Yet another presence detection method
vulbas
Re: Yet another presence detection method
Post by vulbas »
hi, sorry for my english, google translate is my friend lol.
I installed on my AC88U with merlin.
did I fill up well?
#! / Bin / sh
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection xx.xx.xx.xx 3888"
when I type ./presence_detection xx.xx.xx.xx IDX3888 I get the message [: On: unknown operand or [: Off: unknown operand
my phone is recognized. in domoticz the switch does not change state.
is a script needed in LUA in domoticz?
can you help me please?
Surroot
Post by Surroot »
Hi!
It seems like a mistake happened when you copied the script.
Try copy and paste again and replace the script on your router.
Good luck
vulbas
Post by vulbas »
it does not work.
is it necessary to put a script in domoticz? LUA, python ....?
Surroot
Post by Surroot »
vulbas wrote: Saturday 24 February 2018 15:49 Hello,
it does not work.
No it's not necessary, just try the steps from the description of the first post again.
BR
vulbas
Post by vulbas »
if you have an idee
#! /bin/sh
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection 74:23:44:F7:2C:9B IDX3692"
#!/bin/sh
mac=$1
idx=$2
device_present=Off
domoticz_status=`curl -s "http://vulbas:[email protected]:8080/json.htm?\
type=devices&rid=$idx" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
# look in 2.4GHz (eth1) network for device
for x in `wl -i eth1 assoclist | awk '{print $2}'`; do
 if [ $x = $mac ]; then
        device_present=On
 fi
done
# look in 5GHz (eth2) network for device
for x in `wl -i eth2 assoclist | awk '{print $2}'`; do
        device_present=On
 fi
done
# tell domoticz the new device status
if [ $domoticz_status != $device_present ]; then
 if [ $device_present = "On" ]; then
        type=command&param=switchlight&idx=$idx&switchcmd=On" > /dev/null
        type=command&param=switchlight&idx=$idx&switchcmd=Off" > /dev/null
 fi
fi
[youtube]https://youtu.be/qeTwzoC8qvQ?t=56s[/youtube]
Surroot
Post by Surroot »
Ah sorry, I see. "IDX" was intended to be replaced by only a number, not by IDX+number.
So your commands have to look like this:
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection 74:23:44:F7:2C:9B 3692"
Best regards.
vulbas
Post by vulbas »
I had tested for IDX ;)
https://youtu.be/X_YdIgSoNlA
Surroot
Post by Surroot »
vulbas wrote: Saturday 24 February 2018 18:00 I had tested for IDX ;)
You could try setting the status manually by executing:
curl -s "http://domoticzUser:domoticzPassword@domoticzIP:domoticzPort/json.htm?\ type=command&param=switchlight&idx=3692&switchcmd=On"
vulbas
Post by vulbas »
Surroot
Post by Surroot »
vulbas wrote: Saturday 24 February 2018 18:14 Image
https://i62.servimg.com/u/f62/17/98/85/70/bad11.png
:o :(
remove "\ " in between htm? and type=
vulbas
Post by vulbas »
curl -s "http://vulbas:[email protected]:8080/json.htm? type=command&param=switchlight&idx=$idx&switchcmd=On"
<html><head><title>Bad Request</title></head><body><h1>400 Bad Request</h1></body></html>admin@RT-AC88U-2648:/jffs/scripts#
Surroot
Post by Surroot »
vulbas wrote: Saturday 24 February 2018 18:20 curl -s "http://vulbas:[email protected]:8080/json.htm? type=command&param=switchlight&idx=$idx&switchcmd=On"
There is still a space symbol between json.htm? and type=
vulbas
Post by vulbas »
hello surout
i have installed a new domoticz and i make a hard reset of my router, the problem is the same.
i don't understand
with a still a space symbol between json.htm? and type=
admin@RT-AC88U-2648:/jffs/scripts# curl -s "http://vulbas:[email protected]:8080/json.htm? type=command&param=switchlight&idx=$idx&switchcmd=On"
with no space symbol between json.htm? and type=
admin@RT-AC88U-2648:/jffs/scripts# curl -s "http://vulbas:[email protected]:80 ... itchcmd=On"
"status" : "ERR"
i have the asus router AC88U with merlin 384.3
Surroot
Post by Surroot »
you forgot to replace $idx with the ID of your switch
vulbas
Post by vulbas »
ho sorry, i don't understand that :? :? :?
this is good ?
#!/bin/sh
mac=$1
idx=$2
device_present=Off
type=devices&rid=3692" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
        device_present=On
 fi
done
        device_present=On
 fi
done
        type=command&param=switchlight&idx=3692&switchcmd=On" > /dev/null
        type=command&param=switchlight&idx=3692&switchcmd=Off" > /dev/null
 fi
fi
vulbas
Post by vulbas »
it does not work automatically
vulbas
Post by vulbas »
avec ce code ça fonctionne presque.
le on s'allume automatiquement.
mais il ne s'eteint pas automatiquement
with this code it works almost.
it turns on automatically.
but it does not turn off automatically
:? :roll: :| :cry:
vulbas
Post by vulbas »
hello,
finaly that work for my phone !!! :D :D
but i whant put an another phone, and that don't work :(
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection 74:23:44:F7:2C:9B 3701
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection D4:A3:3D:20:51:69 3705
how to add a second phone on the code ?
the IDX is only 3701 on this code :(
#!/bin/sh
mac=$1
idx=$2
device_present=Off
domoticz_status=`curl -s "xxxxxxxxxxxxxxx/json.htm?type=devices&rid=3701" | grep Status | awk '{print $3}' | sed 's/[",]//g'`
 if [ $x = $mac ]; then device_present=On
 fi
done
 fi
done
        curl -s "xxxxxxxxxxxxxxxxxx/json.htm?type=command&param=switchlight&idx=3701&switchcmd=On" > /dev/null
        curl -s "xxxxxxxxxxxxxxxxxxxxx/json.htm?type=command&param=switchlight&idx=3701&switchcmd=Off" > /dev/null
 fi
fi
timop
Post by timop »
your cru commands are missing ending "
should be:
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection 74:23:44:F7:2C:9B 3701"
cru a PRESENCE "*/1 * * * * /jffs/scripts/presence_detection D4:A3:3D:20:51:69 3705"
vulbas
Post by vulbas »
ho thank you.
it worked without the "
but i do not know how to have two phone :(
