Selector dzvents
parrotface
Selector dzvents
Post by parrotface »
I am struggling with a selector switch
I am trying to change my heating zones with a selector switch. I can do with separate switches
Do I have to use the value it has created i.e. 10 20 30 etc
if so what is the correct syntax to read the various buttons of the selector switch
emme
Domoticz version: latest
Re: Selector dzvents
Post by emme »
domoticz.device('myHeatSelector').switchSelector(10)
domoticz.devices('mySetPoint').updateSetPoint(domoticz.device('myHeatSelector').levelName)
"We always done this way"
parrotface
Thanks for reply
my test code
active = true,
devices = {
'boost test 126', -- name of switch
'selector', -- name of selector switch
timer = {'every 1 minutes'}
execute = function(domoticz, device, triggerInfo)
domoticz.log('trigger == > '..triggerInfo.type)
if triggerInfo.type == domoticz.EVENT_TYPE_TIMER then
-- do timer event stuff
domoticz.log(' tttttt Hey! timer ttttttttttttttttttt')
elseif triggerInfo.type == domoticz.EVENT_TYPE_DEVICE then
-- do device event stuff
if (device.state == 'On') then
domoticz.log('Hey! I am on! xxxxxxx Switch On xxxxxxxxxxxxxxxxxxxxxxx')
print " on "
domoticz.log('Hey! I am off! yyyyyyyy Switch Off Off Off Switch Off Off Off ')
if domoticz.device('selector').switchSelector(10) then
domoticz.log('its 10 ')
elseif domoticz.device('selector').switchSelector(20) then
domoticz.log('its 20 ')
domoticz.log(domoticz.devices('selector').value)
log
2018-02-08 12:37:08.159 dzVents: Info: ------ Start internal script: selector: Device: "selector (dummy1)", Index: 871
2018-02-08 12:37:08.159 Error: dzVents: Error: An error occured when calling event handler selector
2018-02-08 12:37:08.159 Error: dzVents: Error: .../domoticz/scripts/dzVents/generated_scripts/selector.lua:19: attempt to index global 'domoticz' (a nil value)
2018-02-08 12:37:08.159 dzVents: Info: ------ Finished selector
thanks
emme
Post by emme »
need to know exactely where is line 19 but I assume is on the if statement
as per dzvents 2.4.1 the triggerInfo is depreciated (but still valid)
try to replace
with
elseif device.isDevice then
parrotface
changed elseif and its now working OK
was --elseif triggerInfo.type == domoticz.EVENT_TYPE_DEVICE then
now elseif device.isDevice then
Thanks for your fast help been struggling for nearly a week and you fixed in minutes.
Out of interest where do I find information for these types of situations
Thanks again
parrotface
I think I spoke too soon it's not working now don't know what is happening
errors
2018-02-08 14:02:26.462 Error: dzVents: Error: An error occured when calling event handler hall
2018-02-08 14:02:26.462 Error: dzVents: Error: ...e/pi/domoticz/scripts/dzVents/generated_scripts/hall.lua:28: attempt to call field 'device' (a nil value)
Code
active = true,
devices = {
print " on "
if domoticz.device('selector').switchSelector(10) then -- THIS IS LINE 28
Note the error is now line 28 - indicated in code above
parrotface
Update errors have disappeared but the if section line 28 is not doing anything
also tried
if domoticz.devices('selector').value == "Breakfast" then
domoticz.log('its Breakfast')
the following line returns Breakfast
following copied from switch
Selector Levels:
Level Level name Order
0 Off
10 Breakfast [Rename] [Delete]
20 Snug [Rename] [Delete]
30 Hall [Rename] [Delete]
40 Lounge [Rename] [Delete]
50 Dinning [Rename] [Delete]
emme
Post by emme »
uh.. this is a wired behavior.... it should be not supposed to act like this...
first of all.. what version are you running?
as per dzVents 2.4 ( https://www.domoticz.com/wiki/DzVents:_ ... _scripting ) your script should look like:
    active = true,
    devices = {
execute = function(domoticz, device )
    domoticz.log('trigger == > '..device.trigger)
    if device.isTimer then
        if (device.state ~= 'Off') then
            domoticz.log('Hey! Not sure I\'m on.. anyhow, if I am a selector, I\'m NOT off!! xxxxxxx Switch On xxxxxxxxxxxxxxxxxxxxxxx')
        if domoticz.device('selector').level == 10 then -- THIS IS LINE 28
        elseif domoticz.device('selector').level == 20 then
        domoticz.log(domoticz.devices('selector').levelName)
parrotface
seem to have solve part of the problem an works for what I need at the moment
if domoticz.devices('selector').state == 'Breakfast' then --- this works OK
also domoticz.devices('selector').levelName) -- returns Breakfast
but domoticz.devices('selector').value -- or .Value Does Not work
at least I can get the name of selector but not the value but I can work around that.
Many Thanks again for all your help and hopefully I will be able to boost my heating in different zones now just using a single selector.
kimot
Domoticz version: v3.8153
Post by kimot »
Here is my way, how I send selector value ( 0, 10, 20,... ) to ESPEasy.
For inspiration part of code my "every minute" script, which send state of selector to ESPeasy every minute.
 local mode = domoticz.devices('Filip_Control')
            local url2= 'http://192.168.1.105/control?cmd=event,modeSet='..(mode.level)..''
            print(url2)
            domoticz.openURL(url2)
I think
".level" is what you looking for.
In my case I am sending:
http://192.168.1.105/control?cmd=event,modeSet=0
or
http://192.168.1.105/control?cmd=event,modeSet=10
or
http://192.168.1.105/control?cmd=event,modeSet=20
according selector state.
https://www.domoticz.com/wiki/DzVents:_ ... or_etc..29
RPi2 Domoticz v 4.10717
10 x Sonoff Basic - ESPeasy
1 x Wemos D1 - ESPeasy
1 x Shelly Plus Plug S
1 x Sonoff S26 - ESPeasy
1 x Shelly 1
1 x MySensors HC-SR04
1 x MySenosrs wifi gateway
1 x RFLink
4x Cam IPC-T240H
