I build a new radio.lua script. You can select the radio station via a selector switch.
Based on this topic:
viewtopic.php?t=10672
And this wiki article:
http://www.domoticz.com/wiki/Play_streaming_radio
First install the necessary tool:
sudo apt-get update
sudo apt-get install mplayerJust make a new selector switch with your favorite name (in my example "Wohnzimmer > Radio"). Add your radio stations with name. Then add a new LUA script and select "Device only" as execution type. Copy the code and change the radio station addresses, the switch name and the switch selector names. Thats all.
The Code:
-- This script play a streaming radio when the device is changed
-- Start files with "mplayer -noconsolecontrols radiostation.mp3 &> /dev/null"
-- Start playlists with "mplayer -noconsolecontrols -playlist radiostation.m3u &> /dev/null"
if (devicechanged['Wohnzimmer > Radio'] == 'Off') then
os.execute ("killall mplayer")
if (devicechanged['Wohnzimmer > Radio'] == '1FM') then
os.execute ("mplayer -noconsolecontrols http://uk2.internet-radio.com:8358/ &> /dev/null")
if (devicechanged['Wohnzimmer > Radio'] == '1LIVE') then
os.execute ("mplayer -noconsolecontrols https://wdr-1live-live.icecastssl.wdr.de/wdr/1live/live/mp3/128/stream.mp3 &> /dev/null")
if (devicechanged['Wohnzimmer > Radio'] == 'Bayern 3') then
os.execute ("mplayer -noconsolecontrols http://br-br3-live.cast.addradio.de/br/br3/live/mp3/128/stream.mp3 &> /dev/null")
if (devicechanged['Wohnzimmer > Radio'] == 'MDR Jump') then
os.execute ("mplayer -noconsolecontrols http://mdr-284320-0.cast.mdr.de/mdr/284320/0/mp3/high/stream.mp3 &> /dev/null")
if (devicechanged['Wohnzimmer > Radio'] == 'Radio Berg') then
os.execute ("mplayer -noconsolecontrols http://edge.live.mp3.mdn.newmedia.nacamar.net/radioberg/livestream.mp3 &> /dev/null")
if (devicechanged['Wohnzimmer > Radio'] == 'SWR1 Rheinland-Pfalz') then
os.execute ("mplayer -noconsolecontrols http://swr-swr1-rp.cast.addradio.de/swr/swr1/rp/mp3/128/stream.mp3 &> /dev/null")
if (devicechanged['Wohnzimmer > Radio'] == 'SWR3') then
os.execute ("mplayer -noconsolecontrols http://swr-swr3-live.cast.addradio.de/swr/swr3/live/mp3/128/stream.mp3 &> /dev/null")
if (devicechanged['Wohnzimmer > Radio'] == 'WDR2 Bergisches Land') then
os.execute ("mplayer -noconsolecontrols https://wdr-wdr2-bergischesland.icecastssl.wdr.de/wdr/wdr2/bergischesland/mp3/128/stream.mp3 &> /dev/null")
if (devicechanged['Wohnzimmer > Radio'] == 'WDR4') then
os.execute ("mplayer -noconsolecontrols https://wdr-wdr4-live.icecastssl.wdr.de/wdr/wdr4/live/mp3/128/stream.mp3 &> /dev/null")
commandArray['Variable:Wohnzimmer > Radio Senderspeicher'] = '10'
