Dashticz - Module - Calendar
Cletus
Domoticz version: Latest
Re: Dashticz - Module - Calendar
Post by Cletus »
Indeed! I tried the following:
Internal IP from Internal PC on port 8080 (http) works
FQDN from Internal PC on port 8080 (http) works
FQDN from Internal PC on port 443 (https) does not work
Probably because dashticz.nl is http? I am using domoticz with https and official certificate as i prefer https over http without any safety warnings :) is there a way to get this working or does this require @robgeerts to change the dashticz.nl url to https?
This is our world now... the world of the electron and the switch, the beauty of the baud.
DewGew
Domoticz version: V4.10618
Post by DewGew »
Cletus wrote: Tuesday 20 February 2018 13:13 Indeed! I tried the following:
I started an issue on github. @robgeerts have to take a look at this. But he seems busy nowdays .. :?
geertvercamer
Post by geertvercamer »
weird.
My dashticz is working fine after modifying the calendar.js to use the dashticz.nl version.
However, when I launch curl http://dashticz.nl/.... on a raspberry pi, there's a 404 error. When launching in Chrome on W10, I get the data...???
Timmi1993
Post by Timmi1993 »
I edited the code again. It still doesn't work. No matter if internal or external, no matter if formula or something else, only loading.....
Do you use calendars. combined?
geertvercamer
No, I want 3 separate blocks.
var calendars = {};
calendars.private = {key:'private', width:12, maxitems: 5, icalurl: _CROSS_ORIGINE_URL + 'https://calendar.google.com/calendar/ical/xxx%40gmail.com/private-xxx/basic.ics' };
calendars.wasteFromGarden = {key:'wasteFromGarden', width:12, maxitems: 1, icalurl: _CROSS_ORIGINE_URL + 'https://calendar.google.com/calendar/ical/yyy%40group.calendar.google.com/public/basic.ics' };
calendars.justForMe = {key:'justForMe', width:3, maxitems: 153, icalurl: _CROSS_ORIGINE_URL + 'https://calendar.google.com/calendar/ical/zzz0%40group.calendar.google.com/private-zzz/basic.ics' };
columns[3]['blocks'] = [calendars.private, calendars.justForMeColoured, calendars.wasteFromGardenColoured, 'garbage', 'streamplayer', 28, 'chromecast']; //, 45, 'spotify'];
htilburgs
Post by htilburgs »
calendars.private = {key:'private', width:12, maxitems: 5, icalurl: _CROSS_ORIGINE_URL + .... };
I was wondering what these options do?
key:'private'
width: 12
I can't seem to find them in the code and no text about it on the wiki.
The same for _CROSS_ORIGINE_URL, have you modified the code yourself somewhere?
Hardware:
geertvercamer
only barely.
If I remember correctly, in the past some settings used crossorigin.me, other cors-anywhere.herokuapp.com, maybe one in the master, another in the beta.
it's just a constant I use wherever this technique is necessary:
var _CROSS_ORIGINE_URL = 'https://cors-anywhere.herokuapp.com/'; // https://crossorigin.me/
the key and width options are probably remnants of previous versions, I don't see anything in the wiki neither.
I found some other settings not exactly up to date. Thanks for pointing this out!
And I must correct my previous remark about the combined.
As a matter of fact I am using it as I want each caledar block to have a different colour. I don't know how to handle this otherwise.
So I have:
var calendars = {};
calendars.private = {maxitems: 5, icalurl: _CROSS_ORIGINE_URL + 'https://calendar.googl.../basic.ics' };
calendars.wasteFromGarden = {maxitems: 1, icalurl: _CROSS_ORIGINE_URL + 'https://calendar.google.c.../basic.ics' };
calendars.justForMe = {maxitems: 3, icalurl: _CROSS_ORIGINE_URL + 'https://calendar.google.c.../basic.ics' };
calendars.justForMeColoured = {};
calendars.justForMeColoured.calendars =	[	{ color: '#cefad9', calendar:calendars.justForMe } ];
calendars.justForMeColoured.maxitems = 3;
calendars.wasteFromGardenColoured = {};
calendars.wasteFromGardenColoured.calendars =	[	{ color: '#00aa00', calendar:calendars.wasteFromGarden }	];
calendars.wasteFromGardenColoured.maxitems = 1;
columns[3] = {};
columns[3]['width'] = 3;
htilburgs
Post by htilburgs »
Strange. I'm using the latest beta and for me everything is working.
