Re: http address not reachable
edwin1234
Domoticz version: 2021.1
Post by edwin1234 »
Maybe u should do name:pasword@ipadres:port
gordonb3
Domoticz version: Custom
Post by gordonb3 »
Port 8080 is not https but plain http
snellejellep
Re: http adres niet bereikbaar
Post by snellejellep »
what you are trying to do is request an https page over the http port, you should try https://<yourip>:443 that should work.
or just http://<yourip>:8080
Smiggel
Domoticz version: 4.9700
Re:http address not reachable
Post by Smiggel »
If you try to browse to domoticz using the same device as it is installed on, you have to go to: http://127.0.0.1:8080 or https://127.0.0.1:443 or use http://localhost:8080, etc.
Qompaqniet
Domoticz version: v4.10717
Post by Qompaqniet »
Have here the same problem. whatever I try none of the suggestions are working. software is last update.
foxmulder06
Post by foxmulder06 »
Activate the domoticz LOG file and check what's happen, first as it should work immediatly, so first reason is that executable file is not running and/or has crashed.
_____________________________________
Pascal
FireWizard
Post by FireWizard »
Move to you domoticz folder.
cd ~/domoticz
and check your domoticz.sh file
more domoticz.sh
and look if
DAEMON_ARGS="$DAEMON_ARGS -www 8080"
DAEMON_ARGS="$DAEMON_ARGS -sslwww 443"
are present.
If not, edit this file, so that the ports are inserted.
Qompaqniet
problem is solved. Missing two weeks data.
1. disconnected Pi from the meter
2. reboted Pi
3. run update of software
4. Reconnected pi to meter
5. reboot
and..................................
It works, can not find why it stopped working two weeks ago.
Only change was installing a connexoon box (somfy) for control of sun screens.
