Water Leak / Flood Sensor? Topic is solved
islandman
Post by islandman »
Is there no water level / flood sensor available within domoticz? Cant find any.
jannl
Domoticz version: 2025.5.x
Re: Water Leak / Flood Sensor?
Post by jannl »
Sure there are. Got a zwave myself. Look robbshop I think I bought there.
snellejellep
Post by snellejellep »
https://nl.aliexpress.com/item/Topvico- ... 0.0.3R5GTa
i just bought this one and it works perfectly for me!
assuming you have zwave this sensor seems what you are searching for.
islandman
Post by islandman »
jannl wrote: Tuesday 10 April 2018 7:36 Sure there are. Got a zwave myself. Look robbshop I think I bought there.
Thanks, however I meant how do i integrate my flood sensor, because was added as smoke sensor :-(
islandman
Post by islandman »
snellejellep wrote: Tuesday 10 April 2018 8:12 https://nl.aliexpress.com/item/Topvico- ... 0.0.3R5GTa
ben53252642
Post by ben53252642 »
I've got the Fibaro Z-Wave flood sensor which has been working well for about 18 months now.
https://www.youtube.com/watch?v=8JRxUoHbEN8
jannl
Post by jannl »
Hm. Ok. I see mine is an on/off. I do not really care. It is handled in lua and sends me a notification.
islandman
Post by islandman »
So there is really no flood sensor setting within domoticz?
fvdl
Domoticz version: 4.10915
Post by fvdl »
I us neo coolcam water sensor, works fine.
Aliexpress € 22
They act like a switch.
But you can choose a water icon in the switch tab (edit)
It can also send you a notification if you need it, also in the switch tab.
sincze
Domoticz version: 2024.4
Post by sincze »
Xiaomi has a nice leakage sensor (gateway also needed), or you could build one yourself with mysensors :lol:
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
pvklink
Domoticz version: latest b
Post by pvklink »
i use this one for my waterhome/houseboat.
Works like a charm
https://nl.aliexpress.com/item/Hight-Kw ... 0.0.tYE6Dg
Jablotron connection, Ikea
sincze
Post by sincze »
pvklink wrote: Tuesday 24 April 2018 22:30 i use this one for my waterhome/houseboat.
Works like a charm
Excellent, does it work with
- RFLINK
- RFXCOM
- RFXCOM-E
I could not determine the internal chipset :( to figure it out myself.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
