Dashticz - Beginner question
Kerneldomoticz
Domoticz version: 3.5248
Post by Kerneldomoticz »
Hello all,
as I'm using the beta branch of Domoticz and as i understood from the wiki that each domoticz update will wipe the DAshticz folder i would like to setup the Dashticz on a separate web server as it is mentioned that you can either install on domoticz or on any other web server.
is it possible to install Dashticz on a Synology apache web server ? what are the necessary package for that ? only apache or do i also need to install node.js V4 ?
any input will be greatly appreciated.
Cheers,
Flo
aiolos
Domoticz version: stable
Re: Dashticz - Beginner question
Post by aiolos »
You can also use the symlink option as described here: https://github.com/Dashticz/dashticz_v2 ... -dashboard
After a Domoticz update, only the symlink needs to be created again then (but your whole config is still there)
I don't expect you need anything special on the Synology web server, only if you want to be able to save the config using the interface, than you need php.
Contributor to Dashticz
More on my Github profile
tontze
Domoticz version: Beta Ch
Post by tontze »
You sure it wipes dashticz ? Since im using beta domoticz and my dashticz hasnt been wiped after several domoticz updates ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
aiolos
Post by aiolos »
There was a time it did, maybe the update process has changed.
On the other hand it's good practice to keep things separated, so the symlink option can be worth it.
