Python Plugin: MoonPhases
- ycahome
- Domoticz version: lat Beta
Hi there.
I have read on this forum about an idea for "Moon Phases" script, jackslayter was the initial poster.....
I have managed to create such plugin.
Plugin updates a "Custom Sensor" Value with current state of Moon. This value can be used later on in order to update any scripts or to be used just a cosmetic improvement.
I hope you like it.
-->NOTE: This plugin requires Weather Underground key<--
Find latest version to https://github.com/ycahome/MoonPhases:
Installation instructions (you can USE PP-MANAGER plugin from http://www.domoticz.com/forum/viewtopic ... 193c8933a0 to install):
- Create Plugin Folder "MoonPhases" under "domoticz/plugins" folder
- Save this script as "plugin.py" on "MoonPhases" folder
- Extract "MoonPhases.zip" to "MoonPhases" folder
- Restart domoticz service.
- Add a new entry of this Hardware on your domoticz installation (Setup/Hardware/select and add "Moon Phases")
What am going to see?:
- Plugin will auto-add one Custom Sensor on your "Utility" Section named "<Your Hardware Name>- Lune".
I hope you like it.
https://www.youtube.com/siakavelisgr
febalci
Re: Python Plugin: MoonPhases
@ycahome,
great work, exactly what was looking for some time, but too lazy to write a plugin about it
One question; is there a specific reason why you used urllib instead of native HTTP/json connection of the Plugin Framework?
corederoma82
It's possible that I have not plugin folder?
- Immagine.png (36.68 KiB) Viewed 5966 times
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
febalci
Install 32 bit Python3 first, then create a plugin folder.
corederoma82
corederoma82
Another question....where I have to put the weather key?
- ycahome
Here:corederoma82 wrote: Monday 05 February 2018 10:01 Another question....where I have to put the weather key?
assenzuid
Great and thanks for sharing.
Would be very nice if Moonset and Moonrise, and Percent of the Moon Illuminated will be showed in a dummy sensor.
Is that possible?
Is that possible?
- Marci
- Domoticz version: 3.8153
Ace - would be a useful astronomy tool if it could also give % cloud cover for a given Lat/Lon...
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
assenzuid
When active my Domoticz Dashboard crashes.
Running Beta V3.8889
- ycahome
Thank you.assenzuid wrote: Tuesday 06 February 2018 17:52 Great and thanks for sharing.
Is that possible?
Your comments noted for the next version
- ycahome
Cloud cover? Astronomy?Marci wrote: Tuesday 06 February 2018 18:04 Ace - would be a useful astronomy tool if it could also give % cloud cover for a given Lat/Lon...
Maybe you mean % of moon covered.
- ycahome
Can I suppose that you have python installed properly?assenzuid wrote: Tuesday 06 February 2018 18:10 When active my Domoticz Dashboard crashes.
Would be nice if you can post some logs from your /var/log/syslog (if you have default log settings)
- Marci
Umm no... % cloud cover. As in, if I look up, are there clouds in the way of the sky... then astronomers / astrophotographers such as myself can get an alert when the sky is clear, and use the sensor to trigger observatory automation (slide off roof, fire up scope etc). DarkSkies makes it available in their JSON feed but the current DarkSkies sensors for Domoticz don’t utilise it. If WeatherUnderground make it available it’d be good to have bundled in with moon phase, as one generally can’t do much astrophotography when there’s a full moon due to the additional contribution it makes to light pollution. Ideally a combination of both moon phase and local cloud cover would be perfect for triggering automated setups. Seeing as my entire observatory / astrophotography rig is run from the same RaspberryPi that runs my Domoticz setup it just keeps everything nice and contained in a single unit.
- htilburgs
After installing MoonPhases Plugin, Domoticz Crashes:
Domoticz v3.8889
Domoticz Log Entry:
/var/log/syslog:
Further information about my system:
Domoticz v3.8889
Domoticz Log Entry:
2018-02-06 23:47:52.717 (Maanfases) Started.
2018-02-06 23:47:52.913 Error: Domoticz received fatal signal 11 !...
2018-02-06 23:47:52.915 Error: /home/pi/domoticz/domoticz() [0x246814]
2018-02-06 23:47:52.915 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x2468cc]
2018-02-06 23:47:52.915 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c136b0]
Feb 6 23:45:26 raspberrypi3 systemd[1]: Starting LSB: Home Automation System...
