I'm trying to give a temperature setpoint using a user's variable. The issue is that only digits can be accepted within the setpoint field.
Is there a trick or an improvement that could help using a user's variable as a setpoint?
user variable as setpoint
Patricen
- Domoticz version: Beta rel
- Blockly.png (1.91 KiB) Viewed 1184 times
blauwebuis
- Domoticz version: current
Re: user variable as setpoint
in the Aurora theme you can change the value of a text element directly in the interface. Perhaps that could be another route.
Patricen
unfortunately no success at the moment
alanlsmith
- Domoticz version: Latest β
I think a script is possibly the only easy solution.
local switch = 'Set_Main_Thermostat'
local mainstatidx = 543
local target = tonumber(uservariables['Target_Temperature'])
if (devicechanged[switch]) == 'On' then
commandArray[#commandArray+1] = {['SetSetPoint:' ..mainstatidx]=tostring(target)}
return commandArrayDomoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
