of the blinds is?
And it's a button that acts independently from the blinds? I mean, without script the blinds don't respond to the button?
gimic
Re: Pass2PHP
Post by gimic »
yes ON - STOP - OFF - STOP - ON - STOP - OFF - ...?
the stop would only be needed the time it takes to get the blinds up or down, but maybe that i can figure out myself, the main problem is how do i know when i have status Stop, the next push will be On or Off?
The last question i don't understand.
Egregius
Re: Pass2PHP
Post by Egregius »
I think I would do something like this:
<?php
if($status=='On'){
	$pushbutton=apcu_fetch('pushbutton');
	if($pushbutton=='on'){
		//do stop action
		apcu_store('pushbutton','onstop');
	}elseif($pushbutton=='onstop'){
		//do off action
		apcu_store('pushbutton','off');
	}elseif($pushbutton=='off'){
		//do stop action
		apcu_store('pushbutton','offstop');
	}elseif($pushbutton=='offstop'){
		//do on action
		apcu_store('pushbutton','on');
Use a cache where you set the last action, write that cache after each action with another value. I used onstop and offstop so you know wich stop action it was.
gimic
Re: Pass2PHP
Post by gimic »
Tnx, since i don't know php (yet) i did not know the function to store variables the last in memory. i'l try it next week!
poudenes
Domoticz version: 3.8993
Re: Pass2PHP
Post by poudenes »
Hi all, I use the latest beta of domoticz 4. Consider to use pass2php but don't know if this will still make difference in speed. Can someone tell me?
Verzonden vanaf mijn iPhone met Tapatalk Pro
sincze
Re: Pass2PHP
Post by sincze »
poudenes wrote: Sunday 29 July 2018 9:45 Hi all, I use the latest beta of domoticz 4. Consider to use pass2php but don't know if this will still make difference in speed. Can someone tell me?
I believe by default script/event handling is still the same in Domoticz 4.
So speed updates and more complicated calculations can only be made with DzVents and Pass2PHP.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
poudenes
Re: Pass2PHP
Post by poudenes »
sincze wrote: Sunday 29 July 2018 9:59
I give it a try :) Always good to try new things to make it better.
1 question. I cannot find ee5_base64.lua in /domoticz/var/scripts/lua/
Egregius
Re: Pass2PHP
Post by Egregius »
You don’t need base64 anymore to use pass2php.
commentator
Re: Pass2PHP
Post by commentator »
tried Pass2PHP yesterday
and now the apache error log is filled with
[Sat Aug 11 00:01:25.002212 2018] [:error] [pid 7648] [client 127.0.0.1:39048] PHP Parse error:  syntax error, unexpected 'time' (T_STRING), expecting ',' or ')' in /var/www/html/secure/pass2php.php on line 45
on this line I see
 apcu_store('cron120'time());
which is strange because on al other itmes there is a , between cronxx and time. Ot isn't that the problem?
sincze
Re: Pass2PHP
Post by sincze »
what happens if you just add the , in between? I indeed would think that is the issue.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: Pass2PHP
Post by Egregius »
I forgot about this reply. Indeed, there needs to be a, in it.
apcu_store('cron120',time());
