MyDomoticz - Testers wanted!
chimit
Domoticz version: master
Re: MyDomoticz - Testers wanted!
Post by chimit »
Good day vivatauro,
First of all, thank you for your donation.
Secondly, what do your local Domoticz log files say about connecting to MyDomoticz?
Regards,
Rene Kluwen
vivatauro wrote: Tuesday 01 May 2018 0:10 Hi chimit:
I registered in mydomoticz and I was able to see my dashboard, but now it seems not. what I see in mydomoticz.com is the user incon in red color. Before that I was able to see it in green.
If I go to my domain (vivatauro.mydomoticz.com) I get an empty screen saying "Server Offline"
Is the server down or I did something wrong?
By the way, you got a donation from me too.
Thanks in advance for your help on this
cnr437
Post by cnr437 »
can you share mydomoticz source code?
chimit
Post by chimit »
At this moment there are no plans to open source the mydomoticz source code.
It's available though under a commercial license. Inquiries via pm.
cnr437 wrote: Tuesday 01 May 2018 13:51 can you share mydomoticz source code?
cnr437
Post by cnr437 »
I cant compose pm, because of newbie at this forum, can you inform me about licensing procedure,
chimit wrote: Tuesday 01 May 2018 14:02 At this moment there are no plans to open source the mydomoticz source code.
chimit
Post by chimit »
You can e-mail us at [email protected] about this.
cnr437 wrote: Tuesday 01 May 2018 14:07 I cant compose pm, because of newbie at this forum, can you inform me about licensing procedure,
vivatauro
Post by vivatauro »
chimit wrote: Tuesday 01 May 2018 10:13 Good day vivatauro,
Regards,
Rene Kluwen
Hi chimit.
I disconnected from mydomoticz since it was crashing my domoticz. I cannot even now access to thr mydomoticz page now. Is there still any issues?
Let me know if you want me to re-test.
Cheers
Sergio
mitko67
Post by mitko67 »
Hello everybody!
I already have a third day no access to https://my.domoticz.com and https://my_name.mydomoticz.com is also unavailable. Is there a problem with the server?
chimit
Post by chimit »
Hi, sorry. MyDomoticz did need to be kicked.
Apologies for the inconvenience.
== Rene
mitko67 wrote: Thursday 03 May 2018 19:58 Hello everybody!
mitko67
Post by mitko67 »
chimit wrote: Thursday 03 May 2018 21:38 Hi, sorry. MyDomoticz did need to be kicked.
== Rene
Thank you!!! Already everything works!
zaakal
Post by zaakal »
zaakal wrote: Tuesday 24 April 2018 14:00
jaha wrote: Friday 06 April 2018 10:34 Oh one more "bug"
Just changed the name of my domoticz on my.domoticz.com proxy and after that just blank dashboard.
I have exact same problem.
If i go directly http://my.domoticz.com/my/ "MyDomoticz Instance ID" - it works but dashboard is empty.
I still have empty dashboard.
2018-05-07 13:15:04.847 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
chimit
Post by chimit »
One question: Are you using any special characters in your description?
zaakal wrote: Monday 07 May 2018 14:57
zaakal
Post by zaakal »
Do you mean Device names or Domoticz name?
In device names i use some .
chimit wrote: Monday 07 May 2018 15:29 One question: Are you using any special characters in your description?
chimit
Post by chimit »
I meant Domoticz name.
I suppose the device names with special characters used to work before the name change?
zaakal wrote: Monday 07 May 2018 18:17 Do you mean Device names or Domoticz name?
zaakal
Post by zaakal »
In this unit i copied the error I have not used special charaters.
In another unit i may have used it. It is in remote location and i dont remember its web login so i have to check it at place.
Is it possible that beacuse of first unit the second one is giving error?
Now i have posted enough posts in forum so if u prefer I can PM afterwards. :D
chimit wrote: Monday 07 May 2018 19:04 I meant Domoticz name.
Nautilus
Post by Nautilus »
Nautilus wrote: Wednesday 25 April 2018 20:23
chimit wrote: Wednesday 25 April 2018 12:49 One reason can be that you have two Domoticz instances.
It's possible that they have an identical apikey, when a backup from the first is transferred to the second at some point.
Another reason can be a network hitch. When you domoticz notices a disconnect it tries to connect again.
But if meanwhile MyDomoticz didn't notice the disconnect yet, it thinks your instance tries to connect multiple times at once.
Thanks for the reply. I only have one Domoticz instance and this issue has been there for a while. I was last able to use the service on March 13th (i.e. over a month ago) and since then it has shown "red" on my.domoticz. If I disable/enable the service in Domoticz I get the mentioned errors. So it is not at least any temporary network glitch. Not sure what else I could try?
I ended up removing the instance and creating a new. It worked for a while but now I'm getting the same error message again. Not much have changed, still only one Domoticz instance running and network working in a normal manner....
Slokoavac
Domoticz version: 3.8153
Post by Slokoavac »
I have same issue. What is worse. I have tried to delete instance, but it says it is online, although i turned off raspi with that domoticz. I have deleted name field and user pass, now i can not even access menu to try to delete instance. I have donated few euros, but this system seems to be deeply broken :(
can mydomoticz admin PM me so i can send him instance ID so it can be removed on server side? Otherwise i am stuck with this no name fake online instance i can't remove.
Pi 2 (raspbian stretch) w. Conrad VOC USB, Xiaomi PM 2.5 detector , Xiaomi/Philips bulbs, Mi Flora BT, Xiaomi GW (w. temp/humidity/pir)
Pi Zero W (raspbian stretch) w. - Xiaomi GW (temp/hum/door)
tgg3
Domoticz version: 4.9700
Post by tgg3 »
I'm getting a "Oops!!" message when I try to start my instance. What should I do?
Version: 3.9459
Platform: Raspberry Pi 3 B+ (Stretch)
Plugin/Hardware: MySensors 2.2.0 with a Serial Gateway
Tom
Slokoavac
Post by Slokoavac »
@chmit
this is definetly UI bug. If i delete name of instance in mydomoticz, i can not edit it anymore since the name was the link to edit. Can you please delete instance that is stuck and fix this UI bug? :)
thanks!
zaakal
Post by zaakal »
So checked all units - no special characters.
Still empty dashboard.
And if i make new account everything works....... but account i donated doesnt work.
zaakal wrote: Monday 07 May 2018 20:49 In this unit i copied the error I have not used special charaters.
chimit
Post by chimit »
PM me your API KEY so I can transfer the donation to the new account.
== Rene
zaakal wrote: Tuesday 29 May 2018 7:42 So checked all units - no special characters.
