Nexa temperature sensor
toch
Post by toch »
I am using : RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: Ext2/1022 Set Mode COM6 Disabled
Showing 1 to 1 of 1 entries
I try to include Temp sensor - Nexa NBA-001, but I am not able to find it under devices ?
Anybody knows why ?
admin
Site Admin
Re: Nexa temperature sensor
Post by admin »
Make sure accept new devices under settings is enabled and that the correct protocol is enabled and that the sensor is supported by the rfxtrx
toch
Post by toch »
Nexa is supported by RFXtrx, but an you pls tell me how i can select the correct protocol ?
toch
Post by toch »
pls tell me om a screen shot how I can Disable/Enable new devices under settings .
toch
Post by toch »
enclosed look at my setting - and pls give me feedback.
gizmocuz
Post by gizmocuz »
Can't make screenshots at the moment but it is under the main settings
toch
Post by toch »
ok cant find it, but can you tell me it where to find it on my shot `?
toch
Post by toch »
Is it possible to have some help here?
mrf68
Post by mrf68 »
Setup - Hardware, look for the line with your rfxcom in it and press “Set mode”. Select the necessay protocol (don’t know what is the correct one) and click “Set Mode”.