var calendars = {}
calendars.f1 = {maxitems: 5, title:'', image:'', icalurl:'webcal://p28-calendars.icloud.com/published/2/xxxxxxxx'}
calendars.prive = {maxitems: 5, title: '', image: '', icalurl:'webcal://p04-calendarws.icloud.com/ca/subscribe/1/xxxxxxx'}
Schermafbeelding 2018-02-21 om 18.27.00.png (222.21 KiB) Viewed 3670 times
Hardware:
Cletus
Post by Cletus »
I think important here is do you use HTTP or HTTPS ?
axel2906
Domoticz version: V3.8926
Post by axel2906 »
it doesn't work with chrome firefox edge or Internet Explorer on my Win 10 computer. I try beta or stable version but nothing for the calendar
calendars.F1 = { maxitems: 5, image: 'calendar.png', url: 'webcal://xxxx2018-formula-1-calendar/calendar.ics', icalurl: 'webcal://xxxx2018-formula-1-calendar/calendar.ics'};
The attachment stable.PNG is no longer available
but if i try it on my smartphone with the browser "Samsung internet", chrome on external lan (4G), it works.
to resume no calendar in internal network but well in external network (i use a no-ip adress for the external)
no https
RPi3 - RfxComm - Milight - OWL160
htilburgs
Post by htilburgs »
Cletus wrote: Wednesday 21 February 2018 19:21 I think important here is do you use HTTP or HTTPS ?
Http. I don’t have any ports open to the outerworld, except for VPN.
Hardware:
Timmi1993
Post by Timmi1993 »
axel2906 wrote: Wednesday 21 February 2018 20:57 it doesn't work with chrome firefox edge or Internet Explorer on my Win 10 computer. I try beta or stable version but nothing for the calendar
no https
Yes, thats true.
I have an Fire HD 10 with Silk-Browser and it works.
Chrome, firefox, ... = Loading
Edit: I have installed the silk browser on my other tablet and it doesn't work
Mads
Post by Mads »
hi.
i also got a problem. The calender just keep loading.
this i my code
var calendars = {}
calendars.private = { maxitems: 5, icalurl: 'https://cors-anywhere.herokuapp.com/web ... MCzfvbZ44/' }
The calender has worked, but now i wont :/
geertvercamer
I've just noticed another problem. I have my calendars showing up all right. I have a 'common' calendar and a 'private' one (tasks/appointments just for me) and I show them in their own block. Both are wrapped in a calendars.x.calendars 'object' to set their own colour.
There is a problem with the items shown in the 'private' calendar.
next Tuesday I have 2 appointmnts
- an appointment A repeating every first Tuesday of the month at 17:45
- an appointment B repeating every first Tuesday of 2 months at 18:15.
The agenda block is setup to show 3 items.
I see 3 items of appointment B...
when I combine them into one calendar all items appear correctly.
htilburgs
Post by htilburgs »
Mads wrote: Thursday 22 February 2018 19:10 hi.
this i my code
var calendars = {}
Try to remove the https://cors-anywhere.herokuapp.com/ part in the url.
Hardware:
axel2906
Post by axel2906 »
i've found a workaround
I changed the calendar.js file to this :
before :
var cache = new Date().getTime();
		curUrl = http://dashticz.nl/ical/?time=' + cache + '&url=' + curUrl;
		moment.locale(settings['calendarlanguage']);
		$.getJSON(curUrl,function(data,textstatus,jqXHR){
i add this before dashticz.nl :
after :
		curUrl = 'https://cors-anywhere.herokuapp.com/http://dashticz.nl/ical/?time=' + cache + '&url=' + curUrl;
and now it's work as expected
Timmi1993
Post by Timmi1993 »
axel2906 wrote: Sunday 25 February 2018 12:48 i've found a workaround
before :
after :
You're my hero.
Thank you, everything works great now. ;)
Mads
Post by Mads »
Didnt help me. The loading text just disapered now :/
axel2906
Post by axel2906 »
Mads wrote: Monday 26 February 2018 14:47 Didnt help me. The loading text just disapered now :/
try with the ical for F1 (it's a public ical so everybody can use this) can you can get it from here https://www.gpupdate.net/en/calendar/27 ... -calendar/
calendars.F1 = { maxitems: 5, image: 'calendar.png', icalurl: 'webcal://www.gpupdate.net/en/calendar/273/2018-formula-1-calendar/calendar.ics'};
if it doesn"t work check the error from google (F12)
GuidoP18
Post by GuidoP18 »
Thanks Axel2906 you're code fixed it.
