Watermeter, script tuning ?..
Droll
Domoticz version: 2024.7
Post by Droll »
Version: 3.9054
Build Hash: aa52bc9
Compile Date: 2018-03-25 13:47:29
dzVents Version: 2.4.1
Python Version: 3.5.2 (default, Nov 23 2017, 16:37:01) [GCC 5.4.0 20160609]
Need some advice on how to tune this script or other settings in Domoticz so I can get the data I want :)
Short on the setup ...
Watermeter with a pulse output ( 1 P pr 10 L )
Fibaro FGBS-001 Universal Binary Sensor, for the input ..
Fresh Ubuntu server install on a ASUS J1800I-C motherboard...
Been running Domoticz on a PI since 2015 before ...
Scrip below are basically the same as posted http://www.domoticz.com/forum/viewtopic ... oor#p22721, was simple enugh for me to understand :D ....
It does work, sort of, but I can't get the numbers I want, as you can see it says 1000L, and not ?? more like 100 or 250 ...
The 1,34m3 are probably correct...
As for the log ... nothing shows up :? just 0L
The divider inside setup are sett at 1 ... I have tried other settings, but then the m3 are way off ...
Probably just a simple typo somwhere, but are not good at scrips :|
Arne Kjetil
--|1.340
local thisfilename = "/home/domoticz/domoticz/scripts/lua/script_device_Vann_forbruk.lua"
local virtualcounter_idx = "494"
local switchName = "Vann_forbruk"
if devicechanged[switchName] == 'On' then
-- Open this file and read in the first line
   file = io.open(thisfilename, "rb")
   sContents = file:read("*l")
   file:close()
-- Parse and update the countvalue
   foo, snumber = sContents:match("([^,]+)|([^,]+)")
   local countvalue = snumber + 0.01
   local newline = foo .. "|" .. string.format("%.3f", tostring(countvalue))
-- Update virtual counter device
   ts = virtualcounter_idx .. "|0|" .. string.format("%.3f", tostring(countvalue))
   commandArray['UpdateDevice'] = ts
-- Write back new counter value
   local file = io.open(thisfilename, "r+")
   file:write(newline)
   file:close()
Droll
Re: Watermeter, script tuning ?..
Post by Droll »
Got it working :)
Just made another costum dummy sensor, an incremental counter, just a counter...
Decided to go for liter, not m3.. made all the math a bit simpler ..
--|120.000
local virtualcounter_idx = "499"
   file:close()
   local countvalue = snumber + 10
   file:write(newline)
   file:close()
