IFTTT and Domoticz
whatisk
Domoticz version: 3.9224
IFTTT and Domoticz
Post by whatisk »
I am hoping it's possible to setup Domoticz so that when a switch is triggered (for example) it will also run an IFTTT applet. Essentially what I am hoping to do is control a Sonoff wifi switch this way rather than trying to flash alternative firmware via an Adruino. I did find some Github projects that avoid needing to do this, but don't work if the firmware is above a certain version. I thought controlling via IFTTT could be an easier solution.
I have found the wiki page on IFTTT integration with Domoticz, however I can't find the option in Domoticz to add the API key.
The wiki advises to add the API key in Domoticz under Settings->Notifications->IFTTT. However this doesn't appear to exist in the Beta version I am running (couple of versions behind latest). I did find a thread with the same question as above, and they said they ended up using "Custom HTTP/Action".
Is what I am wanting to do possible? And if so is there a guide or is someone able to assist with the how?
Cheers.
Re: IFTTT and Domoticz
Do you have any specific reason to stay on your current domoticz version ?
whatisk
Post by whatisk »
waaren wrote: Monday 19 March 2018 7:36 Do you have any specific reason to stay on your current domoticz version ?
Not at all. I'm currently running v3.8890. I believe latest beta is v3.9052 and am happy to upgrade to that if it will help achieve what I am after.
However the wiki entry was last modified Nov 1 2017, so the version I am running is more recent (Feb 7 2018) than the article.
looking at setup -> settings -> notifications screen in V3.9049
ifftt in domoticz.PNG (8.36 KiB) Viewed 11583 times
whatisk
Post by whatisk »
waaren wrote: Monday 19 March 2018 8:02 looking at setup -> settings -> notifications screen in V3.9049
Upgraded to v3.9052 and there now.
Cheers.
GCB2016
Domoticz version: V3.9208
Post by GCB2016 »
Hi, I think I made happen what you need. With a couple seconds of lag, but that's fine for a most cases.
First, use the EWeLink app to add the Sonoff to your wifi-network so that you will be able to turn the light (or whatever you have connected to it ;)) on/off from the app.
Then in IFTTT you have to connect 2 integrations: Webhooks(https://ifttt.com/maker_webhooks) and EWeLink(https://ifttt.com/ewelink)
if you go to your webhooks connection and click on Documentation you see a https-url with your secret key. It looks like this:
https://maker.ifttt.com/trigger/{event}/with/key/dhnasdfasdIOtMfFbV_Khd9dKsdfaMiz5_
Then I created two Applets:
  • For the IFT I used the Webhooks integration and added the eventname to 'lamp_on' (this is your {event}-name). For the TT I chose the EWeLink connection ('Turn 1 channel switch on or off') and selected my lamp and told it to set it to 'On'. Create action.
    So now you have a url that looks like this:
    https://maker.ifttt.com/trigger/lamp_on/with/key/dhnasdfasdIOtMfFbV_Khd9dKsdfaMiz5_
  • I created a second Applet with the only difference I called it 'lamp_off' and set it to 'Off'. Which results in the following url
    https://maker.ifttt.com/trigger/lamp_off/with/key/dhnasdfasdIOtMfFbV_Khd9dKsdfaMiz5_
Back to Domoticz:
Create a Dummy Switch (type: On/Off). Go to 'Edit' on the Dummy Switch and paste the 2 urls in the On and Off sections. I assume you know which to put where ;).
When switching the Dummy you set it to either On of Off and it will trigger the related url, triggering IFTTT which triggers the EWeLink app and within 3 seconds your lamp switches on/off.
whatisk
Post by whatisk »
GCB2016 wrote: Monday 26 March 2018 21:25 Hi, I think I made happen what you need. With a couple seconds of lag, but that's fine for a most cases.
Thank you for the detailed reply.
I did manage to get a test running successfully with IFTTT and Domoticz. Still waiting on some stuff to arrive before I do it for real.
dswinton
Post by dswinton »
Hi Guys,
I know this thread is a few months old, but it was the first result on Google when I was looking for a solution to this problem.
I wanted a way to have all of my devices available via my Google Home's, but without having to create a million IFTTT applets to do it.
I made a script that makes it quick and easy, which I've published in GitHub here:
https://github.com/dswinton/domo-ifttt
Hopefully this will help someone else looking for a solution to this problem.
BarryT
Domoticz version: 2024.3
Post by BarryT »
dswinton wrote: Sunday 12 August 2018 15:04 Hi Guys,
Can you tell us how to make this work?
The php is correctly done its job, but then?
dextm80
Domoticz version: 4.10159
Post by dextm80 »
hi guys, there are anyone that put a definitive guide how to use ifttt with domoticz for a newbies (for example with a simple lights or google home)?
I looking fot that but found only confused or already created video or text.
Domoticz on AsRock j3455-ITX 8gb ram - Aeotec ZWave Usb Stick - RFLink 433Mhz
1x Fibaro Wall Plug
1x Fibaro Motion Sensor
x NeoCoolcam Wall Plug
Netatmo Weather Station - Netatmo Thermostat
Philips Hue Bridge
RapTile
Post by RapTile »
dextm80 wrote: Friday 30 November 2018 16:22 hi guys, there are anyone that put a definitive guide how to use ifttt with domoticz for a newbies (for example with a simple lights or google home)?
I use controlicz
In the google home you can add the controlicz service
Controlicz connects to your Domoticz and performs the action for you.
dextm80
Post by dextm80 »
RapTile wrote: Friday 30 November 2018 17:03
I use controlicz
Hi, thanks for your feedback, but controlicz is a paid service
1x Fibaro Wall Plug
Philips Hue Bridge
RapTile
Post by RapTile »
dextm80 wrote: Friday 30 November 2018 22:44
I use controlicz
True, but it works great :)
daniellejorge
Post by daniellejorge »
Trying to setup my domoticz to google home mini.
Im inside domoticz using v 4.10915 when i enable IFTT and put the API KEY and Aplly setting i get:
Invalid location settings...
Can someone help me?
daniellejorge wrote: Wednesday 19 June 2019 17:03 Trying to setup my domoticz to google home mini.
It's about this location in the settings
daniellejorge
waaren wrote: Wednesday 19 June 2019 18:32
Omg, you are a god!!! Thank you very much!!! :D :D :D
