dzVent script device trigger * bug?
snuiter
Post by snuiter »
So I am having two door sensors deur1 and deur2, when I create a script to notify on door open it works fine when triggered by a device. Now I changed script to be triggered by deur* and it is now sending out notifications now and then even when there was no trigger of any of the devices. This is awkward as both deur1 and deur2 have not been triggered since yesterday
Anyone an suggestion what this could be
2018-02-25 12:32:02.905 dzVents: deur script
2018-02-25 12:32:02.906 dzVents: deur open-3
2018-02-25 12:32:02.910 dzVents: deur script
2018-02-25 12:32:02.910 dzVents: deur open-3
It works fine when only using deur1 and deur2 as device triggers but not when I use deur* in the script.
I thought I check my device listings on "deur" and noticed there is also "Voltage - deur1" and "Voltage - deur2" and when there is an update on the voltage the script is triggered. To me this seems to be in error as the trigger is deur* and not *deur*.
Should this be reported as a bug?
This is the script:
devices = {
'deur1','deur2','deur*'
local now = domoticz.time -- current time
print("deur script")
if now.hour <= 7 and now.wday ~= 1 then
print("deur open-1")
if now.hour >= 22 and now.wday ~= 1 then
print("deur open-2")
if now.wday == 1 then
print("deur open-3")
emme
Domoticz version: latest
Re: dzVent script device trigger * bug?
Post by emme »
well.. deur* already include deur1 and deur2... so you might want to simply specify deur* as on device condition.
then in your script, if you need (but you actually do not in you script) you can use
if device.name == 'deur1' then
elseif device.name == 'deur2' then
to make different action based on the device triggered.
ciao
M
"We always done this way"
snuiter
Post by snuiter »
Thx M for your response.
But the strange behavior is that if the script only has deur* as device listed it also gets triggered by the two devices that only monitor the voltage of the two door switches e.g.
- Voltage - deur1
- Voltage - deur2
So the script is not only triggered by the two "deur" switches but also through an update of the voltage device.
So these four devices trigger the script due to "deur*" So no door is opened but the script gets triggered by an voltage update from battery of the door switch. For now I will use "deur1" and "deur2" as my triggers and not the simple "deur*"
Schermafdruk 2018-02-25 20.55.46.png (53.15 KiB) Viewed 1150 times
emme
Post by emme »
oh, then it would be
devices = {
'deur1','deur2','*deur*' to trigger also for Voltage - Deur ;)
snuiter wrote: Sunday 25 February 2018 20:59 Thx M for your response.
- Voltage - deur1
- Voltage - deur2
Kind of interested what the output is of
print("Script triggered by: " .. device.name)
snuiter
Post by snuiter »
The script got triggered by the batteries and that is the problem I don't want that. To me a bit awkward as this is not matching with "deur*"
Script:
devices = {
'deur*'
2018-02-25 22:48:41.898 dzVents: Script triggered by: Voltage - deur1
2018-02-25 22:48:41.898 dzVents: deur open-3
2018-02-25 22:48:41.902 dzVents: Script triggered by: Voltage - deur2
2018-02-25 22:48:41.902 dzVents: deur open-3
Schermafdruk 2018-02-25 22.50.25.png (115.48 KiB) Viewed 1136 times
Looks indeed to be a bug; but best to ask Danny if it is not working as designed.
Logic in domoticz/dzVents/runtime/Eeventhelpers.lua only checks if an "*" is in the scriptTrigger and if so, if the rest of the scriptTrigger string is found in the target device name, without considering if its at the beginning or at the end.
Although fixable it is not as easy as it looks at first sight.
Until it is fixed I propose a rename of your voltage or door contacts.
dannybloe
Post by dannybloe »
Indeed.. what you can try is in Eventhelpers.lua, function self.findScriptForTarget, replace this line:
scriptTrigger = string.gsub(scriptTrigger, "*", ".*")
with
scriptTrigger = '^' .. string.gsub(scriptTrigger, "*", ".*")
I think that should do the trick.
dannybloe wrote: Monday 26 February 2018 8:20 Indeed.. what you can try is in Eventhelpers.lua, function self.findScriptForTarget, replace this line:
with
Thanks Danny, this indeed does the trick for a trailing "*" but does not change the behaviour for a leading "*"
dannybloe
Post by dannybloe »
Which matching goes wrong then?
dannybloe wrote: Monday 26 February 2018 9:00 Which matching goes wrong then?
please see my testcode. I also sent you a PM about this.
Wildcard test
defined three devices
triggertest_wildcard
wildcard_triggertest
triggertest_wildcard_triggertest
 on = { devices = { "wild*"  } },
 This reacts as expected	(triggers on wildcard_triggertest )
 on = { devices = { "*wildcard*"  } },
 This reacts as expected	(triggers on all three devices )
  on = { devices = { "*card"  } },
 This reacts not as expected (triggers on all three devices and I expected to only trigger on ttriggertest_wildcard)
      print("RvW Script triggered by: " .. device.name)
