How to init GPIO-SYSFS and define inputs using raspi-gpio
OldPensionado
- Domoticz version: 2020.2
Hi guys,
I'm struggling with my RPi, Domoticz (V3.8153), and the plugin GPIO-SYSFS-Switches. And up to this moment my RPi is winning...
What's the case/problem?
I would like to read an input which changes between 0 V and 3V and see the changes reflected in a Domoticz switch/light.
I did an update of Domoticz (from V3.5877 to V3.8153). I was using an older Python version (2.7.9) and updated that as well to Python3 V3.4.2.
After this update I found some errors in the Domoticz logfile (about "Failed dynamic library load, install the latest libpython3.x lib that is available for your platform"). This was finally solved by completely removing Python and a fresh reinstall. At the end I had to install python3-dev in order to get no errors in the logfile. Took me a lot of hours.
Then I decide to install plugin GPIO-SYSFS-Switches from Github. Prior to this I had some problems to stop and disable GPIOinput.service.
After installing the GPIO-SYSFS plugin I don't know how to start or initialize this plugin. Also I was unable to find out where and how to declare the IO-pins (BCM-numbers).
Reading all kinds of posts for two days now doesn't help me till now.
Since I am not very familiar with Linux and so, I would heavily appreciate when you explicitly mention the folder/directory where a specific file resides. Also specifying the precise Raspbian command would be very helpful.
By the way: I know how to declare a (virtual) switch in Domoticz and I did use GPIOinput where the Domoticz description field has to contain for instance "%pin=23".
I sincerely hope someone is out there, has the answers and will share them with me.
Thanks in advance!
[Edit: Forgot to mention that I successfully installed raspi-gpio too. I have tried "$ sudo raspi-gpio set 4 ip pd" but I'm afraid that I need some more information or tips how to go further.]
Thanks in advance!
RPi 1, model B, Rev. 2; RPi 3B+; RPi Zero; RPi 4B
Raspbian 11 (Bullseye)
Domoticz V2024.7
Well, such is life. And it's getting sucher and sucher...
Domoticz V2024.7
ubee
- Domoticz version: 2021.1
Re: How to init GPIO-SYSFS and define inputs using raspi-gpio
Hm, I'm a bit confused here. I doubt you need to enable this python plugin to make this work. In order to just have a switch reflecting the status of an input pin, you should first of all add a new HW device - Generic sysfs GPIO. You also need to configure which pins you should use for this system. See this post for details:
http://www.domoticz.com/forum/viewtopic.php?t=17688
Once you have done this, you just create a new switch device on the Switch tab. Use the manual option in the upper left corner. There you can select which pin to use (if you have many input pins) etc.
You don't need the GPIOinput.service either. That was a fix made by me for polled input. The built in GPIO sysfs support si the only thing you need. It works well. Also forget the virtual switches and %pin etc. That belongs to the GPIOinput.service as well.
OldPensionado
@ubee: thanks for the reply!
What I did:
To check: $ sudo raspi-gpio get 4, which results in: GPIO 4: level=0 fsel=0 func=INPUT. Looks good to me.
In Domoticz I added a new piece of hardware in Setup > Hardware, type Generic sysfs GPIO. And the result was looking good.
However, as mentioned by @elgringo in the topic http://www.domoticz.com/forum/viewtopic.php?t=17688
What did I do wrong? Did I forgot something in the definition using raspi-gpio?
What I did:
$ sudo raspi-gpio set 4 ip pdIn Domoticz I added a new piece of hardware in Setup > Hardware, type Generic sysfs GPIO. And the result was looking good.
I didn't see any "Auto configure devices" to check or to uncheck.Note:
When you add the "Generic sysfs GPIO" hardware "Auto configure devices" is selected by default. In case you want to manually configure your exported sysfs-gpio devices you must uncheck "Auto configure devices" in the "Setup - hardware - Generic sysfs GPIO" menu.
Last edited by OldPensionado on Tuesday 13 March 2018 17:37, edited 1 time in total.
Domoticz V2024.7
Domoticz V2024.7
ubee
Well, I see this check box in my configuration. This is enabled, but to be honest I don't know what this is used for. In my case this is enabled and I add my switches manually on the switches tab. I think this thread should be moved to Bugs and problems. Maybe you can make a new post in that forum and refer to this. Then the guy behind sysfs GPIO might see it and can guide you further.
OldPensionado
What I did:
This is I think exactly (well, ok, I used gpio4 in stead of gpio26) the same as elgringo did in this post
viewtopic.php?f=4&t=17688&p=140828&hili ... te#p140828
And still no checkbox for Autoconfigure devices.
sudo raspi-gpio set 4 ip pu
sudo echo "4" > /sys/class/gpio/export
echo "1" | sudo tee -a /sys/class/gpio/gpio4/active_low
echo "both" | sudo tee -a /sys/class/gpio/gpio4/edge
Domoticz V2024.7
Domoticz V2024.7
ubee
Maybe you should try another web-browser. This sounds weird, but sometimes the browser creates problems with Domoticz. I think it is cache or cookie related. For instance, try with Edge to see if this helps.
