Duco rf ventilation remote
433Mhz opensource Receiver & Transmitter.
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
Is there anybody who also uses this remote for the duco air ventilion and got this working with RFlink ?
The remote itself is an battery powered control unit with 4 different buttons: 1,2,3 and auto .
It's nice to be important, but it's more important to be nice
Scooter ;)
SweetPants
Re: Duco rf ventilation remote
Post by SweetPants »
What are the specs of the remote in terms of frequency and protocol?
Does RFX-Manager see the remote?
Stuntteam
Post by Stuntteam »
The Duco is, so far, not supported.
Use the RFLink Loader program and record the button signals with the debug mode.
cos4x4
Post by cos4x4 »
RF-apparatuur op 868 MHz see the manual http://www.duco.eu/Wes/CDN/1/Attachment ... 923179.pdf
Stuntteam
Post by Stuntteam »
That does not change anything.. RFlink already has some 868 protocols and when you use it with the right RF modules will work fine on that frequency. Just like the fact that it works on 315 mhz and 915 mhz.
thecosmicgate
Stuntteam : that would be nice ! Because we also we have this duco air system also
Scooter ;)
nosehook
Post by nosehook »
Is there an update on this?
I have Duco ventilationa and would very much like to implement it in my Domoticz setu.
Currently I run a Raspberry Pi with RFXcom 433E.
Can anyone tell me what hardware I'd need and how to implement it?
Dank,
Freek
Pi3 Domoticz | RFXcom 433E | KAKU/COCO |Harmony Hub | Samsung TV | HS100 | HS110| HUE | Tradfri | Tado| Xiaomi |sensors | scripts| Pi3 Node Red | Pi2 SDS_011 + MH-Z19B | PiAware (zero) | Pi2 breadboard with Node red and Domoticz
thecosmicgate
Hope this will be implemented.
Scooter ;)
leoncornelissen
Domoticz version: 3.8258
Post by leoncornelissen »
I'm very interested if this is implemented somehow in the mean while.
We bought a new house which contains a Duco box. My current Perilex solution does not fit there. The system works with RF but I hope there is a solution with RFXcom. Otherwhise I have to capture the signal myself and build a own solution.
pvm
Domoticz version: 4.10538
Post by pvm »
Any updates on this topic?
I'm also looking for a solution to connect to duco box. Now I'm using it with 2 rf sensors.
I did find this 'schakel contact' (switch contact) http://www.duco.eu/nl-nl-producten/nl-n ... kelcontact
Is that the way to go?
emiel
Post by emiel »
Stuntteam wrote: Monday 21 December 2015 0:19 Hi,
Hi Stuntteam
I've tried both 'Debug' and 'Unhandled' mode, but the tool doesn't show any signals.
Is there anything else I can try?
FYI, my module does detect other (supported) devices.
thecosmicgate
I think because Duco uses 866mhz
Sent from my SM-G935F using Tapatalk
Scooter ;)
Stuntteam
Post by Stuntteam »
The Duco is using 868 mhz with FSK modulation.
We are working on it.
aDJa
Domoticz version: 4.9700
Post by aDJa »
Re-do since previous post was removed..
Hi there,
This is my first post, I've already red many topics with great interest. Thanks for that, great to see so many people participate and help each other.I am also curious how to connect to the Duco box, haven't tried so far but would be nice to control it without placing the extra 'wireless switches' inside the box.
The search continous..
OS: RPi4B, GH
ELECTRICITY: P1 Smart Meter USB
WATER: NPN inductive sensor
SOLAR: Omnik Inverter, PVOutput
LIGHTS: Philips HUE + GLEDOPTO + Yeelight
SENSORS: Xiaomi Temp + Humidity + Baro + Motion + HUE
lakime
Post by lakime »
I am fighting with it as well, so maybe I will share some things that I've found
I currently do try to sniff the signal using rtl_433 (using rtl_sdk), and I do have challenges.
The problem is of course to determine parameters for signal decoding, currently I am trying like this:
rtl_433 -f 868000000 -A -X 'n=DUCO,m=OOK_PWM,s=11,l=83,r=500,g=150,t=5,y=0'
But not to much success... still not able to decode signal, below I am attaching structure of the data found on some community
I am happy to share the signal (with numbers of parameters) ... maybe someone can help me determine parameters, I will be to happy to share output
structure1
structure1
structure2
structure2
