Maybe the easiest question (if you know the solution.
albercola
Post by albercola »
Hi everyone, my first post with a problem that I tried to solve (useless) for several days.
this is the very simple blockly condition:
nothing happens if I put ON topolino and minnie. If I semplify the block with only one condition (only topolino or only minnie), tip change state correctly .
Log is:
2018-02-19 18:06:58.717 (Utenze attive) Light/Switch (minnie)
2018-02-19 18:07:00.839 User: Admin initiated a switch command (37/topolino/On)
2018-02-19 18:07:00.848 Error: EventSystem: Lua script error (Blockly), Name: disney_1 => [string "result = 0; weekday = os.date('*t')['wday']; ..."]:1: 'then' expected near 'comparevariable'
Can somebody help me, please?
thanks in advance
SweetPants
Re: Maybe the easiest question (if you know the solution.
Post by SweetPants »
Change >= to =
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
First pick the "and" block.
Put a condition to the left and one to the right.
Left: topolino=On
Right:minnie=On
albercola
Post by albercola »
Thanks for your reply. Tried but no works.
albercola
Post by albercola »
I'll became mad...
1) two fresh domoticz in two different raspi;
2) two different domoticz version:Version: 3.8924 Build Hash: 4b5824be and Version: 3.8153 Build Hash: 494fff7;
3) tried different symbols between operator AND : equal, unequal, more, less...
4) with only one condition (if a==x then...) works
5) what means exactly this error message:"2018-02-20 09:46:12.537 Error: EventSystem: Lua script error (Blockly), Name: disney_1 => [string "result =
Any idea about?
Domosapiens
albercola
Post by albercola »
Selected device (ALL).
Domosapiens
Left: topolino=On
Right:minnie=On
Make this:
(topolino=On) AND (minnie=On)
And NOT as yours:
topolino=(On AND (minnie=On)
albercola
Post by albercola »
Sorry for my stupidity but... if I put a condition on the left of the AND it's no possible to attach it to the left side...where is my mistake?
Domosapiens
Start from fresh.
Your If block is ok.
take an "and" Blockly
Then there is on the left space for a "=" blockly and on the right side for a "=" blockly
Add on the left topolino and On
Add on the right minnie and On
Study the wiki http://www.domoticz.com/wiki/Blockly
and look careful for the surroundings of each blockly part
Example of the AND structure
http://www.domoticz.com/wiki/File:Block ... _group.PNG
albercola
Post by albercola »
OMG! was really easy but I didn't focus on the level of each block! thank you, thank you so much Domosapiens for your precious help!
