Hi guys,
I hope someone can help me out with my issue.
I’ve successfully installed the P1 Smart Meter and receive all information except for the ‘Power’ report which displays no results.
Real-time ‘Power’ log data is working properly it’s only the report functionlity which displays no figures.
Has anyone experienced the same issue or knows how to resolve this issue?
Thank you in advance.
Martijn
P1 Smart Meter - Power report empty
- Mooms
- Domoticz version: 2023.01
- 0154E907-7F6D-415C-9621-44BEC0EE7F82.jpeg (294.02 KiB) Viewed 2718 times
- McMelloW
- Domoticz version: V2024.1
Re: P1 Smart Meter - Power report empty
If you look at the P1 Smart Meter devices in the devices list.Do you see any values and changes of the values
Greetings McMelloW
- Mooms
It’s now 4 weeks later since I installed the P1 meter, the Gas report shows all details the Power report remains empty since day 1. Is there anything I can check or parameters to be set or reset in order to resolve this? I’ve also stopped and started the Domoticz services as well as rebooted my Raspberry Pi.
- McMelloW
This odd. You should see something in the report at least after one day. Do you see all values for Electricity on the device?Mooms wrote: Monday 09 April 2018 18:08 It’s now 4 weeks later since I installed the P1 meter, the Gas report shows all details the Power report remains empty since day 1. Is there anything I can check or parameters to be set or reset in order to resolve this? I’ve also stopped and started the Domoticz services as well as rebooted my Raspberry Pi.
This is a quick and dirty try. But your P1 smart meter readings so far are lost.
Remove the P1 Smart meter hardware.
Restart Domoticz
Add the P1 smart meter again.
Greetings McMelloW
- Mooms
Thank you, good point I will give this a try.McMelloW wrote: Monday 09 April 2018 18:28This odd. You should see something in the report at least after one day. Do you see all values for Electricity on the device?Mooms wrote: Monday 09 April 2018 18:08 It’s now 4 weeks later since I installed the P1 meter, the Gas report shows all details the Power report remains empty since day 1. Is there anything I can check or parameters to be set or reset in order to resolve this? I’ve also stopped and started the Domoticz services as well as rebooted my Raspberry Pi.
Restart Domoticz
gerbenvanasselt
- Domoticz version: Beta 4.1
I'm having the same problem. The gas log report contains all logging. But the power report does'nt show anything. How did you solve this problem? I hope you can give me a solution without wiping my historical log files.
Gerben
Verstuurd vanaf mijn ONEPLUS A6003 met Tapatalk
Gerben
