Yet another presence detection method
Re: Yet another presence detection method
hi, sorry for my english, google translate is my friend lol.
I installed on my AC88U with merlin.
did I fill up well?
#! / Bin / sh
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection xx.xx.xx.xx 3888"
when I type ./presence_detection xx.xx.xx.xx IDX3888 I get the message [: On: unknown operand or [: Off: unknown operand
my phone is recognized. in domoticz the switch does not change state.
is a script needed in LUA in domoticz?
can you help me please?
did I fill up well?
#! / Bin / sh
- Surroot
Hi!
It seems like a mistake happened when you copied the script.
Try copy and paste again and replace the script on your router.
Good luck
Good luck
it does not work.
is it necessary to put a script in domoticz? LUA, python ....?
it does not work.
if you have an idee
[youtube]https://youtu.be/qeTwzoC8qvQ?t=56s[/youtube]
#! /bin/sh
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection 74:23:44:F7:2C:9B IDX3692"
#!/bin/sh
mac=$1
idx=$2
device_present=Off
domoticz_status=`curl -s "http://vulbas:[email protected]:8080/json.htm?\
type=devices&rid=$idx" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
# look in 2.4GHz (eth1) network for device
for x in `wl -i eth1 assoclist | awk '{print $2}'`; do
if [ $x = $mac ]; then
device_present=On
fi
done
# look in 5GHz (eth2) network for device
for x in `wl -i eth2 assoclist | awk '{print $2}'`; do
device_present=On
fi
done
# tell domoticz the new device status
if [ $domoticz_status != $device_present ]; then
if [ $device_present = "On" ]; then
type=command¶m=switchlight&idx=$idx&switchcmd=On" > /dev/null
type=command¶m=switchlight&idx=$idx&switchcmd=Off" > /dev/null
fi
fi
- Surroot
Ah sorry, I see. "IDX" was intended to be replaced by only a number, not by IDX+number.
So your commands have to look like this:
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection 74:23:44:F7:2C:9B 3692"
Best regards.
Best regards.
- Surroot
You could try setting the status manually by executing:
curl -s "http://domoticzUser:domoticzPassword@domoticzIP:domoticzPort/json.htm?\ type=command¶m=switchlight&idx=3692&switchcmd=On"
- Surroot
remove "\ " in between htm? and type=
curl -s "http://vulbas:[email protected]:8080/json.htm? type=command¶m=switchlight&idx=$idx&switchcmd=On"
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>admin@RT-AC88U-2648:/jffs/scripts#
- Surroot
There is still a space symbol between json.htm? and type=vulbas wrote: ↑Saturday 24 February 2018 18:20 curl -s "http://vulbas:[email protected]:8080/json.htm? type=command¶m=switchlight&idx=$idx&switchcmd=On"
hello surout
i have installed a new domoticz and i make a hard reset of my router, the problem is the same.
i don't understand
with a still a space symbol between json.htm? and type=
admin@RT-AC88U-2648:/jffs/scripts# curl -s "http://vulbas:[email protected]:8080/json.htm? type=command¶m=switchlight&idx=$idx&switchcmd=On"
with no space symbol between json.htm? and type=
admin@RT-AC88U-2648:/jffs/scripts# curl -s "http://vulbas:[email protected]:80 ... itchcmd=On"
"status" : "ERR"
i have the asus router AC88U with merlin 384.3
i don't understand
"status" : "ERR"
- Surroot
you forgot to replace $idx with the ID of your switch
ho sorry, i don't understand that
this is good ?
this is good ?
#!/bin/sh
mac=$1
idx=$2
device_present=Off
type=devices&rid=3692" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
device_present=On
fi
done
device_present=On
fi
done
type=command¶m=switchlight&idx=3692&switchcmd=On" > /dev/null
type=command¶m=switchlight&idx=3692&switchcmd=Off" > /dev/null
fi
fi
hello,
finaly that work for my phone !!!
but i whant put an another phone, and that don't work
how to add a second phone on the code ?
the IDX is only 3701 on this code
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection 74:23:44:F7:2C:9B 3701
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection D4:A3:3D:20:51:69 3705
#!/bin/sh
mac=$1
idx=$2
device_present=Off
domoticz_status=`curl -s "xxxxxxxxxxxxxxx/json.htm?type=devices&rid=3701" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
if [ $x = $mac ]; then device_present=On
fi
done
fi
done
curl -s "xxxxxxxxxxxxxxxxxx/json.htm?type=command¶m=switchlight&idx=3701&switchcmd=On" > /dev/null
curl -s "xxxxxxxxxxxxxxxxxxxxx/json.htm?type=command¶m=switchlight&idx=3701&switchcmd=Off" > /dev/null
fi
fi
your cru commands are missing ending "
should be:
should be:
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection 74:23:44:F7:2C:9B 3701"
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection D4:A3:3D:20:51:69 3705"
ho thank you.
it worked without the "
but i do not know how to have two phone
