Python Plugin Domoticz-Enigma2
ProjektC
- Domoticz version: 4.10717
I want to send orders to my Vu Enigma2 receiver.
https://github.com/kofec/Domoticz-Enigma2
But I can't find anything under Hardware after successful installation.
I have tested the last beta and it doesn't work.
I have now installed the last stable version, and it is not possible.
Rights set to 755
What am I doing wrong?
Rights set to 755
- 2.jpg (88.76 KiB) Viewed 8010 times
- 1.jpg (55.14 KiB) Viewed 8010 times
zicht
- Domoticz version: 2023.1+
Re: Python Plugin Domoticz-Enigma2
You need to restart domoticz
then you can select in hardware : enigma2 with kodi remote
If i look in my log it does not start (errors on XML dependencies)
So just installing the .PY file is not working ( at least for my config)
Hope it helps you moving forward
ProjektC
EventSystem - Python: Failed dynamic library load, install the latest libpython3.x library that is available for your platform.
i have install sudo apt-get install libpython3.4
ProjektC
sudo apt-get install python3-dev
2017-12-26 11:03:39.919 Error: (Enigma2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Enigma2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2017-12-26 11:03:39.919 Error: (Vuplus) Module Import failed, exception: 'ImportError'
2017-12-26 11:03:39.919 Error: (Vuplus) Module Import failed: ' Name: xmltodict'
arnoldg
I have a total crash of domoticz after adding the hardware.
After reboting, domoticz won't start.
only after deleting the plugin domoticz starts again.
Running Domoticz on a RP2, beta v3.8796
what could be wrong
what could be wrong
ProjektC
I have an RP 3 and the stable version 3.8153 and I can't do it.
I have now ordered a Logitech Harmony Hub.
I hope this will allow me to better control the devices with Domoticz.....
kofec
Install package "xmltodict" (pip for python3)
and check where it was installed
"if sys.platform.startswith('linux'):
# linux specific code here#
sys.path.append('/usr/local/lib/python3.5/dist-packages')
the best way is to first use script:
enigma2.py
enigma2.py
pacitzu
- Target OS: -
I installed xmltodict library withkofec wrote: Monday 22 January 2018 13:16 Install package "xmltodict" (pip for python3)
enigma2.py
pip3 install xmltodict
I found where the packages are installed with
$ python3 -m site
and then In plugin.py I changed
pathOfPackages = '/usr/local/lib/python3.5/dist-packages'
in
pathOfPackages = '/home/pi/.local/lib/python3.5/site-packages'
and now it works.
Thank you
odorf
I've changed the variable to : pathOfPackages = '/usr/lib/python2.7/dist-packages' in enigma2.py file and this script runs perfectly
However after doing the same in plugin.py file Domoticz is stopping without any error in log. What can I do to fix it?
sys.path = [
'/home/pi/domoticz/plugins/Domoticz-Enigma2',
'/usr/lib/python2.7',
'/usr/lib/python2.7/plat-arm-linux-gnueabihf',
'/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old',
'/usr/lib/python2.7/lib-dynload',
'/home/pi/.local/lib/python2.7/site-packages',
'/usr/local/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages',
'/usr/lib/python2.7/dist-packages/gtk-2.0',
USER_BASE: '/home/pi/.local' (exists)
USER_SITE: '/home/pi/.local/lib/python2.7/site-packages' (exists)
ENABLE_USER_SITE: True
kofec
Domoticz only supports python 3.x
so please correct this variable once again.
using pip3 install needed modules/packages
odorf
have some progress
I've installed the xmltodict package and now enigma2.py is running without any changes in the file.
unfortunatelly it didn't help the plugin to run.
any hint which modules/packages should install? Domoticz hangs and kills the process.
*the hint is: the same situation with any other plugin I want execute
(tried with 2 different rpi's with no luck).
kofec
I just tried on latest docker and it fine. Maybe you can backup your domoticz folder and try latest Domoticz beta. Can you also share what python version you have. Just type python3. In my case it is:
python3
Python 3.5.3 (default, Jan 19 2017, 14:11:04)
[GCC 6.3.0 20170124] on linux
Type "help", "copyright", "credits" or "license" for more information.
python3
odorf
I have the same Python version as You have.
Which distribution You are using? Jessie or Stretch?
uronito
hi,
with last version of beta domoticz plugin dont work.
2018-08-27 22:12:52.338 Error: Receptor-Enigma hardware (52) thread seems to have ended unexpectedly-
kofec
Hi, I have added some fix please try latest version ?
uronito
Hi Kofec,
I try the last version of plugin. Continue same Fail.
2018-09-04 10:02:21.375 Error: Receptor-Enigma hardware (52) thread seems to have ended unexpectedly-
NoProfesor
- Target OS: -
Which ? pathlib
pathOfPackages = '/usr/lib/python3/dist-packages'
~ $ python3 -m site
sys.path = [
'/home/pi',
'/usr/lib/python35.zip',
'/usr/lib/python3.5',
'/usr/lib/python3.5/plat-arm-linux-gnueabihf',
'/usr/lib/python3.5/lib-dynload',
'/home/pi/.local/lib/python3.5/site-packages',
'/usr/local/lib/python3.5/dist-packages',
'/usr/lib/python3/dist-packages',
USER_SITE: '/home/pi/.local/lib/python3.5/site-packages' (exists)
2018-11-26 19:29:41.571 Error: (Enigma2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Enigma2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-11-26 19:29:41.572 Error: (VUplus) Module Import failed, exception: 'ImportError'
2018-11-26 19:29:41.572 Error: (VUplus) Module Import failed: ' Name: xmltodict'
2018-11-26 19:29:41.572 Error: (VUplus) Error Line details not available.
2018-11-26 19:31:00.403 Error: VUplus hardware (7) thread seems to have ended unexpectedly
kofec
Check where is this package: xmltodict
NoProfesor
- Target OS: -
is in pathOfPackages = '/home/pi/.local/lib/python3.5/site-packages'
what is wrong?
LOG:
what is wrong?
LOG:
2018-11-26 22:37:39.662 Error: (Enigma2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Enigma2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-11-26 22:37:39.662 Error: (VUplus) Module Import failed, exception: 'ImportError'
2018-11-26 22:37:39.662 Error: (VUplus) Module Import failed: ' Name: xmltodict'
2018-11-26 22:37:39.662 Error: (VUplus) Error Line details not available.
2018-11-26 22:38:40.667 Error: (Enigma2) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/Domoticz-Enigma2/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-11-26 22:38:40.667 Error: (VUplus) Module Import failed, exception: 'ImportError'
2018-11-26 22:38:40.667 Error: (VUplus) Module Import failed: ' Name: xmltodict'
2018-11-26 22:38:40.667 Error: (VUplus) Error Line details not available.
2018-11-26 22:40:01.038 Error: VUplus hardware (8) thread seems to have ended unexpectedly
2018-11-26 22:40:30.043 Error: VUplus hardware (8) thread seems to have ended unexpectedly -
NoProfesor
- Target OS: -
I see on hardware, but not on devices
