Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
alvi72 wrote: Tuesday 24 April 2018 22:47 he, it was not mend as an insult. I was just asking what i could try so that you don't have to spend time on my problem as i actually really appreciate all the time that is spend on these opensource environments.
But forget I asked It seems I am getting mixed result when accessing from the internet so the problem is elsewhere. Thanks for the help
It's ok - no insult taken :) It was more that I did respond to your mail in less than an hour!
mantoz
Domoticz version: 2024.7
Post by mantoz »
I did some more tests with Controlicz and I'm very happy with it. Using Italian.
Only strange things I noticed:
1. blinds appear to be inverted. In domoticz they're set as "Blinds percentage" and icons (open/closed) are correct. In Controlicz/Google home they appear to be inverted, as I have to say "switch off the blinds" to open them and vice versa. I could invert them in Domoticz, but then I'd have the wrong icons in domoticz (open when they're really closed and so on). Any workaround available?
2. related to 1. --> In Italian we usually say "Open blinds" and "Close blinds" instead of "Switch on/off the blinds" (translated, of course). This does not work. I assume that this is a Google Home bug, and/or is due to Google Home thinking that my blinds are really switches.
Can you confirm this please?
Thanks,
mantoz
Madgeni
Post by Madgeni »
Hi all - the new Controlicz site is now live. The main addition is that it will now show your devices on your profile, importantly, it will tell you how Google/Alexa will see them.
More features to come - feedback welcome (and yes I know the Test is still not giving feedback!)
gijsje
Domoticz version: Stable
Post by gijsje »
Very nice and good looking
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
mantoz
Post by mantoz »
Wow, what an improvement!!! Really nice site, congratulations!
The table is very useful!
mantoz
Madgeni
Post by Madgeni »
One of the forum users (Mayank) has done an amazing job helping me with it :)
sincze
Domoticz version: 2024.4
Post by sincze »
Madgeni wrote: Wednesday 18 April 2018 15:33 you can change this via https://www.controlicz.com/forgot
mmm. somethings wrong here :lol:
Error: Failed to lookup view "error" in views directory "/opt/bitnami/apps/Controlicz/views"
   at EventEmitter.render (/opt/bitnami/apps/Controlicz/node_modules/express/lib/application.js:579:17)
   at ServerResponse.render (/opt/bitnami/apps/Controlicz/node_modules/express/lib/response.js:960:7)
   at /opt/bitnami/apps/Controlicz/app.js:93:9
   at Layer.handle_error (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/layer.js:71:5)
   at trim_prefix (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:310:13)
   at /opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:280:7
   at Function.process_params (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:330:12)
   at IncomingMessage.next (/opt/bitnami/apps/Controlicz/node_modules/express/lib/router/index.js:271:10)
   at done (/opt/bitnami/apps/Controlicz/node_modules/express/lib/response.js:955:25)
   at EventEmitter.render (/opt/bitnami/apps/Controlicz/node_modules/express/lib/application.js:581:14)
   at /opt/bitnami/apps/Controlicz/app.js:80:13
unfortunately unable to reset my password.
After pressing the reset link... I receive the nice error mentioned above,
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Akerboom
Post by Akerboom »
Awesome work on the new site!
Had to hack my own login by enterin in the browser console:
document.getElementsByTagName('form')[0].submit();
because my username doesn't include a @ warming I got.
New users all have a email address as login I suppose...
Now I see two of my devices as: 'Color Switch' where the 'Google/Alexa' column is empty. The devices where I mentioned earlier:
Akerboom wrote: Saturday 21 April 2018 9:59 @Madgeni: I added my MiLights as On/Off devices instead of Dimmers (because I don't use the dimmer functions). But if I do that, they are not synced. Is this a feature?
Is this as expected?
b.t.w. test connection doesn't give any result a.t.m. (although my connection is setup and working fine)
[edit] connection test is visible in my domoticz-log though[/edit]
sincze
Post by sincze »
Akerboom wrote: Thursday 26 April 2018 21:50
Haha mine also seems NOT to have the @ .... however your trick did not work for me unforunately.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Madgeni
Post by Madgeni »
sincze wrote: Thursday 26 April 2018 21:45
This is fixed now :)
Madgeni
Post by Madgeni »
anyone who doesn't have an email as their username (why not, it was the original requirement!) PM me, and i'll delete your Controlicz account, so you can recreate it :)
sincze
Post by sincze »
Mmm
Devices available in multiple domoticz roomplans, check
Setup of controlicz, check
Devices available in controlicz, check
Google Home App connected to controlicz, check
Devices appear in google home app, check
Devices (nickname given) and added to a room in google home, check.
WhatsApp Image 2018-04-27 at 11.15.26.jpeg (31.27 KiB) Viewed 2517 times
"Hey Google, turn the light on in the Bathroom".
-> "Sorry I don't understand".
Some pointers in the right directions from the forum experts please :lol: to get it up and running.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Pisellon1
Post by Pisellon1 »
Hello everyone, i'm trying to set it up.
Https from internet is ok. My account is registred on the portal, please could the admin confirm this? (search: **falsini@me***), i've added a "controlicz" user in my domo system and everything seams ok.
In my google home i add the Controlicz, ask for user/password and permission, i allow everything but after some seconds google assistant doesn't show any Controlicz device and neither in the portal i can see my devices.
Could someone help? Thank you very much, i love this project!
sincze
Post by sincze »
Pisellon1 wrote: Friday 27 April 2018 11:43 Hello everyone, i'm trying to set it up.
Question:
Did you add devices to a roomplan so controlicz can find the devices??
Did you add the devices to the controlics user (Set Devices).
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Madgeni
Post by Madgeni »
sincze wrote: Friday 27 April 2018 11:20 Mmm
Is your Google Home app running as UK English? Can you do this via Google Assistant on your phone - i.e can you type it, as it's clearly not understanding what you've asked for.
if the devices are showing in GH, then Controlicz itself is working and ready
Madgeni
Post by Madgeni »
sincze wrote: Friday 27 April 2018 13:41
Question:
You had two accounts in Controlicz - please use the one starting with lowercase 'o' - It seems to be working ok.
sincze
Post by sincze »
Madgeni wrote: Friday 27 April 2018 15:06
It shows English but as you can see some part is in Dutch so that could be something.
It seems to understand my voice and sentence.. And for the temperature part the error message is different.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Pisellon1
Post by Pisellon1 »
Question:
Yes, problem was roomplan.
Now fixed.
Thank you
sincze
Post by sincze »
Question:
Now fixed.
Thank you
Excellent :D you got it up and running earlier than I did haha.
The answer of google: "Sorry I don't understand'.
And it shows exactly the thing I asked. Totally clueless here. :shock:
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Post by sincze »
I will answer my own post ;-).
What I did with the google home was.
- Press the mute/mic button until I had a full reset.
- After that I just reconfigured the google home with the google home app.
- Controlicz started to work instantly.
Seems the problem is solved. Just a little hint for future reference.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
