RFXTRX433 and Conrad RSL
phobosman
Post by phobosman »
I'm using the rfxtrx433 in Domoticz with some Nexa and Conrad RSL switches. The Nexa switches works fine but I cannot get the Conrad RSL to work. I'm using this ( http://www.conrad.se/RADIOSTYRD-INF%26A ... 84_2806092 )
When adding a switch in Domoticz, the RSL alternative doesn't show in drop down. Is this a known problem? Or should I use another protocol...?
Blom1974
Re: RFXTRX433 and Conrad RSL
Post by Blom1974 »
Did you get this sorted?
BobdeBouwer
Post by BobdeBouwer »
Hi there,
On the Conrad site it will not show whether they are RSL 2 or RSL 3 type when you look them up or buy them.
I bought 4 outlet switches and a remote for around 25,- euro, 2000W per switch wich you simply insert into a wall outlet (<0.5 W standby) ..no problem I thought.
But even with the undec mode switched on in the RFXCOM tranceiver, they won't show up.
After a bit of reading and checking the appliance, I discovered that I had bought RSL366R switches.
I'm guessing that they are brand new RSL types and RFXCOM firmware (my receiver is at firmware 71) will not decode them properly at this point in time.
So my tip's:
- look at the back of the Conrad RSL switches and find the model no.
- try the 'undec mode' on (look for options, hardware, RFXCOM setup mode, check the undec on box, save.. Then go to the Domoticz log (options -> log) and press the remote for the switches. If nothings appears you won't get a chance to use them in Domoticz (don't forget to uncheck the 'undec mode' after this discovery tour)
- If you have an RSL 3xx model, hope that future versions of the firmware of the RFXCOM device will support it (I am sure you could even drop them an email)
Regards,
Bob
sebitop
Post by sebitop »
Hi there
did you fix this issue with rfxcom or domoticz ?
I ordered some RSL switches from conrad but if they are not compatible I will send them back.
Let me know.
cheers
sebastien
domoticz on Raspberry Pi + RFXcom LAN moded
Blyss / DI.O / ESP / Arduino
BobdeBouwer
Hi there,
I will post an email to RFXCOM this evening.
I will let you know what comes out.
Regards,
Bob
sebitop
Post by sebitop »
Just for info RSL4 are compatible
I will test RSLU receivers soon
b_weijenberg
Post by b_weijenberg »
The Conrad set (order number 034911) does not use RSL coding despite of the type indication RSL366R!
This set can be controlled using Lighting4. The code table has been added to the RFXtrx User Guide.
Receive for the remote will not be added.
RFX-433, RFX-433EMC, RFX-868
BobdeBouwer
Thanks for updating the user guide (page 31) and researching the RSL 3xx story, great support!
To finish off at the Domoticz end, I encountered a problem. (nothing to do with the RFXCOM product)
First, I set the protocols to at least Lightning 4 in the hardware tab of the Domoticz setup tab.
Then, from the drop-down menu in the switches tab (manual addition of switches), I can't seem to find the Lightning4 'type' assuming the 'switch type' to be on/off.
I tested 'Livolo' because they also have 2 code wheels but no effect.
Am I doing something wrong?
Regards,
Bob
twimpy
Domoticz version: V2.3790
Post by twimpy »
Hi is there any update? :?:
I like to use these devices to I think this protocol is less used.
I searched what type I should use in add Manual Light/Switch Device but cannot find RSL protocol in the list.
Regards,
Twimpy
phobosman
Post by phobosman »
I'm using several Conrad RSL switches with Domoticz and RFXTRX433, but the only way I can get them into Domotics is by first use another sending source. (E.g. RSL remote). I happens to have an old Telldus usb stick that has support for Conrad RSL. I program the switch with the Telldus and then use the "Learn switch" function in Domoticz. It will then show up in Domoticz as Conrad RSL switch. This will also work with a remote that can control Conrad RSL.
xtenz
Post by xtenz »
I just would like to share that I found a "dirty" way to operate these Conrad RSL366R devices using rfxcmd (https://code.google.com/p/rfxcmd/)
Using rfxcmd Domoticz can operate these devices using OS cli commands. The reason why this is a dirty trick is because rfxcmd hijacks the serial interface of the RFXCOM device causing Domoticz to loose its connection with the RFXCOM transciever.
