Looking for an switch
Wilco
Domoticz version: 3.8153
Post by Wilco »
I want to replace more lightning-switches in my house, but the wife wants to simple push the (old) button.
Is there an switch which combines the classis switch and the domonticz control ?
Hobbybob
Re: Looking for an switch
Post by Hobbybob »
I don't have any experience with them, but from what I understood Qubino has Z-wave switches that can be built into regular switches.
Something like this: http://qubino.com/products/onoff-switches/
(these are on/off, there are also dimmer-versions of this product).
Perhaps other manufacturers also have these, but as I said: I have no experience with these.
Wilco
Post by Wilco »
Thanx for your reply,
but it is to difficult, i want simply to replace the one in the wall.
gijsje
Domoticz version: Stable
Post by gijsje »
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
tontze
Domoticz version: Beta Ch
Post by tontze »
gijsje wrote: Saturday 10 February 2018 22:57 i use these and work great
https://www.klikaanklikuit.nl/nl/produc ... laars.html
These are 433mhz, if you have lots of 433mhz devices, their signals might overlap and signal is not going through, hence, button might not work everytime. 433mhz devices are good when you dont need it to work at once, like temperature measuring, humidity etc.
Another backdraw is, that if you want to control them via domoticz, or app or something, they dont send confirmation about command succeed or not, therefore your domoticz might show lights are off, and they actually are not. Its a one way system.
But if you dont have too much 433mhz traffic, these do work fine :)
I myself have been trying to find similar, but z-wave. Have only found expencive ones and crappy like tkbhome :/
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
mrf68
Post by mrf68 »
Hobbybob
Post by Hobbybob »
That would work too, but from what I see it is exactly the same amount of installation work as the Qubino's, and you said you found those to be too difficult.
mrf68
Post by mrf68 »
? It was my first post in this thread, so I did not say I found those to be difficult.
Wilco
Post by Wilco »
i'm looking for a switch with has in 1-module:
- hand (old-way)
- 433 (domoticz)
what you show me is 2 modules, that is not what i'm, looking for, but thanx anyway
Hobbybob
Post by Hobbybob »
mrf68 wrote: Sunday 11 February 2018 11:25 ? It was my first post in this thread, so I did not say I found those to be difficult.
Sorry, I thought you were OP. I didn't read it correctly.
Hobbybob
Post by Hobbybob »
Wilco wrote: Sunday 11 February 2018 11:25 i'm looking for a switch with has in 1-module:
- hand (old-way)
- 433 (domoticz)
I think the wall-switches tontze suggested would be what you are looking for.They can be controlled by hand and by any other means of controlling KaKu (including Domoticz).
Wilco
Post by Wilco »
the problem with 2 modules are the batteries.
gizmocuz
Post by gizmocuz »
Any zwave (quibino, popp, ... ) build in modules will work. It might be a pain to build them into the wall, but the wife can operate them like normal switches. (as it always should be)
Wilco
Post by Wilco »
something like this
https://www.aliexpress.com/item/Sonoff- ... 0.0.BDvrPI
(dont buy, not working)
but than the old-fashion swicth
