First of all, thank you for your donation.
Secondly, what do your local Domoticz log files say about connecting to MyDomoticz?
Regards,
Rene Kluwen
vivatauro wrote: Tuesday 01 May 2018 0:10
Hi chimit:
I registered in mydomoticz and I was able to see my dashboard, but now it seems not. what I see in mydomoticz.com is the user incon in red color. Before that I was able to see it in green.
If I go to my domain (vivatauro.mydomoticz.com) I get an empty screen saying "Server Offline"
Is the server down or I did something wrong?
I cant compose pm, because of newbie at this forum, can you inform me about licensing procedure,
chimit wrote: Tuesday 01 May 2018 14:02
At this moment there are no plans to open source the mydomoticz source code.
It's available though under a commercial license. Inquiries via pm.
cnr437 wrote: Tuesday 01 May 2018 13:51
can you share mydomoticz source code?
cnr437 wrote: Tuesday 01 May 2018 14:07
chimit wrote: Tuesday 01 May 2018 10:13
Good day vivatauro,
Regards,
Rene Kluwen
Hi chimit:
By the way, you got a donation from me too.
Thanks in advance for your help on this
Hi chimit.
I disconnected from mydomoticz since it was crashing my domoticz. I cannot even now access to thr mydomoticz page now. Is there still any issues?
Let me know if you want me to re-test.
Hello everybody!
I already have a third day no access to https://my.domoticz.com and https://my_name.mydomoticz.com is also unavailable. Is there a problem with the server?
Hi, sorry. MyDomoticz did need to be kicked.
Apologies for the inconvenience.
== Rene
mitko67 wrote: Thursday 03 May 2018 19:58
Hello everybody!
chimit wrote: Thursday 03 May 2018 21:38
== Rene
Hello everybody!
I meant Domoticz name.
I suppose the device names with special characters used to work before the name change?
zaakal wrote: Monday 07 May 2018 18:17
Do you mean Device names or Domoticz name?
In device names i use some .
chimit wrote: Monday 07 May 2018 15:29
One question: Are you using any special characters in your description?
zaakal wrote: Monday 07 May 2018 14:57
I still have empty dashboard.
2018-05-07 13:15:04.847 Error: PROXY: Read failed, code = 335544539. Reconnecting: short read
In this unit i copied the error I have not used special charaters.
In another unit i may have used it. It is in remote location and i dont remember its web login so i have to check it at place.
Is it possible that beacuse of first unit the second one is giving error?
Now i have posted enough posts in forum so if u prefer I can PM afterwards.
chimit wrote: Monday 07 May 2018 19:04
chimit wrote: Wednesday 25 April 2018 12:49
One reason can be that you have two Domoticz instances.
It's possible that they have an identical apikey, when a backup from the first is transferred to the second at some point.
Another reason can be a network hitch. When you domoticz notices a disconnect it tries to connect again.
But if meanwhile MyDomoticz didn't notice the disconnect yet, it thinks your instance tries to connect multiple times at once.
Thanks for the reply. I only have one Domoticz instance and this issue has been there for a while. I was last able to use the service on March 13th (i.e. over a month ago) and since then it has shown "red" on my.domoticz. If I disable/enable the service in Domoticz I get the mentioned errors. So it is not at least any temporary network glitch. Not sure what else I could try?
I ended up removing the instance and creating a new. It worked for a while but now I'm getting the same error message again. Not much have changed, still only one Domoticz instance running and network working in a normal manner....
I have same issue. What is worse. I have tried to delete instance, but it says it is online, although i turned off raspi with that domoticz. I have deleted name field and user pass, now i can not even access menu to try to delete instance. I have donated few euros, but this system seems to be deeply broken
can mydomoticz admin PM me so i can send him instance ID so it can be removed on server side? Otherwise i am stuck with this no name fake online instance i can't remove.
Pi 2 (raspbian stretch) w. Conrad VOC USB, Xiaomi PM 2.5 detector , Xiaomi/Philips bulbs, Mi Flora BT, Xiaomi GW (w. temp/humidity/pir)
Pi Zero W (raspbian stretch) w. - Xiaomi GW (temp/hum/door)
this is definetly UI bug. If i delete name of instance in mydomoticz, i can not edit it anymore since the name was the link to edit. Can you please delete instance that is stuck and fix this UI bug?
thanks!
So checked all units - no special characters.
Still empty dashboard.
And if i make new account everything works....... but account i donated doesnt work.
zaakal wrote: Monday 07 May 2018 20:49
PM me your API KEY so I can transfer the donation to the new account.
== Rene
zaakal wrote: Tuesday 29 May 2018 7:42