Domoticz logs the following messages:
2015-04-11 15:11:36.113 Error: Serial Port closed!... Error: End of file
2015-04-11 15:11:37.092 RFXCOM: retrying in 30 seconds...
Fortunately Domoticz automatically reconnects to the RFXCOM device but please be aware that this is causing an interruption in the communication between Domoticz and the RFXCOM device every time you switch a Conrad RSL366R device.
Though it's not perfect it does work without any alternatives available. (As far as I'm aware)
Hopefully the developers of Domoticz will find some time to invest in the implementation of manually adding lightning4 devices so rfxcmd can be skipped.
More information about this topic/request can be found in the following thread: http://www.domoticz.com/forum/viewtopic ... 449#p24449
This is how it can be done.
1. Install and configure rfxcmd like described in their documentation.
2. Create a switch (E.g. a Dummy or use the autolearn feature to register a remote control)
3. Install a lua script in domoticz/scripts/lua that takes care of executing the correct cli commands.
An example:
script_device_switchConrad.lua:
-- script name : script_device_switchConrad
-- This script will trigger a command every time the Domoticz switch changes status
if (devicechanged["Switch1"] == 'On') then
print "Switched Conrad1 On"
os.execute ("/opt/rfxcmd/rfxcmd.py -s 0913000354155501A950")
if (devicechanged["Switch1"] == 'Off') then
print "Switched Conrad1 Off"
os.execute ("/opt/rfxcmd/rfxcmd.py -s 0913000354155401A950")
if (devicechanged["Switch2"] == 'On') then
print "Switched Conrad2 On"
os.execute ("/opt/rfxcmd/rfxcmd.py -s 0913000354455501A950")
if (devicechanged["Switch2"] == 'Off') then
print "Switched Conrad2 Off"
os.execute ("/opt/rfxcmd/rfxcmd.py -s 0913000354455401A950")
if (devicechanged["Switch3"] == 'On') then
print "Switched Conrad3 On"
os.execute ("/opt/rfxcmd/rfxcmd.py -s 0913000354515501A950")
if (devicechanged["Switch3"] == 'Off') then
print "Switched Conrad3 Off"
os.execute ("/opt/rfxcmd/rfxcmd.py -s 0913000354515401A950")
if (devicechanged["Switch4"] == 'On') then
print "Switched Conrad4 On"
os.execute ("/opt/rfxcmd/rfxcmd.py -s 0913000354545501A950")
if (devicechanged["Switch4"] == 'Off') then
print "Switched Conrad4 Off"
os.execute ("/opt/rfxcmd/rfxcmd.py -s 0913000354545401A950")
In this example I am using the configurable channel IV but you can always adapt the codes like described in chapter 14.4 of the rfxcom userguide:
http://www.rfxcom.com/WebRoot/StoreNL2/ ... _Guide.pdf
Just convert the described BIN values to HEX using e.g. a calculator app and replace these values in the used examples: rfxcmd.py -s 0913000354545401A950
Names like "Switch1" should be replaced by the name of your switch defined in Domoticz.
Testing rfxcmd can be done manually using the cli command directly e.g.: /opt/rfxcmd/rfxcmd.py -s 0913000354455501A950
frostwork
Post by frostwork »
I recently bought some RSL366R and also had the problem, that I couldn't add them in the domoticz add switch dropdown.
now I simply picked "RisingSun" in the dropdown and set it to "A,1" (my testing RSL is set to "I,1") and the RSL works! :)
I'm using latest rfx433 Type1 fw (86) and the RSL is detected as Lighting1.
I hope this helps some people :)
xtenz
Post by xtenz »
Frostwork, you made my day.
I can confirm that RisingSun is working for these RSL366R devices even with different channels.
I'm using a rfx433E with the latest ext 240 firmware.
This is a little bit easier and better compared to my former approach :D
frostwork
Post by frostwork »
I'm glad I could be helpful :)
Unfortunately the range of the RSLs seems to be worse than f.e. those of the IT1500 devices,
haven't tested much yet though :)
chimit
Domoticz version: master
Post by chimit »
I also could switch on and of the RSL366 switches with this.
