Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Madgeni
blinds are inverted (open = close) - don't judge me. i'll look at it - definitely there was a reason (about 18 months ago) why I got to this point..!
Madgeni
From the original Alexa development - feedback from the community came to :
"the blinds should be put back to the correct values ... (on = On, Off=Off ... it is more logical that turn on closes the blinds and turn off opens them"
Happy to have that conversation again, but would want consensus
willumpie82
- Target OS: -
hi, thanks for creating this great initiative!
I did al the steps but i can't get it to work:
- Created a controlicz user with user rights and device sharing enabled => OK ??
- Domain is available via SSH domoticz.*****.nl can login with my admin account and controlicz account => OK
- From the controlicz page, the test succeeds when i click the test connection button => OK
- Google Home app display's the "[test] controlicz" instance when adding new device => OK
- when adding i got a prompt to login ( I login with my Controlicz page credentialz) => OK
- pop-up page for allow/deny connectoin => OK
- when G-Home is linking [test] controlicz => ERROR, couldn't update settings
==> when i use the test credentials listed on you G-project-page it succesfully adds the controls.
What am I doing wrong?
Windows Server 2012 + domoticz + https + sub-domain with reverse Proxy (URL rewrite)
- Zwave.me module
- Plugwise (via Python scripting)
- Omnik Solar (Via Python scripting)
- Zwave.me module
Madgeni
do you have devices in a Room Plan in your Domoticz?
Fred78
Hmmm...funny. Because when I say "Ouvre le volet du salon", it works fine. I mean it says "ok j'allume la lumière volet du salon" and it opens the shutter.getget wrote: Wednesday 07 February 2018 14:18 Hello, today, no 404
l have blinds defined in domoticz. What should I say to open them ?
When I say "ouvre le velux" (open the blind called velux in french) Google says "ok J'allume la lumière velux" (ok I turn on the light velux" ans the blind .... Closes.
What kind of device are you using for you're blinds? My shutter is managed by a Qubino Zwave module that is recognized by domoticz as a dimmer.
willumpie82
- Target OS: -
I do have multiple room plans, is there a specific room plan required?Madgeni wrote: Wednesday 07 February 2018 14:34 do you have devices in a Room Plan in your Domoticz?
- Zwave.me module
- Zwave.me module
Madgeni
no, as long as there is one it should work - Can you PM me your email, and i'll take a lookwillumpie82 wrote: Wednesday 07 February 2018 16:12I do have multiple room plans, is there a specific room plan required?Madgeni wrote: Wednesday 07 February 2018 14:34 do you have devices in a Room Plan in your Domoticz?
Madgeni
check your SSL port is correct in Controlicz - oh and that the username/password you've given Controlicz can access your Domoticz instancewillumpie82 wrote: Wednesday 07 February 2018 14:33 hi, thanks for creating this great initiative!
willumpie82
- Target OS: -
hi, thanks for the support!Madgeni wrote: Wednesday 07 February 2018 17:28
check your SSL port is correct in Controlicz - oh and that the username/password you've given Controlicz can access your Domoticz instance![]()
I have entered port 443, (https), and created a Controlicz user + pass, when i click "test domoticz", controlicz can connect to domoticz
(for a quick test i changed to port 80, than controlicz can't connect)
- Zwave.me module
- Zwave.me module
Madgeni
ok, so have you now tried
Google Home app display's the "[test] controlicz" instance when adding new device?
willumpie82
- Target OS: -
yep, and after that i get a login prompt, with which i login with my controlicz website credentials, followed by an accept/deny screen, when accepted i'm brought back to G-home app, and that follows with a "can't configure, check connection error".Madgeni wrote: Wednesday 07 February 2018 20:24 ok, so have you now tried
- Zwave.me module
- Zwave.me module
Madgeni
Ok - PM sentwillumpie82 wrote: Thursday 08 February 2018 8:12yep, and after that i get a login prompt, with which i login with my controlicz website credentials, followed by an accept/deny screen, when accepted i'm brought back to G-home app, and that follows with a "can't configure, check connection error".Madgeni wrote: Wednesday 07 February 2018 20:24 ok, so have you now tried
Thanks for the answer.Fred78 wrote: Wednesday 07 February 2018 15:27Hmmm...funny. Because when I say "Ouvre le volet du salon", it works fine. I mean it says "ok j'allume la lumière volet du salon" and it opens the shutter.getget wrote: Wednesday 07 February 2018 14:18 Hello, today, no 404
Lizard
I also got it running here. Thanks for the support madgeni. Donation sent.
Madgeni
Thank you Lizard - I really appreciate the donation, they *really* help keep Controlicz running
michel30
I was checking the site controlicz and I have a question for sign up:
Signup to Controlicz
Username or Email : Okay this clear I enter my email adress in.
Password : what password do you need? because is strange if you need my email adress password.
domoticz.host.net : For this I need to create an DNS server that will connect to my domoticz?
443 : okay, this is clear open the port to my domoticz.
controlicz_user : must I create the same user name on my domoticz?
controlicz_password : Enter the password from my domoticz with the user what I add above.
Regards,
Michel
Regards,
Michel
Madgeni
Hi -michel30 wrote: Friday 09 February 2018 14:53 Hello,
Regards,
Michel
Email;
Password for Controlicz account (NOT your actual email password!)
yep - domoticz DNS (or static IP)
port - whatever you've configured domoticz to use - i would suggest non-standard port number
controlicz_user/password - the domoticz username/password you've created for Controlicz ON your Domoticz instance.
sandervanpelt
- Domoticz version: 4.10404
Since a few days I am also no longer able to sync my devices, Google Home responds with 'An error occurred while syncing Controlicz'. I am still able to control my devices. Any suggestions?mark.sellwood wrote: Saturday 30 December 2017 19:54 Hi, My Google Home has stopped connecting to my Domoticz, when I ask Google to sync devices i get "Sorry an error occurred syncing Controlicz" When I look at my firewall logs I don't see any incoming connections. If I go to https://www.controlicz.com login and click "Test connection to your Domoticz" this passes and I see an incoming connection on my firewall from an Amazon IP address.
Is something broken?
Sander
Madgeni
Can you disable and reenable the test in the simulation?
sandervanpelt
Disabled and reenabled, but still not able to syncMadgeni wrote: Saturday 10 February 2018 11:55 Can you disable and reenable the test in the simulation?
Sander
