Dashticz - Module Moonphases
clubeddie
Re: Dashticz - Module Moonphases
Cannot seems to get it working. Created 2 dummy switches
MoonPicture
MoonPhaseCheck
Then created 5 devices on the MoonPhaseCheck
Did not create any device on the MoonPicture (i cannot found info on this, but i think i must do here someting)
Adjust the script and placed it. That's all working, i retrieve data on the 5 devices. I can display data in Dashticz, but it don't show the image of the moon. Someone above said " (e.g. the MoonPicture variable contains "moon.89.png") " but i don't have this.
So i think i have to create a variable on MoonPicture, but cannot find any info. Can anyone help me?
MoonPicture
MoonPhaseCheck
CaesarPL
Why switches? Instruction is VERY clear describing it:clubeddie wrote: Sunday 04 February 2018 23:15 Cannot seems to get it working. Created 2 dummy switches
MoonPicture
MoonPhaseCheck
'2 uservariables'
clubeddie
Ok, i am confused, i read this;
As you can see there are some (dummy) devices that need to be created in Domoticz. 2 uservariables:
User variable Type
MoonPicture STRING
MoonphaseCheck STRING
So in hardware i created a dummy moonpicture and moonphasecheck.
In the dummy moonphase check i created 5 virtual sensors that are working.
How can i create a uservariable?
Edit: i found it. Menu never used before so i am trying to get it working. Thanks for your reply!
Plaffie
I have a strange problem. The moonpicture is the wrong side. The moon is waning crescent phase but the picture shows a waxing crescent phase. Am i the only one with this problem? i could rename all the pictures but maybe there is an easier solve. Is there a list with moonphase <-> picturenumber?
- RobertK
- Domoticz version: 3.8153
What coincidence... I was looking and wondering about the same thing yesterday. So, no you're not the only one. My picture also shows the
illuminated part at the wrong side.
I was looking at the moonphase script due to another problem I had. The script_time_moon.lua script polled the wunderground website every minute,
so I received the well known API usage alert email "Your wunderground API key (******) exceeded its allotted usage today by making 511 calls in a day but the limit is 500.".
By now, I have found the problem for this issue on my side, so I toss in here, maybe it's useful for anyone else as well:
The script itself is being called every 60 seconds. However, in the script is a timecheck that compares the current time against the time of the last
update of the 'MoonphaseCheck' user variable in Domoticz. If the time difference is less than 3600 seconds (1 hour), the poll to the wunderground
website is skipped. In my case, I had a typo in the variable name (MoophaseCheck) so the actual MoonphaseCheck variable itself didn't actually
exist in in my system and because of that, time difference check resulted every time in 3600. And this again resulted in a new poll to the wunderground website every 60 seconds...
Maybe this is helpful to know for every anyone else: Check this variable name. (I would have found it more logical to compare e.g. the update time of
the used '/var/tmp/phase.tmp' file with the current os-time, instead of checking a Domoticz user variable, but that's my opinion
Back to the incorrect picture: The picture number to be displayed is also calculated in this same .lua script.
The variable 'waardecheck' on line 123 in the script should likely be changed into 'is_waxing'. The 'is_waxing' variable is only set in
the statements above but its value is never used, while it probably should be the trigger to step into the 'if' part of the if-else statement
of lines 123 - 136.
Changing this variable will show the correct picture again.
of lines 123 - 136.
Plaffie
Thanks. changing the variable solved the problem.RobertK wrote: Saturday 10 February 2018 14:30 What coincidence... I was looking and wondering about the same thing yesterday. So, no you're not the only one. My picture also shows the
of lines 123 - 136.
clubeddie
Okay, how must the sentence be then?Plaffie wrote: Sunday 11 February 2018 13:02Thanks. changing the variable solved the problem.RobertK wrote: Saturday 10 February 2018 14:30 What coincidence... I was looking and wondering about the same thing yesterday. So, no you're not the only one. My picture also shows the
of lines 123 - 136.