OldPensionado
Yes, yes!
I tested with Chrome and voilà: the Auto configure devices checkbox and Debounce field both appear! Since I prefer to keep using Firefox I cleared the cache and both fields are visible now in Firefox too. Somewhere on this forum I read a post about clearing the browser's cache.
Thank you again. Now I can continue with my little project of defining an input and so on.
I'll report later.
I'll report later.
Domoticz V2024.7
Domoticz V2024.7
OldPensionado
Since my problem about the invisible checkboxes "Auto configure devices" was solved by @ubee I did a lot of experiments with defining gpio-pins and trying to connect to them within Domoticz. But so far no success, unfortunately.
I am afraid that I'm doing something seriously wrong in my pin definition. I've tried (again) to define inputs as in my previous post http://www.domoticz.com/forum/viewtopic ... 01#p174403.
Somewhere on the forum I saw that the double quote sign (") was not used; I've tried this without any success.
What I need to know is:
Thanks in advance!
- is it necessary to use a script which runs at boottime of the RPi?
- or can I enter these commands in my putty-window?
- what kind of script should I use (Python?)
- in which startup file should this script be invoked?
- when is it necessary to reboot the RPi?
- how could I check whether the commands have been executed correctly?
- where can I find what these commands actually do (or what results should be visible)?
- which part of the Domoticz manual should I read more in detail?
Thanks in advance!
Domoticz V2024.7
Domoticz V2024.7
ubee
You need to configure the pins at boot. I have made an update to /etc/rc.local. In my case I have defined a shell script with the following commands and just execute this script by the end of rc.local.
I have put this in a file
/home/pi/sysfs_init.sh
and execute this by adding the following line by the end of /etc/rc.local
Please make sure you make this file executable by the following command
chmod 750 sysfs_init.sh
#! /bin/sh
# Init sysfs GPIO ports
# unexport
#echo 4 > /sys/class/gpio/unexport
#echo 12 > /sys/class/gpio/unexport
#echo 13 > /sys/class/gpio/unexport
# export
echo 17 > /sys/class/gpio/export
echo 18 > /sys/class/gpio/export
echo 22 > /sys/class/gpio/export
echo 10 > /sys/class/gpio/export
echo 9 > /sys/class/gpio/export
echo 11 > /sys/class/gpio/export
echo 8 > /sys/class/gpio/export
echo 7 > /sys/class/gpio/export
# Set direction = in
# echo in > /sys/class/gpio/gpio4/direction
echo out > /sys/class/gpio/gpio17/direction
echo out > /sys/class/gpio/gpio18/direction
echo out > /sys/class/gpio/gpio22/direction
echo out > /sys/class/gpio/gpio10/direction
echo out > /sys/class/gpio/gpio9/direction
echo out > /sys/class/gpio/gpio11/direction
echo out > /sys/class/gpio/gpio8/direction
echo out > /sys/class/gpio/gpio7/direction
# Set active_low = 0 (false)
# echo 0 > /sys/class/gpio/gpio4/active_low
echo 1 > /sys/class/gpio/gpio17/active_low
echo 1 > /sys/class/gpio/gpio18/active_low
echo 1 > /sys/class/gpio/gpio22/active_low
echo 1 > /sys/class/gpio/gpio10/active_low
echo 1 > /sys/class/gpio/gpio9/active_low
echo 1 > /sys/class/gpio/gpio11/active_low
echo 1 > /sys/class/gpio/gpio8/active_low
echo 1 > /sys/class/gpio/gpio7/active_low
# Set edges = none
# echo none > /sys/class/gpio/gpio4/edge
# Set pullups
# raspi-gpio set 4 pu
#raspi-gpio set 11 dl
#raspi-gpio set 12 dl
peterjoosen
- Domoticz version: 4.9700
Hi everyone,
I'm struggling with the configuration of the GPIO input pins with my raspberry pi3. I configured GPIO 0,1,2,4,5,6,7,8,9 and 10 as inputs in the file: /etc/init.d/domoticz.sh and they all work when I activate the hardware tab (Generic SYSFS GPIO). After a reboot, GPIO 9 and 10 don't react anymore. Disable and re-enable the hardware is necessary to let them work until you reboot again. I tried to test this with a brand new Raspbian Stretch_lite installation with a clean database, but it doesn't help. I also checked the logfile and performed python update (No errors after Python update to version '3.5.3'). Is there a limitation on how many inputs you can use or isn't it possible to use certain GPIO numbers? I will put a text doc with the additional lines used in the domoticz.sh file for declaring the GPIO pins... Anyone suggestions ?
Please , let me know if you have a solution
Regards,
Peter
Regards,
Peter
HvdW
- Domoticz version: 2023.2
I have been struggling with GPIO all day.
The post of @ubee is straightforward and works as expected.
The Domoticz sysfs wiki is a bit confusing in my opinion.
@ubee sets the pin active_low , the Wiki sets the value.
Bugs bug me.
Users browsing this forum: Jeweettoch13 and 1 guest
