Daily Energy usage cost
garethiowc
So i've been able to graph my energy usage using the owl micro but i wondered if theres anyway i can get domoticz to automatically work out how much it's costing me.
i pay 14.89p per unit.
many thanks
many thanks
- McMelloW
- Domoticz version: V2024.1
Re: Daily Energy usage cost
AT settings ==> meters/counters fill in the cost/kWh.
On the device click on log and then report
Greetings McMelloW
garethiowc
ah awesome thank you
i also have a daily meter charge of 14.09p i don't suppose there's anyway to get that to add to the daily cost?
- McMelloW
I use an average figure per kWh including tax, meter charge etc. This calculated according to the bills of the past few years.
Feel free to think of something clever and post it.
Greetings McMelloW
dervogt
- Domoticz version: BETA
good idea, if you got the energy bill of last year, you can probably just add a markup for the fixed costs like meter rent, delivery&transport costs etc to the price per unit
- McMelloW
Even better if you have energy bills from a couple of years.dervogt wrote: Friday 30 March 2018 12:57 good idea, if you got the energy bill of last year, you can probably just add a markup for the fixed costs like meter rent, delivery&transport costs etc to the price per unit
Greetings McMelloW
MikeF
- Domoticz version: V2022.2
Here's a simple python script I use which calculates energy cost based on cumulative energy today, and which allows for fixed and variable cost elements:
I run this once a minute from crontab - I would have liked to use lua (so this would update every time the Owl device updates), but I couldn't work out how to extract 'CounterToday'.
Here is an example of my output:
(of course this can be changed for other currencies)
- Spoiler: show
garethiowc
MikeF you hero
this is exactly what i was thinking of but just didn't have the knowledge to put it together.
so i would copy the code you have supplied and save it to a file called energy_cost.py
Once i have made the changes i would run:
choose nano and add the following line to the bottom of the file:
sorry where would i find the json for the device?
i can see the following in the logs
crontab -eCode: Select all
*/1 * * * * /usr/bin/python2.7 /sbin/energy_cost.py >> /var/log/energy_cost.log 2>&1sorry where would i find the json for the device?
2018-03-31 16:46:43.495 RFLink: 20;E5;OWL_CM180;ID=003D;WATT=00f1;KWATT=00026bad;
2018-03-31 16:46:43.497 (RFLink Gateway) General/kWh (Power Monitor)
MikeF
Hi garethiowc,
First of all, make sure you change the lines in 'Domoticz variables' section of the code to your values - you'll need to find the idx of your Owl device, and also set up a text sensor in Domoticz, and get its idx.
Once you've got the Domoticz idx of your Owl device, type the following into your browser (replacing the angle brackets with your values):
http://<Domoticz ip:port>/json.htm?type=devices&rid=<Owl idx>
(e.g., http://192.168.0.63:8080/json.htm?type=devices&rid=240)
- this is the json output. If you can see a line like this:
then you should be good to go.
Your crontab steps look OK.
"CounterToday" : "9.211 kWh",Your crontab steps look OK.
garethiowc
Thanks MikeF
just got the script working
apt-get install python-requests
source ~/.bashrc
source ~/.bashrc
garethiowc
is the fixed cost the daily meter rental charge or am i understanding that wrong?
- EdwinK
Trying to get this to work with Toon (Eneco), but only get 0.01 pence costs. Of course I wouldn't mind that
garethiowc
all working great here
thank you so much MikeF
i had to specify the python3 path to get it to work in cron using the following
*/1 * * * * /usr/bin/python3.5 /sbin/energy_cost.py >> /var/log/energy_cost.log 2>&1
added a log output for errors when the cron job runs
next thing to work out would be a weekly and monthly cost output
MikeF
Have you checked that you've got a variable 'CounterToday' (or change it to something similar) that's producing values to a similar order of magnitude (e.g., 6.392 kWh)? and that your fixed / variable costs are similar? (Of course, you can input these in cents, and change the script to display in € rather than £.)EdwinK wrote: Sunday 01 April 2018 22:50 Trying to get this to work with Toon (Eneco), but only get 0.01 pence costs. Of course I wouldn't mind that![]()
garethiowc
Does any one know if the data sting will reset monthly or just keeps counting?"CounterToday" : "6.6 kWh",
"CustomImage" : 0,
"Data" : "167.985 kWh",
clubeddie
Data is Just counting, so not usable for monthly costs.garethiowc wrote: Monday 02 April 2018 0:22Does any one know if the data sting will reset monthly or just keeps counting?"CounterToday" : "6.6 kWh",
"CustomImage" : 0,
MikeF
I guess you could get the script to save the cumulative Data value at the beginning of each month
- if 'day' = '01' and 'time' = '00:00' then write Data to uservariable 'MonthStart'
and then subtract MonthStart from current value of Data every time the script runs...
Haven't tried it though!
- EdwinK
This is what I have within the device:
"ActTime" : 1522779214,
"AstrTwilightEnd" : "22:20",
"AstrTwilightStart" : "05:12",
"CivTwilightEnd" : "20:53",
"CivTwilightStart" : "06:38",
"DayLength" : "13:06",
"NautTwilightEnd" : "21:35",
"NautTwilightStart" : "05:56",
"ServerTime" : "2018-04-03 20:13:34",
"SunAtSouth" : "13:05",
"Sunrise" : "07:12",
"Sunset" : "20:19",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"Counter" : "3532.785",
"CounterDeliv" : "0.000",
"CounterDelivToday" : "0 kWh",
"CounterToday" : "5.709 kWh",
"CustomImage" : 0,
"Data" : "1744933;1787852;0;0;517;0",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 35,
"HardwareName" : "Toon",
"HardwareType" : "Toon Thermostat",
"HardwareTypeVal" : 34,
"HaveTimeout" : false,
"ID" : "1",
"LastUpdate" : "2018-04-03 20:13:13",
"Name" : "Electra",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Energy",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "P1 Smart Meter",
"TypeImg" : "counter",
"Unit" : 1,
"Usage" : "517 Watt",
"UsageDeliv" : "0 Watt",
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "199"
"status" : "OK",
"title" : "Devices"
}Running latest BETA on a Pi-3 | Toon® Thermostat (rooted) | Hue | Tuya | IKEA tradfri | Dashticz V3 on Lenovo Huawei Tablet | Conbee
MikeF
My python script uses CounterToday, so if for instance your unit cost is 14.89 and fixed cost is 14.09 (garethiowc's example), then you should get:EdwinK wrote: Tuesday 03 April 2018 20:14 This is what I have within the device:
{ ... "CounterToday" : "5.709 kWh", ... }
cost = (5.709 * 14.89 + 14.09 ) / 100 = 0.99
Can you check your values and your script again?