Something like this?
if waardecheck==is_waxing then- RobertK
Just replace waardecheck into is_waxing, like:
if is_waxing==false then
picnumber=math.floor(...etc...)-
florisi
- Domoticz version: 2020beta
I'm having the same issue.jvanthof wrote: Monday 09 October 2017 23:59 The Moon Phase module is not showing the images of the moon... I think I have followed all the instructions to the letter. The /var/tmp/phases.tmp file is filled with info. The dummy devices and user variables get filled with information (e.g. the MoonPicture variable contains "moon.89.png") but on the dashticz website: nada...
When I inspect the elements using the developer tools of Safari, it looks like the image is not properly set in the DOM:
The "buttons.UNKNOWN" doesn't look right...Code: Select all
<div class="col-xs-12 transbg imgblock imgblock17610" data-id="buttons.UNKNOWN"> <div class="col-xs-12"> <div class="moon"></div> </div> </div>
My CONFIG.js (I thinks there's a typo on the Wiki btw...) contains these lines:andCode: Select all
buttons.moon = {width:12, isimage:true, refreshimage:60000, image:'moon'}Anyone knows what I'm missing?Code: Select all
columns[1] = {} columns[1]['blocks'] = ['garbage','s1',buttons.moon] columns[1]['width'] = 5;
Changed my CONFIG.js with config['idx_moonpicture'] = 1 (this the index of the uservariable)
Can someone help me with this?
- RobertK
Can you mention what steps/code you have already inserted yourself in the CONFIG.js file?
And if the file /var/temp/phase.tmp indeed contains the correct information, retrieved from wunderground?
florisi
Here is my CONFIG.js
All the dummy devices get the right values, so the temp file is correct.
var config = {}
config['language'] = 'nl_NL';
config['domoticz_ip'] = 'http://xxxxxxxxxxxxxxxxx';
config['app_title'] = 'ControlCenter';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['auto_positionning'] = 0;
config['idx_moonpicture'] = 1;
config['garbage_company'] = 'afvalwijzerarnhem';
config['garbage_icalurl'] = 0;
config['garbage_zipcode'] = 'xxxxxx';
config['garbage_street'] = 'xxxxxxx';
config['garbage_housenumber'] = '9';
config['garbage_maxitems'] = '12';
config['garbage_use_names'] = true;
config['garbage_use_colors'] = true;
config['garbage_icon_use_colors'] = true;
config['garbage_use_cors_prefix'] = true;
config['garbage'] = {
gft: {kliko: 'green', code: '#375b23', name: 'GFT', icon: 'img/garbage/kliko_green.png'},
pmd: {kliko: 'orange', code: '#db5518', name: 'PMD', icon: 'img/garbage/kliko_orange.png'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval', icon: 'img/garbage/kliko_grey.png'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier', icon: 'img/garbage/kliko_blue.png'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval', icon: 'img/garbage/kliko_red.png'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin', icon: 'img/garbage/kliko_brown.png'},
black: {kliko: 'black', code: '#000000', name: 'Zwart', icon: 'img/garbage/kliko_black.png'},
milieu: {kliko: 'yellow', code: '#f9e231', name: 'Geel', icon: 'img/garbage/kliko_yellow.png'},
kerstboom: {kliko: 'green', code: '#375b23', name: 'Kerstboom', icon: 'img/garbage/tree.png'},
var coins = {}
coins.bitcoin = { key:'bitcoin', currency: 'EUR', layout:'vertical',width:6 }
coins.monero = { key:'monero', currency: 'EUR', layout:'vertical',width:6 }
coins.bitcoincash = { key:'bitcoin-cash', amount: 0.03071800, currency: 'EUR', width:12 }
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Papier en Karton'] = 'Papier';
trashnames['Plastic, Metalen en Drankkartons(PMD)'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
var calendars = {}
calendars.business = { maxitems: 8, icalurl: 'https://calendar.google.com/calendar/ic ... /basic.ics' }