Feb 6 23:45:26 raspberrypi3 domoticz.sh[11910]: 2018-02-06 23:45:26.621 Domoticz V3.8889 (c)2012-2018 GizMoCuz
Feb 6 23:45:26 raspberrypi3 domoticz.sh[11910]: 2018-02-06 23:45:26.621 Build Hash: 7d40a8bc, Date: 2018-02-06 13:16:43
Feb 6 23:45:26 raspberrypi3 domoticz.sh[11910]: 2018-02-06 23:45:26.622 Startup Path: /home/pi/domoticz/
Feb 6 23:45:26 raspberrypi3 domoticz.sh[11910]: domoticz: Domoticz is starting up....
Feb 6 23:45:26 raspberrypi3 domoticz: Domoticz is starting up....
Feb 6 23:45:26 raspberrypi3 domoticz: Domoticz running...
Feb 6 23:45:26 raspberrypi3 systemd[1]: Started LSB: Home Automation System.
Feb 6 23:47:34 raspberrypi3 systemd[1]: Started Session c49 of user pi.
Feb 6 23:49:39 raspberrypi3 systemd[1]: Stopping LSB: Home Automation System...
Feb 6 23:49:40 raspberrypi3 systemd[1]: Stopped LSB: Home Automation System.Code: Select all
pi@raspberrypi3:/ $ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 9.3 (stretch)
Release: 9.3
Codename: stretchCode: Select all
pi@raspberrypi3:/ $ uname -a
Linux raspberrypi3 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/LinuxCode: Select all
pi@raspberrypi3:/ $ python --version
Python 2.7.13
pi@raspberrypi3:/ $ python3 --version
Python 3.5.3Code: Select all
pi@raspberrypi3:/ $ dpkg --list | grep python
ii dh-python 2.20170125 all Debian helper tools for packaging Python libraries and applications
ii libpython-stdlib:armhf 2.7.13-2 armhf interactive high-level object-oriented language (default python version)
ii libpython2.7-minimal:armhf 2.7.13-2+deb9u2 armhf Minimal subset of the Python language (version 2.7)
ii libpython2.7-stdlib:armhf 2.7.13-2+deb9u2 armhf Interactive high-level object-oriented language (standard library, version 2.7)
ii libpython3-dev:armhf 3.5.3-1 armhf header files and a static library for Python (default)
ii libpython3-stdlib:armhf 3.5.3-1 armhf interactive high-level object-oriented language (default python3 version)
ii libpython3.4:armhf 3.4.4-3 armhf Shared Python runtime library (version 3.4)
ii libpython3.4-minimal:armhf 3.4.4-3 armhf Minimal subset of the Python language (version 3.4)
ii libpython3.4-stdlib:armhf 3.4.4-3 armhf Interactive high-level object-oriented language (standard library, version 3.4)
ii libpython3.5:armhf 3.5.3-1 armhf Shared Python runtime library (version 3.5)
ii libpython3.5-dev:armhf 3.5.3-1 armhf Header files and a static library for Python (v3.5)
ii libpython3.5-minimal:armhf 3.5.3-1 armhf Minimal subset of the Python language (version 3.5)
ii libpython3.5-stdlib:armhf 3.5.3-1 armhf Interactive high-level object-oriented language (standard library, version 3.5)
ii python 2.7.13-2 armhf interactive high-level object-oriented language (default version)
ii python-apt-common 1.1.0~beta5 all Python interface to libapt-pkg (locales)
ii python-minimal 2.7.13-2 armhf minimal subset of the Python language (default version)
ii python-rpi.gpio 0.6.3~stretch-1 armhf Python GPIO module for Raspberry Pi
ii python2.7 2.7.13-2+deb9u2 armhf Interactive high-level object-oriented language (version 2.7)
ii python2.7-minimal 2.7.13-2+deb9u2 armhf Minimal subset of the Python language (version 2.7)
ii python3 3.5.3-1 armhf interactive high-level object-oriented language (default python3 version)
ii python3-apt 1.1.0~beta5 armhf Python 3 interface to libapt-pkg
ii python3-dev 3.5.3-1 armhf header files and a static library for Python (default)
ii python3-minimal 3.5.3-1 armhf minimal subset of the Python language (default python3 version)
ii python3.5 3.5.3-1 armhf Interactive high-level object-oriented language (version 3.5)
ii python3.5-dev 3.5.3-1 armhf Header files and a static library for Python (v3.5)
ii python3.5-minimal 3.5.3-1 armhf Minimal subset of the Python language (version 3.5)
pi@raspberrypi3:/ $ Hardware:
- ycahome
Hi there again.htilburgs wrote: Tuesday 06 February 2018 23:59 After installing MoonPhases Plugin, Domoticz Crashes:
Domoticz v3.8889
Domoticz Log Entry:
Your installation seems ok. I can't tell what exactly is causing this behavior.
