How to update device attribute batterylevel
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
Is there a way to update or change the device attribute batterylevel on a virtual device? Just want to create custom virtual battery if possible
Greetings McMelloW
Re: How to update device attribute batterylevel
McMelloW wrote: Friday 09 March 2018 14:52 Is there a way to update or change the device attribute batterylevel on a virtual device? Just want to create custom virtual battery if possible
local batteryDevice = domoticz.devices("Your battery device name")   -- Type: General, subType: Custom Sensor
local batteryLevel = yourBatteryLevel                                -- int between 0 - 100
batteryDevice.update(0,batteryLevel)
tested on devices created by Z-Wave battery monitor plugin
McMelloW
Post by McMelloW »
waaren wrote: Sunday 11 March 2018 12:39
Thanks for your reaction.
This does not update the attribute "BatteryLevel"". It remains 255. It does update the attribute "Data"
http://192.168.xxx.yy:8080/json.htm?type=devices&rid=94
Greetings McMelloW
I know but if I update the devices created by Z-Wave battery monitor plugin with this, the new value is displayed for the device on the Utility tab.
I have not find anything that is closer to the desired result yet.
McMelloW
Post by McMelloW »
Any device / sensor expert out there willing help me.
How do I update the device attribute BatteryLevel with a number 1-100 on a Virtual device
Greetings McMelloW
If you are still interested...
   updateBatterylevel
		devices = { 'Your triggerdevice name'} ,
        	timer = { 'every 30 minutes' },             -- timer or device to trigger the script. Can be both or one of them
        	httpResponses = { 'setBatterylevel' }	    -- When json call is answered it will trigger this
    execute = function(domoticz, trigger)
	local debug = true
        function debug_print(myLine)
        	if debug then print("***** updateBatterylevel ****** "  .. myLine) end
	if trigger.isHTTPResponse then
		debug_print("Triggered by HTTPResponse")
		if (trigger.ok) then -- statusCode == 2xx
               		local setting = trigger.json.status
               		debug_print("result: " .. setting )
        	debug_print("Triggered by device or timer")
        	local myIP          ="nnn.nnn.nnn.nnn"   -- your domoticz system IP
        	local myPort        ="nnnn"			-- your domoticz port
        	local batteryDevice = domoticz.devices("BatteryTest")
        	local deviceIDX       = batteryDevice.idx
	    	local newBatterylevel = batteryDevice.batteryLevel or math.random(100)
        	local myNvalue        = batteryDevice.nValue
        	local mySvalue        = batteryDevice.state
        	local mySignal        = batteryDevice.signalLevel
        	local myUrl           = "http://" .. myIP .. ":" .. myPort .. "/json.htm?type=command&param=udevice&idx=" .. deviceIDX
        	myUrl = myUrl .. "&nvalue=" .. myNvalue .. "&svalue=" .. mySvalue .. "&rssi=" .. mySignal .. "&battery=" .. newBatterylevel
           	debug_print("myUrl: " .. myUrl)
                domoticz.openURL({
                	url = myUrl,
                	method = "GET",
                	callback = "setBatterylevel"
McMelloW
Post by McMelloW »
waaren wrote: Tuesday 20 March 2018 21:22
   updateBatterylevel
	local debug = true
                domoticz.openURL({
                	url = myUrl,
                	method = "GET",
Thanks a lot I will have a look at it.
Greetings McMelloW
hoeby
Domoticz version: V2022.1
Post by hoeby »
I am using a copy of this script.
But it is not very stable.
The battery which i am reading out is 84%.
But whit running the script, the answer of the script is going up and down and never got the right read out.
Some idea's?
hoeby wrote: Monday 23 July 2018 21:38 I am using a copy of this script.
Some idea's?
@hoeby, this script was created to test if it is possible to set the batterylevel on a virtual device. It will look for the batterylevel attribute of a testdevice but if that attribute is not set for that specific device it will generate a random number between 0 and 100 and update the batterylevel of a virtual device with it.
It was never meant to be used other then for test/development purposes. Sorry if that was not clear
hoeby
Post by hoeby »
thanks for the reply.
i will try to remove the math.random and look what will hapen. maybe nothing, but i can try
EDIT: tried it, but get an error. disabled the script, tonight i will look further if something can be changed to get it working.
Domoticz can read the battery status of the device. Just looking for it how it works and how it can be used for making virtual switches with it.
hoeby
Post by hoeby »
Your code is working whit a little changing
What is changed?
- Removed the
or math.random(100)
- Changed the URL to the dummy IDX device. I have done this because i want to use it in a dashboard an need the read the battery value of my device. When connecting it to a dummy i can program it different than the IDX which produces the batterylevel. This is not necessary when your are not using dummy devices.
I don't work whit the Local xx = xx function.
Because when debugging i find it easier when to code is writting whitout variables.
Therefor my code is not cleaned up, sorry for that
   updateBatterylevel
		devices = { 'Xiaomi Door Sensor'} ,
        	timer = { 'every 1 minutes' },             -- timer or device to trigger the script. Can be both or one of them
	local debug = true
        	local myIP          ="192.168.178.29"   -- your domoticz system IP
        	local myPort        ="8080"			-- your domoticz port
        	local batteryDevice = domoticz.devices("Xiaomi Door Sensor")
        	local mySvalue        = batteryDevice.batteryLevel
        	local myUrl           = "http://192.168.178.29:8080/json.htm?type=command&param=udevice&idx=100"
                domoticz.openURL({
                	url = myUrl,
jannnfe
Post by jannnfe »
I do not understand why the script should go to you. For me it results in an infinite loop, because every time the device is turned on, it is automatically turned on a second time and that triggers the script again. Do not you have this problem? Please check your log.
jannnfe
Post by jannnfe »
This is my modified script:
-- Lua dzVents Script
-- Check Dead Device and set BatteryLevel
        devices = {
            'Doppellampe'
        timer = {
            'at 12:00'
    logging = {
        level = domoticz.LOG_DEBUG,
        marker = 'ManageBattery'
        -- Every Day at 12:00 do this:
        if(item.isTimer) then
            -- Check all devices for potential deadness based on the latest update:
            local deadDevices = domoticz.devices().filter(function(device)
                return (device.lastUpdate.daysAgo > 4)
            end)
            deadDevices.forEach(function(deadDevice)
                domoticz.openURL('http://192.168.178.10:8080/json.htm?type=command&param=udevice&idx=' ..deadDevice.idx.. '&nvalue=' ..deadDevice.nValue.. '&svalue=""&rssi=7&battery=5')
                domoticz.log('Set potential dead device ' ..deadDevice.name.. ' Battery & RSSI Level!', domoticz.LOG_DEBUG)
            end)
        -- If any device is changed, do this:
        elseif(item.isDevice) then
            local deviceIDX       = item.idx
            local newBatterylevel = item.batteryLevel or math.random(50, 70)
            local myNvalue        = item.nValue
            local mySvalue        = item.state
            local mySignal        = item.signalLevel or math.random(5, 8)
            local myUrl           = "http://192.168.178.10:8080/json.htm?type=command&param=udevice&idx=" ..deviceIDX.. "&nvalue=" ..myNvalue.. "&svalue=" ..mySvalue.. "&rssi=" ..mySignal.. "&battery=" ..newBatterylevel
            domoticz.log('myUrl: ' ..myUrl, domoticz.LOG_DEBUG)
            domoticz.openURL({
                url = myUrl,
                method = "GET",
And the setting of the signal level does not work. it will always set the default value of 12.
