One thing I've noticed with the non zero line Aqara switches I have is that they all work fine but they will not switch properly using a slave device.
I have a set of Homeeasy wireless switches I use as a master control panel. When I assign one of these as a slave device to the Xiaomi Aqara Switch I get the following behaviour -
Switching the Homeeasy switch on appears to switch the Aqara Switch on in Domoticz - i.e. the status changes on the Switches screen to On but the Aqara switch does not physically switch on (i.e. the relay does not switch)
If I switch the Xiaomi Aqara Switch it does, obviously, switch on and it does update the slave Homeeasy switch in Domoticz.
- Domoticz version: 3.8153
Hi, I have a problem with Domoticz.
I have installed Domoticz in a NAS4Free jail and although I was able to add the gateway and sensors, its status is not updated.
When I start Domoticz, it gives me the following error:
XiaomiGateway: Could not detect local IP address: connect: Can not assign requested address
The similar problem was at zorroar, but on NAS4Free.
How can I solve the problem?
Hi.
I have Domoticz working in conjunction with Xiaomi Gateway v2.
Recently, after updating the beta version, Domoticz has stopped adjusting the brightness and color of the gateway.
On the switches tab, nothing happens when trying to adjust the color and brightness of the gateway.
Also no longer responds to commands from Lua.
commandArray['OpenURL']="root:[email protected]:8080/json.htm?type=command& param=setcolbrightnessvalue&idx=1&hue=360&brightness=10&iswhite=false"
Maybe it's just me or do you have the same problems?
- sincze
- Domoticz version: 2024.4
Any error messages in the log?OlegT1234 wrote: ↑Friday 30 March 2018 11:28 Hi.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
It worked when a command specified a specific IP server and removed root:root.
commandArray ['OpenURL'] = "192.168.1.100:8080/json.htm?type=command& param = setcolbrightnessvalue & idx = 1 & hue = 360 & brightness = 10 & iswhite = false"
Its propablly because od latest RGB bulb code changes in hwtypes, same as dzvents problems...OlegT1234 wrote: ↑Friday 30 March 2018 11:28 Hi.
- Domoticz version: 2024.3
I use :
ON (purple): http://IP:PORT/json.htm?type=command¶m=setcolbrightnessvalue&idx=IDX&hex=27024E&brightness=100&iswhite=false
OFF: http://IP:PORT/json.htm?type=command¶m=setcolbrightnessvalue&idx=IDX&hex=27024E&brightness=0&iswhite=false
Do not forget to set your IDX...
Raspberry / ESP Boards / Relais / Milight / Hue / OTGW / P1 / Xiaomi / RFXCom / RFLink / ZWave / Conbee II / Z2M / MQTT / A lot of scripts and many more..
Software: Linux, Android and Windows
Since few updates (curently 3.9185) I have a problem seeing the history of sensors (movement, window/door, temperature, humidity) when clicking them on a floorplan.
When I get to switches menu and then click LOG on one of these sensors evething works fine but when I click them on the Floorplan there is only a black screen ...
I am on 3.8337 beta, however I can not see the Aquara Water Leak Sensor, do I need a newer beta?
- sincze
I know 3.8805 and 3.8875 definitely work as I''ve one working here.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
hello.
Anyone know if I can block the xiaomi devices that they cant connect to xiaomi servers?
Now I can see the sensor however it is recognized as a smoke sensor. What did I do wrong?
Did you get this working with a trigger?schlabbe wrote: ↑Thursday 04 January 2018 9:44Hi,grunkan wrote: ↑Friday 29 December 2017 20:29 Hi,
I just got a couple of Honeywell Smoke Detectors in the mail. They where super easy to add to Domoticz! But I have a problem. I can't trigger the alarm sound from Domoticz. Is it even possible to do this? My plan was to link them together to make them turn on the alarm if any of them detect smoke and I wanted to use them as "sirens" in my home alarm.
Is this a dead end?
I have the same question.
I would like to implement the Smoke Detectors in the alarm system.
But turning the Detector "on" doesn't have an effect.
Anybody who got this working?
Thank you very much in advance
Apparently there's now a working plugin working for Zigate: https://www.domoticz.com/wiki/Zigate
Anyone tried it?
Anyone tried it?
Hello, can you tell me how you block the gateway?,
You block all the gateway, not a port or protocol?
thanks
- marcotini
Hi, I just noticed that the temperature sensor is not automatically update anymore since the last update. Why?
Here the screenshot https://imgur.com/YchoQGU