You remind me some months ago that I personally faced the same behavior with another plugin.
Ended up to reinstall Domoticz and recreate database/sensors from scratch.
Don't get me wrong, am not saying that the plugin is correct and your installation is wrong. Just saying that didn't found any solution for "Domoticz received fatal signal 11 !..." error.
Do you have other plugins working?
- ycahome
Marci wrote: Tuesday 06 February 2018 23:24 Umm no... % cloud cover. As in, if I look up, are there clouds in the way of the sky...
Did you checked "Weather Underground" Hardware of Domoticz to see if this information is currently provided? I have a "Visibility" sensor on my setup maybe this can give you an indication (at least)!!
I would be glad to include any functionality on "Moon Phases" plugin but,i believe that "% Cloud cover"
is more "Weather" than "Moon status" related. Given that, if it is not provided via "Weather Underground" Hardware, maybe you can request to be added.
assenzuid
ycahome wrote: Tuesday 06 February 2018 19:43Can I suppose that you have python installed properly?assenzuid wrote: Tuesday 06 February 2018 18:10 When active my Domoticz Dashboard crashes.
With plugin enabled/installed
var/log/syslog
Feb 6 18:06:48 MLTHomeDom systemd[1]: Starting LSB: Home Automation System...
Feb 6 18:06:48 MLTHomeDom domoticz.sh[24792]: 2018-02-06 18:06:48.225 Domoticz V3.8889 (c)2012-2018 GizMoCuz
Feb 6 18:06:48 MLTHomeDom domoticz.sh[24792]: 2018-02-06 18:06:48.225 Build Hash: 7d40a8bc, Date: 2018-02-06 13:16:43
Feb 6 18:06:48 MLTHomeDom domoticz.sh[24792]: 2018-02-06 18:06:48.226 Startup Path: /home/pi/domoticz/
Feb 6 18:06:48 MLTHomeDom domoticz.sh[24792]: domoticz: Domoticz is starting up....
Feb 6 18:06:48 MLTHomeDom domoticz: Domoticz is starting up....
Feb 6 18:06:48 MLTHomeDom domoticz: Domoticz running...
Feb 6 18:06:48 MLTHomeDom systemd[1]: Started LSB: Home Automation System.
Feb 6 18:07:32 MLTHomeDom systemd[1]: Created slice User Slice of root.
Feb 6 18:07:32 MLTHomeDom systemd[1]: Starting User Manager for UID 0...
Feb 6 18:07:32 MLTHomeDom systemd[1]: Started Session c5 of user root.
Feb 6 18:08:00 MLTHomeDom systemd[1]: Stopping LSB: Home Automation System...
Feb 6 18:08:00 MLTHomeDom systemd[1]: Stopped LSB: Home Automation System.Code: Select all
pi@MLTHomeDom:~ $ python --version
Python 2.7.13
pi@MLTHomeDom:~ $ python3 --version
pi@MLTHomeDom:~ $ lsb_release -a
Release: 9.3
pi@MLTHomeDom:~ $ uname -a
Linux MLTHomeDom 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/LinuxCode: Select all
pi@MLTHomeDom:~ $ dpkg --list | grep python
ii python-cffi-backend 1.9.1-2 armhf Foreign Function Interface for Python calling C code - backend
ii python-chardet 2.3.0-2 all universal character encoding detector for Python2
ii python-cryptography 1.7.1-3+b2 armhf Python library exposing cryptographic recipes and primitives (Python 2)
ii python-enum34 1.1.6-1 all backport of Python 3.4's enum package
ii python-idna 2.2-1 all Python IDNA2008 (RFC 5891) handling (Python 2)
ii python-ipaddress 1.0.17-1 all Backport of Python 3 ipaddress module (Python 2)
ii python-openssl 16.2.0-1 all Python 2 wrapper around the OpenSSL library
ii python-pkg-resources 33.1.1-1 all Package Discovery and Resource Access using pkg_resources
ii python-pyasn1 0.1.9-2 all ASN.1 library for Python (Python 2 module)
ii python-requests 2.12.4-1 all elegant and simple HTTP library for Python2, built for human beings
ii python-setuptools 33.1.1-1 all Python Distutils Enhancements
ii python-six 1.10.0-3 all Python 2 and 3 compatibility library (Python 2 interface)
ii python-urllib3 1.19.1-1 all HTTP library with thread-safe connection pooling for Python
assenzuid
These are my logs, @htilburgs post also some logs.
- ycahome
So, till now seems that you 2 running the same version 8889 and Domoticz crashes, correct?
Is there anyone else that runs 8889 and "Moon phases" working properly?
