blinds are inverted (open = close) - don't judge me. i'll look at it - definitely there was a reason (about 18 months ago) why I got to this point..!
From the original Alexa development - feedback from the community came to :
"the blinds should be put back to the correct values ... (on = On, Off=Off ... it is more logical that turn on closes the blinds and turn off opens them"
Happy to have that conversation again, but would want consensus
- Target OS: -
hi, thanks for creating this great initiative!
I did al the steps but i can't get it to work:
- Created a controlicz user with user rights and device sharing enabled => OK ??
- Domain is available via SSH domoticz.*****.nl can login with my admin account and controlicz account => OK
- From the controlicz page, the test succeeds when i click the test connection button => OK
- Google Home app display's the "[test] controlicz" instance when adding new device => OK
- when adding i got a prompt to login ( I login with my Controlicz page credentialz) => OK
- pop-up page for allow/deny connectoin => OK
- when G-Home is linking [test] controlicz => ERROR, couldn't update settings
==> when i use the test credentials listed on you G-project-page it succesfully adds the controls.
What am I doing wrong?
Windows Server 2012 + domoticz + https + sub-domain with reverse Proxy (URL rewrite)
- Zwave.me module
- Plugwise (via Python scripting)
- Omnik Solar (Via Python scripting)
- Zwave.me module
do you have devices in a Room Plan in your Domoticz?
Hmmm...funny. Because when I say "Ouvre le volet du salon", it works fine. I mean it says "ok j'allume la lumière volet du salon" and it opens the shutter.getget wrote: ↑Wednesday 07 February 2018 14:18 Hello, today, no 404
l have blinds defined in domoticz. What should I say to open them ?
When I say "ouvre le velux" (open the blind called velux in french) Google says "ok J'allume la lumière velux" (ok I turn on the light velux" ans the blind .... Closes.
What kind of device are you using for you're blinds? My shutter is managed by a Qubino Zwave module that is recognized by domoticz as a dimmer.
- Target OS: -
I do have multiple room plans, is there a specific room plan required?
- Zwave.me module
- Zwave.me module
no, as long as there is one it should work - Can you PM me your email, and i'll take a lookwillumpie82 wrote: ↑Wednesday 07 February 2018 16:12I do have multiple room plans, is there a specific room plan required?
check your SSL port is correct in Controlicz - oh and that the username/password you've given Controlicz can access your Domoticz instancewillumpie82 wrote: ↑Wednesday 07 February 2018 14:33 hi, thanks for creating this great initiative!
- Target OS: -
hi, thanks for the support!
I have entered port 443, (https), and created a Controlicz user + pass, when i click "test domoticz", controlicz can connect to domoticz
(for a quick test i changed to port 80, than controlicz can't connect)
- Zwave.me module
- Zwave.me module
ok, so have you now tried
Google Home app display's the "[test] controlicz" instance when adding new device?
- Target OS: -
yep, and after that i get a login prompt, with which i login with my controlicz website credentials, followed by an accept/deny screen, when accepted i'm brought back to G-home app, and that follows with a "can't configure, check connection error".
- Zwave.me module
- Zwave.me module
Ok - PM sentwillumpie82 wrote: ↑Thursday 08 February 2018 8:12yep, and after that i get a login prompt, with which i login with my controlicz website credentials, followed by an accept/deny screen, when accepted i'm brought back to G-home app, and that follows with a "can't configure, check connection error".
Thanks for the answer.Fred78 wrote: ↑Wednesday 07 February 2018 15:27Hmmm...funny. Because when I say "Ouvre le volet du salon", it works fine. I mean it says "ok j'allume la lumière volet du salon" and it opens the shutter.getget wrote: ↑Wednesday 07 February 2018 14:18 Hello, today, no 404
I also got it running here. Thanks for the support madgeni. Donation sent.
Thank you Lizard - I really appreciate the donation, they *really* help keep Controlicz running
I was checking the site controlicz and I have a question for sign up:
Signup to Controlicz
Username or Email : Okay this clear I enter my email adress in.
Password : what password do you need? because is strange if you need my email adress password.
domoticz.host.net : For this I need to create an DNS server that will connect to my domoticz?
443 : okay, this is clear open the port to my domoticz.
controlicz_user : must I create the same user name on my domoticz?
controlicz_password : Enter the password from my domoticz with the user what I add above.
Regards,
Michel
Regards,
Michel
Hi -michel30 wrote: ↑Friday 09 February 2018 14:53 Hello,
Regards,
Michel
Email;
Password for Controlicz account (NOT your actual email password!)
yep - domoticz DNS (or static IP)
port - whatever you've configured domoticz to use - i would suggest non-standard port number
controlicz_user/password - the domoticz username/password you've created for Controlicz ON your Domoticz instance.
- Domoticz version: 4.10404
Since a few days I am also no longer able to sync my devices, Google Home responds with 'An error occurred while syncing Controlicz'. I am still able to control my devices. Any suggestions?mark.sellwood wrote: ↑Saturday 30 December 2017 19:54 Hi, My Google Home has stopped connecting to my Domoticz, when I ask Google to sync devices i get "Sorry an error occurred syncing Controlicz" When I look at my firewall logs I don't see any incoming connections. If I go to https://www.controlicz.com login and click "Test connection to your Domoticz" this passes and I see an incoming connection on my firewall from an Amazon IP address.
Is something broken?
Sander
Can you disable and reenable the test in the simulation?
