Cheap RGB controller
Jappie
Domoticz version: 4.9700
Post by Jappie »
I found a lot of topics about these kind of controllers, but I bought
 http://s.aliexpress.com/riyQFVJZ
And the remote is seen bij rflink(r45), I added all the buttons and can usse them in events, that is all working, but the controller does not react on the RFlink when trying to controller the led strip via Domoticz. So when using the button on the remote, Domoticz is telling me the buton is pressed and the controller reacts. When pressing the button on Domoticz, the controller is not reacting.
Remote is detected as Llight/Switch with subtype EV1527 and it is a always on type remote.
Any idea how to fix this?
Raspberry Pi + RFLink + CC2531
Derik
Re: Cheap RGB controller
Post by Derik »
Perhaps nuy 1 like this:
https://www.aliexpress.com/item-img/LED ... 47651.html
Works great
Jappie
Post by Jappie »
Derik wrote:Perhaps nuy 1 like this:
Works great
Not really, because I want to have a remote for direct control. Adding it to Domoticz is a bonus, but I cannot get it to work because the controller does not understand the RF-link commands. Probably the RF-Link is using the wrong protocol for sending the messages.
Derik
Post by Derik »
You can use this controller with the app and with domoticz @ the same time..
Jappie
Post by Jappie »
Derik wrote:You can use this controller with the app and with domoticz @ the same time..
I asked a question about how to be able to use this device with Domoticz. Pointing out another option is okay, repeating without reading a previous answer is annoying.
D3LTA
Domoticz version: 3.8153
Post by D3LTA »
Maybe he did, i don't think you understand... if you add the device to domoticz you can control it with any other 433mhz remote if you set it up right.
But i recommend you look at the other suggested option also, because the cheap rgb dimmer you pointed out are all using the same code... so if you have more of them, you can't controll them seperatly.
buster
Post by buster »
Derik wrote: Monday 27 February 2017 17:52 Perhaps nuy 1 like this:
Works great
Hi, could you write me small tutorial how to add it to domoticz?
TIA
buster