var publictransport = {}
publictransport.ovinfobus = { show_via: false, station: 'arnhem/bushalte-keulse-slag', provider: '9292-bus', icon: 'bus', width:5, results: 6 }
var tvguide = {}
tvguide.dutch = { key:'dutch', icon: 'fa-television', width:7, channels: [1,2,3,148], maxitems: 10 }
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Q-music","file":"http://icecast-qmusic.cdp.triple-it.nl/ ... ive_96.mp3"},
{"track":2,"name":"538 Hitzone","file":"http://vip-icecast.538.lw.triple-it.nl/WEB11_MP3"},
{"track":3,"name":"Slam! NonStop","file":"http://stream.radiocorp.nl/web10_mp3"},
{"track":4,"name":"100%NL","file":"http://stream.100p.nl/100pctnl.mp3"},
var buttons = {}
buttons.nunl = {key: 'nunl', width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', newwindow:true, url: 'http://www.nu.nl'}
buttons.nos = {key: 'nos', width:12, icon: 'fa-newspaper-o', title: 'Nos', url: 'http://www.nos.nl'}
buttons.moon = {width:12, isimage:true, refreshimage:60000, image: 'moon'}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['key'] = 'blocktitle_1';
blocks['blocktitle_1']['title'] = 'Example';
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = [buttons.moon,'garbage',coins.bitcoin,coins.monero,calendars.business]
columns[1]['width'] = 6;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',tvguide.dutch,publictransport.ovinfobus]
columns[2]['width'] = 4;
var config = {}
var coins = {}
var trashnames = {}
var calendars = {}
var tvguide = {}
var buttons = {}
var blocks = {}
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[2] = {}
- RobertK
I do get the moon picture (A big black circle, with just a small enlighted part today) with your CONFIG.js, so this CONFIG.js file does not seem be the problem.
When you look in the Domoticz (not Dashticz) dashboard itself and check the 'Current value' of the 'MoonPicture' user variable (Setup -> More Options - User Variables), does it show a filename there (like moon.44.png)?
If you do not see a User Variable there, then that may be your issue and you would need to create them (MoonphaseCheck and MoonPicture).
florisi
- RobertK
In the main.js script, I see that the IP-address is likely used to find your pictures:
This:
is the only thing I did not use from your file, since that needs to reflect my personal IP-address
Can you check if that address (with portnumber) is really correct and reflects where your Domoticz installation is running?
Something like: 'http://192.168.1.100:8080';
Another thing you may want to check: Are the pictures really present in your dasticz_v2/img/moon folder? (I would not know
why they wouldn't be there, but I'm trying to exhaust all possibilities I can think of).
BTW. the picture that is showing in your User variable is not the correct one, but that's a different issue. See a couple of post back (last weekend), about the 'waardecheck' variable in your .lua script.
function getMoonInfo(image){
req = $.getJSONP({
url: settings['domoticz_ip']+"/json.htm?type=command¶m=getuservariable&idx="+settings['idx_moonpicture']+"&jsoncallback=?",
type: 'GET',async: true,contentType: "application/json",dataType: 'jsonp',
florisi
Solved.
It was an issue with the ip-address.
florisi
By the way, the uservariable shows now: moon.45.png
Is this the correct one?
clubeddie
That solved the problem! Thank you.RobertK wrote: Sunday 11 February 2018 13:36 Just replace waardecheck into is_waxing, like:Code: Select all
if is_waxing==false then picnumber=math.floor(...etc...)
brain
hi the moon module stops working this morning does anyone has this problem ?
thanx
thanx
Jan Jansen
- Domoticz version: Stable
clubeddie
Same herebrain wrote: Saturday 03 March 2018 10:53 hi the moon module stops working this morning does anyone has this problem ?
thanx
