Water Leak / Flood Sensor? Topic is solved
islandman
Is there no water level / flood sensor available within domoticz? Cant find any.
jannl
- Domoticz version: 2025.5.x
Re: Water Leak / Flood Sensor?
Sure there are. Got a zwave myself. Look robbshop I think I bought there.
snellejellep
- Domoticz version: 2020.2
https://nl.aliexpress.com/item/Topvico- ... 0.0.3R5GTa
i just bought this one and it works perfectly for me!
assuming you have zwave this sensor seems what you are searching for.
raspberry pi | xiaomi vacuum | yeelight | philips hue | zwave | ubiquiti unifi | harmony | sonoff | zigbee2mqtt | https://www.youtube.com/channel/UC2Zidl ... m1OLuNldfQ
islandman
Thanks, however I meant how do i integrate my flood sensor, because was added as smoke sensorjannl wrote: Tuesday 10 April 2018 7:36 Sure there are. Got a zwave myself. Look robbshop I think I bought there.
islandman
Thanks, however I meant how do i integrate my flood sensor, because was added as smoke sensorsnellejellep wrote: Tuesday 10 April 2018 8:12 https://nl.aliexpress.com/item/Topvico- ... 0.0.3R5GTa
ben53252642
I've got the Fibaro Z-Wave flood sensor which has been working well for about 18 months now.
https://www.youtube.com/watch?v=8JRxUoHbEN8
jannl
Hm. Ok. I see mine is an on/off. I do not really care. It is handled in lua and sends me a notification.
islandman
So there is really no flood sensor setting within domoticz?
fvdl
- Domoticz version: 4.10915
I us neo coolcam water sensor, works fine.
Aliexpress € 22
They act like a switch.
But you can choose a water icon in the switch tab (edit)
It can also send you a notification if you need it, also in the switch tab.
Aliexpress € 22
- sincze
- Domoticz version: 2024.4
Xiaomi has a nice leakage sensor (gateway also needed), or you could build one yourself with mysensors
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
pvklink
- Domoticz version: latest b
i use this one for my waterhome/houseboat.
Works like a charm
https://nl.aliexpress.com/item/Hight-Kw ... 0.0.tYE6Dg
Works like a charm
Jablotron connection, Ikea
- sincze
Excellent, does it work withpvklink wrote: Tuesday 24 April 2018 22:30 i use this one for my waterhome/houseboat.
Works like a charm
- RFLINK
- RFXCOM
- RFXCOM-E
I could not determine the internal chipset
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
