Hello all,
as I'm using the beta branch of Domoticz and as i understood from the wiki that each domoticz update will wipe the DAshticz folder i would like to setup the Dashticz on a separate web server as it is mentioned that you can either install on domoticz or on any other web server.
is it possible to install Dashticz on a Synology apache web server ? what are the necessary package for that ? only apache or do i also need to install node.js V4 ?
any input will be greatly appreciated.
Cheers,
Flo
Dashticz - Beginner question
Kerneldomoticz
- Domoticz version: 3.5248
aiolos
- Domoticz version: stable
Re: Dashticz - Beginner question
You can also use the symlink option as described here: https://github.com/Dashticz/dashticz_v2 ... -dashboard
After a Domoticz update, only the symlink needs to be created again then (but your whole config is still there)
I don't expect you need anything special on the Synology web server, only if you want to be able to save the config using the interface, than you need php.
tontze
- Domoticz version: Beta Ch
You sure it wipes dashticz ? Since im using beta domoticz and my dashticz hasnt been wiped after several domoticz updates ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
aiolos
There was a time it did, maybe the update process has changed.
On the other hand it's good practice to keep things separated, so the symlink option can be worth it.
