Blockly & Varíable does not work
Joerg99
Post by Joerg99 »
I have the following problem, I have written the blockly shown below but it does not work. It switches once when I change the variable but it does not automatically turn on. The internal temperature I have entered via a virtual dummy he is visible and displays correctly in Domoticz. does anyone know a solution?
EricT
Domoticz version: 3.9440
Re: Blockly & Varíable does not work
Post by EricT »
I don't know much about Blockly but I think you are missing something to trigger that script. Maybe adding a time or a switch to the script may solve your problem.
E.g
if time is 9 AM and temp < 20 then turn on heating
or
if switch is On and temp < 20 then turn on heating
if it was easy everybody would do it
Joerg99
Post by Joerg99 »
Thanks, I'll try that and get in touch
tozzke
Domoticz version: Stable
Post by tozzke »
Did you change your Blockly Event type to UserVariable?
Joerg99
Post by Joerg99 »
E.g
or
Thanks that was exactly the right idea !!!
it works perfect !!
Thank you so much EricT !!
EricT
Post by EricT »
I am glad to be able to help. :)
