I tried to access domoticz via https using the 443 port.
So https://ip-adres:443
But I receive an error: ' deze site kan geen beveiligde verbinding leveren'
' **.**.**.**. Heeft een ongeldige reactie verzonden'
I searched the forum and wiki, but in can not find the answer.
Somebody any clue what to try.
Greets Gijs
Err_ssl_protocol_error
domogijs
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
- jvdz
- Domoticz version: 4.107
Re: Err_ssl_protocol_error
What do you have in the startup config for domoticz?
The config file for domoticz on Raspberry is: /etc/init.d/domoticz.sh
Look for the initial lines containing DAEMON_ARGS=
Jos
Jos
domogijs
Sorry took some time to find out what to do (noob alert). I did 'cat domoticz.sh'
I see the 443 port. See attachment. What am I doing wrong?
Greets Gijs
Greets Gijs
- Domotica.sh
- IMG-20180425-WA0006.jpg (178.89 KiB) Viewed 1840 times
domogijs
I think I located the problem; I use a pi hole. The ssl seems to be blocked. Somebody experience with pi hole ivm domoticz 443 port?
Greets Gijs
Greets Gijs
geraldmuller
The error message ERR_SSL_PROTOCOL_ERROR error indicates that the browser is not able to initiate the secured communication at the moment. It's almost impossible to pin it down to a single cause, it could be almost anything. There is no definite guide for managing this error. However, there are few changes or settings which help you to get rid you of this error.
Configure Correct Date and Time
Clear Browsing Data
Clear Your SSL State
Disable QUIC Protocol of Chrome
Disable your Internet Browser Extensions
Adjust Your Internet Security and Privacy Level
Remove your system's hosts file
Check Your Antivirus Settings
Check Your Firewall
Clear Browsing Data
Check Your Firewall