My question: Just how can the remote control be recognized?
bewo
Domoticz version: 2021.1
Similar lightning4 problem with RFXTRX433
Post by bewo »
Hi together,
i have an similar problem. I've bought some new - cheap - sockets from Voltomat (Bauhaus Germany).
They works with lightning4. But i didn't get work them with domoticz.
So - can i get this working with a lua script like xtenz have done?
Thanks for a little bit help :)
This are the sockets:
This the code which i've received with RFXmanager:
When i press "ON A":
Packettype    = Lighting4
subtype       = PT2262
Sequence nbr  = 30
Code          = C3B970
S1- S24  = 1100 0011 1011 1001 0111 0000
Pulse         = 384 usec
Signal level  = 6
When i press "OFF A":
subtype       = PT2262
Sequence nbr  = 31
Code          = C21B10
S1- S24  = 1100 0010 0001 1011 0001 0000
Pulse         = 382 usec
Signal level  = 7
When i press "ON B":
subtype       = PT2262
Sequence nbr  = 32
Code          = CBFAB4
S1- S24  = 1100 1011 1111 1010 1011 0100
Pulse         = 384 usec
Signal level  = 7
When i press "OFF B":
subtype       = PT2262
Sequence nbr  = 33
Code          = C99F24
S1- S24  = 1100 1001 1001 1111 0010 0100
Pulse         = 382 usec
Signal level  = 7
When i press "ON C":
subtype       = PT2262
Sequence nbr  = 34
Code          = CBFABC
S1- S24  = 1100 1011 1111 1010 1011 1100
Pulse         = 384 usec
Signal level  = 7
When i press "OFF C":
subtype       = PT2262
Sequence nbr  = 35
Code          = C99F2C
S1- S24  = 1100 1001 1001 1111 0010 1100
Pulse         = 384 usec
Signal level  = 7
When i press "ON D":
subtype       = PT2262
Sequence nbr  = 36
Code          = CA5492
S1- S24  = 1100 1010 0101 0100 1001 0010
Pulse         = 382 usec
Signal level  = 7
When i press "OFF D":
subtype       = PT2262
Sequence nbr  = 37
Code          = C1D842
S1- S24  = 1100 0001 1101 1000 0100 0010
Pulse         = 382 usec
Signal level  = 7
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
patvandijk
Post by patvandijk »
I was able to add the Conrad RSL33T manually by adding it as RisingSun.
Just cycled through all combinations to check which one worked.
My transmitter broke, so I was not able to use the autolearn anyway.
vermonden
Post by vermonden »
Hello, I have the same problem like bewo. I have a Voltomat (Bauhaus Germany).
What should I do to get this working in Domoticz?
biomm
Post by biomm »
Just received few Conrad RSL devices. As previously described no such equipment on drop-down list so, I have decided to check 2 above possibilities:
1) described by phobosman - I have paired one RSL433R with remote (mini control). Remote was easily recognised by Domoticz so, it was easy to add it into switches - so far so good..
- for some practical reasons (below) option described by frostwork was much more interesting (as far as I do understand no remotes in use) BUT I did checked all A-D (1-4) options of RisingSun and was not able to add a switch as receiver was not reacting on "test".
Receiver / switch tested RSL-R2 - might be the reason (??) Anyway first option is OK - just wondering how to avoid swithing on/off few devices as remote used is a basic one - no choice of channels and my plan is to use several switches both inside as well as outside...
Will update when done with other switches but your help in dealing with Conrad RSL is most welcome!
[2017-02-12] UPDATE: SOLVED :-) all Conrad RSL working with Domotich!
MarceldeJongNL
Domoticz version: 3.5108
Post by MarceldeJongNL »
biomm wrote: [2017-02-12] UPDATE: SOLVED :-) all Conrad RSL working with Domotich!
Good news!
Did you solve with the use of a remote, or did you find an other way?
Hardware: Raspberry Pi 2B | RFXCOM RFXtrx433E v1 | Synology DS213+ | KaKu Clones | Conrad RSL switches | KAKu Doorbell Clone | USB Webcam | ICY Thermostat | Resol DL2 | Imatic Relay Board | Eminent 6230 | Eminent 6220 | iMatic 16 ports Relay Board
