I am using : RFXCOM - RFXtrx433 USB 433.92MHz Transceiver
Version: Ext2/1022 Set Mode COM6 Disabled
Showing 1 to 1 of 1 entries
I try to include Temp sensor - Nexa NBA-001, but I am not able to find it under devices ?
Anybody knows why ?
Nexa temperature sensor
Re: Nexa temperature sensor
Make sure accept new devices under settings is enabled and that the correct protocol is enabled and that the sensor is supported by the rfxtrx
Nexa is supported by RFXtrx, but an you pls tell me how i can select the correct protocol ?
pls tell me om a screen shot how I can Disable/Enable new devices under settings .
enclosed look at my setting - and pls give me feedback.
- settings-domoticz.png (262.17 KiB) Viewed 2484 times
- gizmocuz
Can't make screenshots at the moment but it is under the main settings
ok cant find it, but can you tell me it where to find it on my shot `?
Is it possible to have some help here?
mrf68
Setup - Hardware, look for the line with your rfxcom in it and press “Set mode”. Select the necessay protocol (don’t know what is the correct one) and click “Set Mode”.
