user variable as setpoint
Patricen
Domoticz version: Beta rel
Post by Patricen »
I'm trying to give a temperature setpoint using a user's variable. The issue is that only digits can be accepted within the setpoint field.
Is there a trick or an improvement that could help using a user's variable as a setpoint?
blauwebuis
Domoticz version: current
Re: user variable as setpoint
Post by blauwebuis »
in the Aurora theme you can change the value of a text element directly in the interface. Perhaps that could be another route.
Patricen
Post by Patricen »
unfortunately no success at the moment
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
I think a script is possibly the only easy solution.
local switch = 'Set_Main_Thermostat'
local mainstatidx = 543
local target = tonumber(uservariables['Target_Temperature'])
if (devicechanged[switch]) == 'On' then
	commandArray[#commandArray+1] = {['SetSetPoint:' ..mainstatidx]=tostring(target)}
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
