How to update device attribute batterylevel
- McMelloW
- Domoticz version: V2024.1
Is there a way to update or change the device attribute batterylevel on a virtual device? Just want to create custom virtual battery if possible
Greetings McMelloW
- waaren
Re: How to update device attribute batterylevel
McMelloW wrote: Friday 09 March 2018 14:52 Is there a way to update or change the device attribute batterylevel on a virtual device? Just want to create custom virtual battery if possible
local batteryDevice = domoticz.devices("Your battery device name") -- Type: General, subType: Custom Sensor
local batteryLevel = yourBatteryLevel -- int between 0 - 100
batteryDevice.update(0,batteryLevel)Debian buster, bullseye on RPI-4, Intel NUC.
- McMelloW
Thanks for your reaction.waaren wrote: Sunday 11 March 2018 12:39tested on devices created by Z-Wave battery monitor pluginCode: Select all
local batteryDevice = domoticz.devices("Your battery device name") -- Type: General, subType: Custom Sensor local batteryLevel = yourBatteryLevel -- int between 0 - 100 batteryDevice.update(0,batteryLevel)
This does not update the attribute "BatteryLevel"". It remains 255. It does update the attribute "Data"
http://192.168.xxx.yy:8080/json.htm?type=devices&rid=94
Greetings McMelloW
- waaren
I know but if I update the devices created by Z-Wave battery monitor plugin with this, the new value is displayed for the device on the Utility tab.
I have not find anything that is closer to the desired result yet.
- McMelloW
Any device / sensor expert out there willing help me.
How do I update the device attribute BatteryLevel with a number 1-100 on a Virtual device
Greetings McMelloW
- waaren
If you are still interested...McMelloW wrote: Friday 09 March 2018 14:52 Is there a way to update or change the device attribute batterylevel on a virtual device? Just want to create custom virtual battery if possible
updateBatterylevel
devices = { 'Your triggerdevice name'} ,
timer = { 'every 30 minutes' }, -- timer or device to trigger the script. Can be both or one of them
httpResponses = { 'setBatterylevel' } -- When json call is answered it will trigger this
execute = function(domoticz, trigger)
local debug = true
function debug_print(myLine)
if debug then print("***** updateBatterylevel ****** " .. myLine) end
if trigger.isHTTPResponse then
debug_print("Triggered by HTTPResponse")
if (trigger.ok) then -- statusCode == 2xx
local setting = trigger.json.status
debug_print("result: " .. setting )
debug_print("Triggered by device or timer")
local myIP ="nnn.nnn.nnn.nnn" -- your domoticz system IP
local myPort ="nnnn" -- your domoticz port
local batteryDevice = domoticz.devices("BatteryTest")
local deviceIDX = batteryDevice.idx
local newBatterylevel = batteryDevice.batteryLevel or math.random(100)
local myNvalue = batteryDevice.nValue
local mySvalue = batteryDevice.state
local mySignal = batteryDevice.signalLevel
local myUrl = "http://" .. myIP .. ":" .. myPort .. "/json.htm?type=command¶m=udevice&idx=" .. deviceIDX
myUrl = myUrl .. "&nvalue=" .. myNvalue .. "&svalue=" .. mySvalue .. "&rssi=" .. mySignal .. "&battery=" .. newBatterylevel
debug_print("myUrl: " .. myUrl)
domoticz.openURL({
url = myUrl,
method = "GET",
callback = "setBatterylevel"
- McMelloW
Thanks a lot I will have a look at it.waaren wrote: Tuesday 20 March 2018 21:22If you are still interested...McMelloW wrote: Friday 09 March 2018 14:52 Is there a way to update or change the device attribute batterylevel on a virtual device? Just want to create custom virtual battery if possibleCode: Select all
--[[ updateBatterylevel ]] -- return { on = { devices = { 'Your triggerdevice name'} , timer = { 'every 30 minutes' }, -- timer or device to trigger the script. Can be both or one of them httpResponses = { 'setBatterylevel' } -- When json call is answered it will trigger this }, execute = function(domoticz, trigger) local debug = true function debug_print(myLine) if debug then print("***** updateBatterylevel ****** " .. myLine) end end if trigger.isHTTPResponse then debug_print("Triggered by HTTPResponse") if (trigger.ok) then -- statusCode == 2xx local setting = trigger.json.status debug_print("result: " .. setting ) end else debug_print("Triggered by device or timer") local myIP ="nnn.nnn.nnn.nnn" -- your domoticz system IP local myPort ="nnnn" -- your domoticz port local batteryDevice = domoticz.devices("BatteryTest") local deviceIDX = batteryDevice.idx local newBatterylevel = batteryDevice.batteryLevel or math.random(100) local myNvalue = batteryDevice.nValue local mySvalue = batteryDevice.state local mySignal = batteryDevice.signalLevel local myUrl = "http://" .. myIP .. ":" .. myPort .. "/json.htm?type=command¶m=udevice&idx=" .. deviceIDX myUrl = myUrl .. "&nvalue=" .. myNvalue .. "&svalue=" .. mySvalue .. "&rssi=" .. mySignal .. "&battery=" .. newBatterylevel debug_print("myUrl: " .. myUrl) domoticz.openURL({ url = myUrl, method = "GET", callback = "setBatterylevel" }) end end }
Greetings McMelloW
hoeby
- Domoticz version: V2022.1
I am using a copy of this script.
