downgrade domoticz
ropske
Domoticz version: V3_8394
downgrade domoticz
Post by ropske »
Hi, is it actually possible to install an older version of domoticz?
I have now beta V3.9052 but i want to go back to an older version, because my personal website is not working anymore because of :
Het script van http://192.168.1.175:8080/json.htm?type ... 2008312934 is geblokkeerd vanwege een niet-overeenkomend MIM-type
SEC7112: Het script van http://192.168.1.175:8080/json.htm?type ... 2008312940 is geblokkeerd vanwege een niet-overeenkomend MIME-type
Everything was working fine before this update, and i see on this forum more people are having the same problem, with: Dashticz, MyFrontpage,...
philchillbill
Re: downgrade domoticz
Post by philchillbill »
Sure you can downgrade but you need to have a copy of the install-zip in question as the Domo website only provides the latest beta for download (there’s no archive)
Tip: Every time I do a sudo ./updatebeta I also go to the website and download the Linux install zipset to a backup directory, adding the version number to the name manually. That way, if I determine that updating was a bad idea, I just manually install an old beta I knew was good.
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
Egregius
Domoticz version: v2024.7
Post by Egregius »
You should install a backup script to make a complete backup of your domoticz folder and keep versions of it. That way you can very easily rollback to any day you'd like. For example: http://www.domoticz.com/forum/viewtopic ... nc#p109996
ropske
Post by ropske »
Egregius wrote: Monday 26 March 2018 7:15 You should install a backup script to make a complete backup of your domoticz folder and keep versions of it. That way you can very easily rollback to any day you'd like. For example: http://www.domoticz.com/forum/viewtopic ... nc#p109996
Damned, there is a backup script running with rsync every week, but it doesn't copy it into different directory's like yours.
It overwrites it everytime, normally after 1 week i should noticed it; but now i didn't :(
Will do it like you way, copy it in versions; so in different directory's, thanks mate
ropske
Post by ropske »
philchillbill wrote: Sunday 25 March 2018 23:11 Sure you can downgrade but you need to have a copy of the install-zip in question as the Domo website only provides the latest beta for download (there’s no archive)
Maybe you can help me then with an 'older' beta version in case you still have some older versions?
I don't know how many versions there are after 83.xx
can you send me one from 83.xx ? [email protected]
Thank you.
Egregius
Post by Egregius »
philchillbill
ropske wrote: Monday 26 March 2018 9:31 Maybe you can help me then with an 'older' beta version in case you still have some older versions?
Sure, but I always download the Linux Beta variant (I'm on Ubuntu on an Intel NUC). Is that OK for you or do you need Raspbian for a pi ?
