Re: http address not reachable
- Domoticz version: 2021.1
Maybe u should do name:pasword@ipadres:port
- Domoticz version: Custom
Port 8080 is not https but plain http
- Domoticz version: 2020.2
Re: http adres niet bereikbaar
what you are trying to do is request an https page over the http port, you should try https://<yourip>:443 that should work.
or just http://<yourip>:8080
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
- Domoticz version: 4.9700
Re:http address not reachable
If you try to browse to domoticz using the same device as it is installed on, you have to go to: http://127.0.0.1:8080 or https://127.0.0.1:443 or use http://localhost:8080, etc.
- Domoticz version: v4.10717
Have here the same problem. whatever I try none of the suggestions are working. software is last update.
Activate the domoticz LOG file and check what's happen, first as it should work immediatly, so first reason is that executable file is not running and/or has crashed.
_____________________________________
Pascal
Pascal
- FireWizard
Move to you domoticz folder.
and check your domoticz.sh file
and look if
If not, edit this file, so that the ports are inserted.
cd ~/domoticz
more domoticz.sh
are present.DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
problem is solved. Missing two weeks data.
1. disconnected Pi from the meter
2. reboted Pi
3. run update of software
4. Reconnected pi to meter
5. reboot
and..................................
It works, can not find why it stopped working two weeks ago.
Only change was installing a connexoon box (somfy) for control of sun screens.
2. reboted Pi
5. reboot