But it is not very stable.
The battery which i am reading out is 84%.
But whit running the script, the answer of the script is going up and down and never got the right read out.
Some idea's?
Some idea's?
Thin-client --> Docker Domoticz main environment
Pi3A+ --> Google home (GAssistPi)
Pi3B+ --> Docker (P1monitor, Domoticz test environment, Ubiquity controller)
- waaren
@hoeby, this script was created to test if it is possible to set the batterylevel on a virtual device. It will look for the batterylevel attribute of a testdevice but if that attribute is not set for that specific device it will generate a random number between 0 and 100 and update the batterylevel of a virtual device with it.hoeby wrote: Monday 23 July 2018 21:38 I am using a copy of this script.
Some idea's?
It was never meant to be used other then for test/development purposes. Sorry if that was not clear
hoeby
thanks for the reply.
i will try to remove the math.random and look what will hapen. maybe nothing, but i can try
EDIT: tried it, but get an error. disabled the script, tonight i will look further if something can be changed to get it working.
Domoticz can read the battery status of the device. Just looking for it how it works and how it can be used for making virtual switches with it.
hoeby
Your code is working whit a little changing
What is changed?
- Removed the
- Changed the URL to the dummy IDX device. I have done this because i want to use it in a dashboard an need the read the battery value of my device. When connecting it to a dummy i can program it different than the IDX which produces the batterylevel. This is not necessary when your are not using dummy devices.
I don't work whit the Local xx = xx function.
Because when debugging i find it easier when to code is writting whitout variables.
Therefor my code is not cleaned up, sorry for that
What is changed?
- Removed the
or math.random(100)I don't work whit the Local xx = xx function.
updateBatterylevel
devices = { 'Xiaomi Door Sensor'} ,
timer = { 'every 1 minutes' }, -- timer or device to trigger the script. Can be both or one of them
local debug = true
local myIP ="192.168.178.29" -- your domoticz system IP
local myPort ="8080" -- your domoticz port
local batteryDevice = domoticz.devices("Xiaomi Door Sensor")
local mySvalue = batteryDevice.batteryLevel
local myUrl = "http://192.168.178.29:8080/json.htm?type=command¶m=udevice&idx=100"
domoticz.openURL({
url = myUrl,
}Thin-client --> Docker Domoticz main environment
jannnfe
I do not understand why the script should go to you. For me it results in an infinite loop, because every time the device is turned on, it is automatically turned on a second time and that triggers the script again. Do not you have this problem? Please check your log.
jannnfe
This is my modified script:
And the setting of the signal level does not work. it will always set the default value of 12.
-- Lua dzVents Script
-- Check Dead Device and set BatteryLevel
devices = {
'Doppellampe'
timer = {
'at 12:00'
logging = {
level = domoticz.LOG_DEBUG,
marker = 'ManageBattery'
-- Every Day at 12:00 do this:
if(item.isTimer) then
-- Check all devices for potential deadness based on the latest update:
local deadDevices = domoticz.devices().filter(function(device)
return (device.lastUpdate.daysAgo > 4)
end)
deadDevices.forEach(function(deadDevice)
domoticz.openURL('http://192.168.178.10:8080/json.htm?type=command¶m=udevice&idx=' ..deadDevice.idx.. '&nvalue=' ..deadDevice.nValue.. '&svalue=""&rssi=7&battery=5')
domoticz.log('Set potential dead device ' ..deadDevice.name.. ' Battery & RSSI Level!', domoticz.LOG_DEBUG)
end)
-- If any device is changed, do this:
elseif(item.isDevice) then
local deviceIDX = item.idx
local newBatterylevel = item.batteryLevel or math.random(50, 70)
local myNvalue = item.nValue
local mySvalue = item.state
local mySignal = item.signalLevel or math.random(5, 8)
local myUrl = "http://192.168.178.10:8080/json.htm?type=command¶m=udevice&idx=" ..deviceIDX.. "&nvalue=" ..myNvalue.. "&svalue=" ..mySvalue.. "&rssi=" ..mySignal.. "&battery=" ..newBatterylevel
domoticz.log('myUrl: ' ..myUrl, domoticz.LOG_DEBUG)
domoticz.openURL({
url = myUrl,
method = "GET",
